local VoIP - LAN
ahmedeshtiwi
Hello..
I have a local network that consists of a Router, a Fire-Wall, a core switch (4507R) and Several (3750) switches which are connecting more than 100 end-point PCs.
I need to implement local VoIP between devices (either software on PC -Preferred- or a VoIP telephone). How Can I do that with minimum requirements?
Thank you
Ahmed
You can use a supported router i.e. 29XX/39XX, 28XX/39XX and run Communications Manager Express (CME) on it, ASA nor switch can not provide telephony services.
5 Replies 5
Chris Deren
Are you asking for Cisco Collaboration product recommendations?  Based on your size I would explore BE6K bundle. You can contact local Cisco partner for free quote.
RedReddington
What router is it? Could you not get a license for CME/CUE and run it on that (if its up to spec)
Leo Laohoo
What is your budget?
How many phones are you looking at?
ahmedeshtiwi
Well, the thing is: I would like to run a test first and my question was that is it possible to configure CISCO ASA or Switch as an SIP server or what so ever. I can manage to get a couple of IP telephones for the test, but I don't like to buy a new device for the time being at least, until later maybe. Is that even possible (No voice experience before, so excuse me :) )
Thank you
