Jabber 12.8 no outside line prefix
iverson.justin
I noticed on my Jabber 12.8 I don't have to dial an outside access code like 9  to get outside access.  I do 96512223333 and it routes it to external partition.  Am I missing something?  Thanks
Possibly you have an application dial rule that adds the outside prefix to the call from Jabber.
Response Signature
George Sotiropoulos
Assuming that your Jabber is registered on a CUCM, have you tried to place a call while using another device? Jabber will route the call based on the Partition/CSS that is associated with. I would also suggest to try to use Dialed Number Analazer (CUCMIPADDRESS/DNA) and to identify the path of your call via Jabber and/or via another device.
I hope this helps,
George
Please Rate Posts (by clicking on Star) and/or Mark Solutions as Accepted, when applies
Response Signature
