isdn commands not enabled on cisco 2851 router
ayokunles
I am trying to install and configure a voice gateway but the sh isdn command does not seem to be enabled.
Hello Ayo,
Under the
controller E1 0/1/0
channel-group 15 timeslots 30
it should be as
controller E1 0/1/0
pri-group timeslots 1-31
Karthik
Ayodeji Okanlawon
Ayo,
Have you configured your E1 on the gateway. Can you send you sh run
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Hi Okanlawon
The configurations are not complete, I was in the process when i discovered the isdn command isnt working.
nevertheless, see the sh run output.
Hello Ayo,
Under the
controller E1 0/1/0
it should be as
controller E1 0/1/0
Karthik
Hi Karthik,
thanks, I made the change and it worked like charm, I can no see the isdn commands.
thanks a lot.
