Jabber call issues - VDI environment
Murali_DS
Users are facing call issues like  - one way audio, delay in audio, disconnection (intermittent) only when Jabber used in laptop while logged into VDI desktop. Any troubleshooting technotes/guide to troubleshoot?
They are connected via VPN.
Jabber Version: 11.8.4
CUCM Version: 10.5.2
5 Replies 5
Dennis Mink
well your one way audio issues are probably the easiest to fix. as they are typically related to routing, so analyse the sip traces of a failed call and look at the SDP in it, to see what the RTP stream is supposed to be terminated at.
so if your vpn jabber user dials a phone internally, ping that phone from the vpn client to verify end to end connectivity, also check FW to see if RTP is not getting blocked.
Please remember to rate useful posts, by clicking on the stars below.
Jonathan Schulenberg
Have I read your post correctly that users are connecting over VPN and then logging into a VDI session where Jabber is running? In other words, Jabber is *not* running locally on their VPN-connected laptop?
If true, that is not supported. Jabber only supports chat functionality when running on the VDI server. Softphone functionapity requires VXE, a shim that runs on supported thin clients and registers the soft phone directly from the thin client to keep media offloaded of the server. Jabber is only the UI in that scenario.
have same issue. Do we need DNS for VDI jabber in windows to work? in non VDI machine normal windows desktop softphone is working when logged into jabber client.
Anyone else see this issue?
DNS is a mandatory component of all Jabber deployments. Many features (e.g. Service Discovery and basic TLS certificate validation) depend on it.
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/jabber/12_5/Planning_Guide/cjab_b_planning-guide-for-cisco-jabber-125/cjab_b_planning-guide-for-cisco-jabber-125_chapter_010.html?bookSearch=true#id_83190
HARIS_HUSSAIN
You need to install VXE and additional Ports need to be opened for same.
*** Please rate helpful post; Mark "Accept as a Solution" if applicable
Haris
