ISDN Calls - Bearer capability not implemented
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
01-24-2012 06:24 AM - edited 03-16-2019 09:10 AM
Hi.
Cause i = 0x8090 - Normal call clearing
Jan 20 13:26:52.647: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x8166
Jan 20 13:26:52.647: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x0166
Jan 20 13:26:57.026: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x16 is 0x0 0x0, Calling num 528181530100
Jan 20 13:26:57.026: ISDN Se0/0/0:15 Q931: Sending SETUP callref = 0x0167 callID = 0x80E8 switch = primary-qsig interface = User
Jan 20 13:26:57.026: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x0167
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Calling Party Number i = 0x0080, '528181530100'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '233000'
Jan 20 13:26:57.046: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x8167
Jan 20 13:26:57.050: ISDN Se0/0/0:15 Q931: RX <- ALERTING pd = 8 callref = 0x8167
Jan 20 13:26:57.058: ISDN Se0/0/0:15 Q931: RX <- CONNECT pd = 8 callref = 0x8167
Facility i = 0x9FAA068001008201008B0100A118020287DE020102800F44465F4154435F434F4E545F505041
Progress Ind i = 0x8182 - Destination address is non-ISDN
Jan 20 13:26:57.058: ISDN Se0/0/0:15 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x0167
Jan 20 13:26:57.262: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x0167 Cause i = 0x80C1 - Bearer capability not implemented
Jan 20 13:26:57.290: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x8167
Jan 20 13:26:57.294: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x0167
Do you have any aidea ?
Thanks..
- Labels:
Other IP Telephony
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-24-2012 06:28 AM
Apply the following to your D-channel:
voice-port 0/0/0:23
bearer-cap Speech
Chris
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-24-2012 06:32 AM
Hi Cris, thanks for your feedback.
I tried with this command but the problem continue.
Regards.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-24-2012 06:39 AM
I've seen this caused by codec mismatch as well, could that be the issue here?
Chris
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-24-2012 06:44 AM
Hi Chirs.
We´ve tried change the codecs but we don´t have results.
Do you know a debug command in order to detect the codec mismatch ?
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-24-2012 06:51 AM
To detect codec mismatch you would need to look at the voip protocol debugs, depending on protocol user it would be different commands, for SIP use "debug ccsip messages"
H323 - "debug h225" or "debug h245 asn1"
MGCP you would look at CCM SDI traces.
HTH,
Chris
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
07-19-2016 03:48 AM
Got to the bottom of this
For MGCP Gateways anyway ..
On Call Manager - goto the gateway in question and drill into the Cisco MGCP T1 port config..
Scroll down and change the Channel IE Type from the default ..
USE Number when 1B OR Slotmap
TO the correct setting
Timeslot Number
PCM Type = u-law
thats for US T1 PRI
Hope that helps ..
