02-19-2014 04:41 AM - edited 03-18-2019 11:20 AM
Hi All,
We've deployed Cisco BE6K and we are required to do redundancy for CUCM & CUC do we need to have separate UWL license for the redundant servers ?
Please help.
Best regards
kennedy
Solved! Go to Solution.
02-19-2014 04:44 AM
No you do not need separate CUWL licenses. The reason is that licenses on CUCM 9.x and later which is when CUWL starts to be used are not node or server based but user based instead. You can have as many servers for redundancy as you want without changing the number of licenses you have.
02-19-2014 04:44 AM
02-19-2014 08:13 PM
Hi Joseph,
Many Thanks for your response.
Best regards
Kennedy
02-20-2014 01:49 AM
Joe,
Long time..!! We have missed you on the forum! Welcome back..Bet you have been busy..
Please rate all useful posts
"The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
