Maximum input received extension mobility - IP Communicator
simc92
When I try to type a long email address as UserID in Cisco IP Communicator there is an error message 'Maximum input received'.
We can't create an alias because our users are synchronized with LDAP.
I know there is no more support from Cisco for this product but do u have an idea ?
Thank you.
Best regards.
Jaime Valencia
There is a limitation for only 32 characters to be allows for user input, there is no way around this, other than using shorter user IDs.
java
if this helps, please rate
5 Replies 5
Use the USRER-ID  displayed on your CUCM enduser page. Does your USER id showing testtesttest@testtesttest ?
Response Signature
Yes, the UserID is the email address (synchronized with LDAP, I can't modify this field).
You do have the option to use samaccountname as the field for user name in CM instead of email.
Response Signature
Jaime Valencia
java
Thank you!
