Issues with incoming calls CUCM 8.5
divine007
Outgoing calls works perfectly
but incoming don't work, can someone advice
here are the #debug mgcp events
3900series#
*Jun  3 10:41:20.443: //-1/xxxxxxxxxxxx/MGCP/mgcpapp_process_sys_msg(208):[lvl=0]MGCP sys msg: (EXTERNAL_EVENT)
*Jun  3 10:41:20.443: //-1/xxxxxxxxxxxx/MGCP/xlate_mgcp_sys_ev(69):[lvl=0]xlate sys msg: (EXTERNAL_EVENT, 264873C)
*Jun  3 10:41:20.443: //-1/xxxxxxxxxxxx/MGCP/mgcpapp_process_sys_msg(217):[lvl=0]sys msg values: (INVALID MGCP EVENT, 0,  , 0, CALL_IDLE)
*Jun  3 10:41:20.443: //-1/xxxxxxxxxxxx/MGCP/mgcp_handle_cmapp_event(441):[lvl=0]process
*Jun  3 10:41:20.443: //-1/xxxxxxxxxxxx/MGCP/mgcp_cmapp_send_keepalive(286):[lvl=0]send NTFY KeepAlive
*Jun  3 10:41:20.443: //-1/xxxxxxxxxxxx/MGCP/send_mgcp_empty_notify_msg(3675):[lvl=1]endpt *, complete_endpt *@3900series
*Jun  3 10:41:20.443: //-1/xxxxxxxxxxxx/MGCP/mgcp_get_ne_info(2768):[lvl=1]Used endpoint NE 192.168.0.3
*Jun  3 10:41:20.443: //-1/xxxxxxxxxxxx/MGCP/mgcp_enq_retx_msg(911):[lvl=0]trans_id 402909875,ntfy_ent 192.168.0.3
*Jun  3 10:41:20.443: //-1/xxxxxxxxxxxx/MGCP/mgcp_root_get_profile(1905):[lvl=0]Entered
*Jun  3 10:41:20.443: //-1/xxxxxxxxxxxx/MGCP/MGCP_NEDB_get_next_addr(1211):[lvl=1]
NOTIFY ENTITY = 192.168.0.3
next->192.168.0.3
      <END>
*Jun  3 10:41:20.443: //-1/xxxxxxxxxxxx/MGCP/mgcp_add_trans_id_rec(1167):[lvl=1]Add trans id (402909875, 18189B38) record
*Jun  3 10:41:20.443: //-1/xxxxxxxxxxxx/MGCP/mgcp_stw_timer_start(393):[lvl=0]timer type 0, duration 500
*Jun  3 10:41:20.443: //-1/xxxxxxxxxxxx/MGCP/mgcp_stw_timer_start(393):[lvl=0]timer type 15, duration 20000
*Jun  3 10:41:20.443: //-1/xxxxxxxxxxxx/MGCP/send_mgcp_empty_notify_msg(3738):[lvl=2]NTFY Packet sent successfully - *
*Jun  3 10:41:20.443: //-1/xxxxxxxxxxxx/MGCP/mgcp_count_active_mgc_msg_stat(239):[lvl=1]MGC stat - 192.168.0.3, total=1462, succ=1461, failed=0
*Jun  3 10:41:20.443: //-1/xxxxxxxxxxxx/MGCP/mgcpapp_process_mgcp_msg(3507):[lvl=0] : <NEW MGCP MSG From CA>
*Jun  3 10:41:20.443: //-1/xxxxxxxxxxxx/MGCP/mgcp_msg_ack(6876):[lvl=0]Entered
*Jun  3 10:41:20.443: //-1/xxxxxxxxxxxx/MGCP/mgcp_count_active_mgc_msg_stat(239):[lvl=1]MGC stat - 192.168.0.3, total=1462, succ=1462, failed=0
*Jun  3 10:41:20.443: //-1/xxxxxxxxxxxx/MGCP/mgcp_msg_ack(6948):[lvl=1]Removing msg : NTFY 402909875 *@3900series MGCP 0.1
X: 0
O:
*Jun  3 10:41:20.443: //-1/xxxxxxxxxxxx/MGCP/mgcpapp_process_socket(3618):[lvl=0]Entered
3900series#
3900series#
3900series#
3900series#
*Jun  3 10:41:35.443: //-1/xxxxxxxxxxxx/MGCP/mgcpapp_process_sys_msg(208):[lvl=0]MGCP sys msg: (EXTERNAL_EVENT)
*Jun  3 10:41:35.443: //-1/xxxxxxxxxxxx/MGCP/xlate_mgcp_sys_ev(69):[lvl=0]xlate sys msg: (EXTERNAL_EVENT, 2648750)
*Jun  3 10:41:35.443: //-1/xxxxxxxxxxxx/MGCP/mgcpapp_process_sys_msg(217):[lvl=0]sys msg values: (INVALID MGCP EVENT, 0,  , 0, CALL_IDLE)
