ITS Telecom Pantel IP (Door Phone ) + Callmanager
habouzyad
Hi everybody,
does any have an idea about the compatibility between Pantel IP and CUCM 7.0 ?
If there is any documentation, please send me the link
Hicham
7 Replies 7
Hi Hicham,
I have the same problem.
Did you make the registration with a Pantel IP door line and the Communications Manager?
kind regards
Benjamin
Reading this link http://www.its-tel.com/index.php?option=com_phocadownload&view=category&id=22:door-phones-application-notes&Itemid=132
Probably setting up a SIP TRUNK with UDP port 5060
Allow the incoming CSS to find the IP phone or hunt pilot etc partition.
Set up the PANTEL as the TRUNK option section 4.2 on page 15
Alex
Regards, Alex. Please rate useful posts.
Hi Alex,
Thank you very much for your help ;-)!
Its working now.
Kind regards
Benjamin
Mit freundlichen Gruessen - Best regards
Benjamin Krueger
Technology Specialist
Unified Communications & Collaboration
Computacenter AG & Co oHG
Services & Solutions
Voltastraße 1, 60486 Frankfurt, Germany
Tel.: +49 69 97779 255
Mobile: +49 172 8153319
Fax: +49 69 97779 252
Short-Dial: 522255
E-Mail: benjamin.krueger@computacenter.com
WWW: www.computacenter.de<>
Von: acampbell
Gesendet: Mittwoch, 1. Februar 2012 17:42
An: Krueger, Benjamin
Betreff: - Re: ITS Telecom Pantel IP (Door Phone ) + Callmanager
Home<>
created by acampbell<> in IP Telephony - View the full discussion<>
So did using a SIP trunk resolve the issue
Alex
Please rate useful posts and close your case as correct answer provided.
Yes that’s right, I added a SIP trunk and let the doore line make calls to the reception.
Once again thank you ;-)!
Kind regards
Benjamin
Benjamin Krueger
Short-Dial: 522255
Von: acampbell
Gesendet: Donnerstag, 2. Februar 2012 16:21
Home<>
Hi Alex,
Sorry to interrupt you again. But I have other problem with the door line.
DTMF tones are not “hear” at the door line. I configured the trunk with the option DTMF signaling method RFC 2833, on the door line I use the same DTMF option (RFC 2833), but when the reception press a number to open the door, the door line doesn’t open. We use 7962 SCCP phones.
Have you an idea what I can do, that DTMF is transferred via the trunk?
Kind regards
Benjamin
Von: acampbell
Home<>
I have the same problem - however it does work with a model 8961 phone. Did you ever get a solution?
