Limit Max Calls on a PRI
anupamjain
We are using 3825 and 3945. For one our PRIs, we want to  limit the no. of simultaneous calls to 10 (instead of 30). Searched  through the docs but couldnt find any parameter or dial-peer config to  do that. Is this achievable?
Anupam
ronpatel
Level 8
Level 8
If you have one dial peer POTS for that PRI you can configure  max-conn under that dial peer.
Or Else you can have fractional PRI configured. I believe fractional PRI is not supported but worth a try.
Ronak patel
Rate Helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Anas Abueideh
Level 9
Level 9
do u have fractional PRI ?
Anas
Sent from Cisco Technical Support Android App
Do you mean inbound? outbound?? both??
And practional PRIs are supported, as long as you're using H323. We do not support them, if you want to use MGCP.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
As my colleagues already suggested simply configure the controller with number of channels you desire.
Chris
