10-20-2017 06:38 AM - edited 03-17-2019 11:26 AM
Hello CSC,
I have one doubt about the new ISRs 4XXX.
At the Cisco IOS dowload page has two options of IOS:
Release Denali-16.3.5
Release 3.16.6S
Whats the difference between them?
Leonardo Santana
10-20-2017 07:06 AM
Hi, you can use this tool to compare between the 2 versions:
http://cfn.cloudapps.cisco.com/ITDIT/CFN/jsp/compareImages.jsp
In conclusion, the Denali version includes more features (you can see those in the compare tool above).
So you can upgrade to Denali or not, it's up to you. I have few 44XX but can't see a good reason to upgrade it to Denali for now, everything's needed in my deployments are fully supported in the current firmware version, for me at least.
10-20-2017 02:48 PM
+5 Slavik for excellent response.
In nutshel Cisco in their wisdom decided to skip from version 3.17 of IOS-XE code all the way to 16.X code, not 4.X but 16.X, hence I believe your confusion. Basically Denali is the next iteration of IOS-XE.
