02-23-2013 10:43 PM - edited 03-16-2019 03:54 PM
If I receive a call on a Sip phone (9951), no name is displayed. However, when I look in the local directory, the entries are present.
With SCCP phones everything is ok.
Do you have any idea what could that be?
9951, 7970, 7942 on CME 8.6
Regards, Patrick
Solved! Go to Solution.
02-24-2013 12:26 AM
SIP phones do not support directory lookup for external calls, an many other things.
However you can use my script "number to name". It can be acquired on the website mentioned in my profile.
02-24-2013 03:04 AM
Internal calls should show names. Maybe update IOS, phne firmware, check everything over again, etc.
02-23-2013 10:58 PM
Hi Patirck,
do you have this issue between sip to sip phones or sccp to sip phones ?
Anas
02-24-2013 12:26 AM
02-24-2013 01:39 AM
That is a pity. My concern is simply for the local (internal) calls. The problem I have only SCCP to SIP Phones. SCCP to SCCP works.
Calls from SIP to SCCP and from SCCP to SCCP are ok.
Calls from SCCP to SIP are not ok.
02-24-2013 03:04 AM
