Jabra headset and Cisco 7942 Aux port
Saima Harris
Hi ,
Two of our employees are using Jabra headsets. They are currently working over the analog headset port, but they would like to use the digital converter cable the headset came with to improve performance. How should I turned it on to utilize the auxiliary port in behind the phone.
Head model:       Jabra GN9300e
Phone model:     7942
Any help would be much appreciated.
Saima
saima.harris wrote:
Thanks for the quick response .
How can I configure it on CME
Saima
I just searched the forums for "CME Headset Enable" and found this document as the second link.
https://supportforums.cisco.com/docs/DOC-9928
Anthony Holloway
Please use the star ratings to help drive great content to the top of searches.
Rob Huffman
Hi Saima,
With the Cisco 7942, you would leverage the setting under
the product specific porting of the config via device>phone
and set Wireless Headset Hookswitch Control to Enabled
http://headsetplus.com/PDF/Jabra-EHS-guide.pdf
Cheers!
Rob
"And if I should fall behind
Wait for me" - Springsteen
Saima
Saima
Anthony Holloway
Yungi Chu
I believe you can find your answer here:
http://headsetplus.com/category99_105/index.html
