LDAP Sync to wrong AD Server "Inactive LDAP Synchronized User" is not removed
dan hale
Level 3
Level 3
Hello All, I sync'd up to the wrong Active Directory Server. I removed the old AD server in CUCM 11 and pointed it to the correct AD server and sync'd up. Now I have a dozen or so "Inactive LDAP Synchronized Users" and It's been about two days. I would have thought the Garbage Collection process would have removed the dozen or so inactive users.
What are my other options? Should I remove all instance of LDAP enabled end users and give the garbage collection process its process or should I re-add the old server let it sync up then convert the users I know that don't exists on then new AD server to local accounts and delete?
Dan
Shashank Mahajan
You can convert those inactive LDAP synchronized users to local CUCM end users by running the following command from CLI:
run sql update enduser set fkdirectorypluginconfig=NULL where userid IN ('userid1', 'userid2', ‘userid3’, 'userid4', 'userid5')
Once they are converted to local CUCM end users then you can delete them right away.
Tried the above but when I run the command I get the following error:
Column (actual user ID) not found in any table in the query (or SLV is undefined)
I ran the below command on both active and non active users:
run sql update enduser set fkdirectorypluginconfig=NULL where userid=’<userid>‘           —– Replace <userid> with the actual User ID on CUCM
Does this require "root" access?
This command can be run from the CLI and does not require root access. I was able to run this command on my lab CUCM 11.0 successfully (Screenshot attached for your reference).
I'm not sure why I couldn't run the command.
I ended up adding back in the previous LDAP server then converting the users to local and deleting. I only had about 30 users so it did not take that long.
Dan