*Jun  3 10:41:35.443: //-1/xxxxxxxxxxxx/MGCP/mgcp_handle_cmapp_event(441):[lvl=0]process
*Jun  3 10:41:35.443: //-1/xxxxxxxxxxxx/MGCP/mgcp_cmapp_send_keepalive(286):[lvl=0]send NTFY KeepAlive
*Jun  3 10:41:35.443: //-1/xxxxxxxxxxxx/MGCP/send_mgcp_empty_notify_msg(3675):[lvl=1]endpt *, complete_endpt *@3900series
*Jun  3 10:41:35.443: //-1/xxxxxxxxxxxx/MGCP/mgcp_get_ne_info(2768):[lvl=1]Used endpoint NE 192.168.0.3
*Jun  3 10:41:35.443: //-1/xxxxxxxxxxxx/MGCP/mgcp_enq_retx_msg(911):[lvl=0]trans_id 402909876,ntfy_ent 192.168.0.3
*Jun  3 10:41:35.443: //-1/xxxxxxxxxxxx/MGCP/mgcp_root_get_profile(1905):[lvl=0]Entered
*Jun  3 10:41:35.443: //-1/xxxxxxxxxxxx/MGCP/MGCP_NEDB_get_next_addr(1211):[lvl=1]
next->192.168.0.3
      <END>
*Jun  3 10:41:35.443: //-1/xxxxxxxxxxxx/MGCP/mgcp_add_trans_id_rec(1167):[lvl=1]Add trans id (402909876, 18189B38) record
*Jun  3 10:41:35.443: //-1/xxxxxxxxxxxx/MGCP/mgcp_stw_timer_start(393):[lvl=0]timer type 0, duration 500
*Jun  3 10:41:35.443: //-1/xxxxxxxxxxxx/MGCP/mgcp_stw_timer_start(393):[lvl=0]timer type 15, duration 20000
*Jun  3 10:41:35.443: //-1/xxxxxxxxxxxx/MGCP/send_mgcp_empty_notify_msg(3738):[lvl=2]NTFY Packet sent successfully - *
*Jun  3 10:41:35.443: //-1/xxxxxxxxxxxx/MGCP/mgcp_count_active_mgc_msg_stat(239):[lvl=1]MGC stat - 192.168.0.3, total=1463, succ=1462, failed=0
*Jun  3 10:41:35.443: //-1/xxxxxxxxxxxx/MGCP/mgcpapp_process_mgcp_msg(3507):[lvl=0] : <NEW MGCP MSG From CA>
*Jun  3 10:41:35.443: //-1/xxxxxxxxxxxx/MGCP/mgcp_msg_ack(6876):[lvl=0]Entered
*Jun  3 10:41:35.443: //-1/xxxxxxxxxxxx/MGCP/mgcp_count_active_mgc_msg_stat(239):[lvl=1]MGC stat - 192.168.0.3, total=1463, succ=1463, failed=0
*Jun  3 10:41:35.443: //-1/xxxxxxxxxxxx/MGCP/mgcp_msg_ack(6948):[lvl=1]Removing msg : NTFY 402909876 *@3900series MGCP 0.1
X: 0
O:
*Jun  3 10:41:35.443: //-1/xxxxxxxxxxxx/MGCP/mgcpapp_process_socket(3618):[lvl=0]Entered
16 Replies 16
Hello Neba,
You can't directly to SP and asking for that until you figure out its your service provider who is not sending CLID.
Is calls coming on PRI ? if yes can  you take debug isdn q931 to verify we are receiving it or not, if yes does it get process or is it the CUCM stripping it off . as i see you have some collecting the logs
just collect the logs this way
1) no logging console
2) no logging monitor
# logging buffer 3000000
enabled the debugs, make a test a call and also check on the MGCP GW on CUCM.
Br,
Nadeem
Br, Nadeem Please rate all useful post.
What are your internal extension lengths, i.e. XXXX or XXXXXXXXX? Like Manish stated, you have to set the "significant digits" to the correct length. Unless you have a translation pattern that is converting the number, into an internal number.
Yosh
HTH Regards, Yosh
