Media sense recording
b717k
Does Media Sense recording work with Extension mobility ?
Manish Gogna
Hi Bala,
As per the following link
http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/workforce_optimization/qm_9x/installation/guide/qm90-installation-user-guide-cisco.pdf
Cisco MediaSense Recording Limitations
"Cisco does not support Extension Mobility with Cisco MediaSense Recording"
Manish
Is this true for both Contact Center agents and telephony users?
And what happens if media forking is done by CUBE.. then I think it should be supported?
Nirmal
Yes we forking the media via Cube and the agents are using EM. It works very well and it is supported by TAC I've had to reach out to them before. Since techincally they are just supporting the audio forking.
http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/mediasense/901/inst_admin/CUMS_BK_IFE33F4B_00_mediasense-install-and-admin-guide_chapter_011.html
