08-07-2013 12:16 AM - edited 03-18-2019 11:17 AM
Hi All,
We have one cluster in India and another cluster in UK. We dont have any trunk between them. Both doesnt speak with each other. Now we are planning to move 250 No's IP Phones from UK to India cluster. My query is, do we need to buy separate licenses for the 250 devices or can we transfer the Existing license from UK cluster Publisher to India Cluster Publisher? If possible, then provide me the procedure. Kindly suggest.
Sankar.
08-07-2013 12:20 AM
Hi Sankar,
As far as I know, u cannot do transfer of licenses from one cluster to other.
Let others comment.
regds,
aman
08-07-2013 12:37 AM
Hi Sankar,
U can also refer the DOC for license borrow for UCL within a cluster.
regds,
aman
08-07-2013 06:56 AM
Licenses cannot be migrated from one cluster to another, you will need new licenses.
HTH,
Chris
08-07-2013 07:48 AM
Hi Chris,
thanks for supporting(+5)
regds,
aman
08-07-2013 09:26 AM
One alternate solution to this would be if you upgrade to 9.x and integrate both clusters to a single Enterprise License Manager instance. In this case all of your licenses get pooled into one place and any number of clusters can check licenses out.
Please remember to rate helpful responses and identify helpful or correct answers.
