Meetme maximun call busy tone
I trying to increase the maximun number of call that Meetme can handle but after the 6th call is made a fastbusy tone is received. I have followed the next steps:
1. Increased the Maximum MeetMe Conference Unicast parameter to 10
Service Parameters->Maximum MeetMe Conference Unicast:10 for all Call Manager server
2. Hard/Software Conference are available for use for meetme conference:
CUCM
IOS Conference Bridge Info
Required Field Cisco IOS Enhanced Conference Bridge
Device is trusted
Required FieldCFBCUBE
CFBCUBE
Required FieldDefault
Required FieldHQ
Required Field
Required Field
Router#sh dspfarm dsp all
SLOT DSP VERSION  STATUS CHNL USE   TYPE    RSC_ID BRIDGE_ID PKTS_TXED PKTS_RXED
0    15  26.8.1   UP     N/A  FREE  conf   2      -         -         -
0    16  26.8.1   UP     N/A  FREE  conf   2      -         -         -
0    17  26.8.1   UP     N/A  FREE  conf   2      -         -         -
0    18  26.8.1   UP     N/A  FREE  conf   2      -         -         -
Thanks in advance.
__________________________________________________
Please remember to rate useful posts clicking on the stars below.
LinkedIn Profile: do.linkedin.com/in/leosalcie
Most likely you're using the HW CFB and the number of conferencees is limited due to the codecs under your dspfarm configuration.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
8 Replies 8
arunkum3
Did you place the conferencing resources in the MRGL of the user who initiated the Meet me call ? Please do it if not done already and let me know if it resolves the issue.
Arun Kumar
Please rate useful posts.
Yes, the conferecing resources are place in the MRGL of the user.
java
java
Rob Huffman
Hi Leo,
I'm going with my friend Java here Have a look at the restrictions shown in this
doc with Hardware Conference Bridges;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/7_1_2/ccmsys/a05confb.html#wpxref27448
Cheers!
Rob
"Always movin' ahead and never lookin' back" - Springsteen
I'm using both HW/SW Conference resources. For DSP it used a Cisco 3945 CUBE with G.711 CODEC so which should be the maximun number of participant?, the link only show the restricction for Cisco Catalyst.
Please post your dspfarm config and how are your MRG/MRGLs configured?
Which CFB do you use in first place?
java
java
I used in first place the harware conference bridge.
CUBE 3945 setup:
sccp ccm group 1
associate ccm 1 priority 1
associate ccm 2 priority 2
associate ccm 3 priority 3
associate ccm 4 priority 4
associate profile 2 register CFB_1CUBE
associate profile 1 register XCODE_1CUBE
keepalive retries 1
keepalive timeout 10
switchover method immediate
switchback method immediate
show run | s dsp
dspfarm
dsp services dspfarm
dspfarm profile 1 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 90
associate application SCCP
dspfarm profile 2 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 40
CO01CUBE#
CUCM
CUCM
HQ_MRGL
   HQ_HW_MRG
CFB_1CUBE CFB_1CUBE
  CFB_2CUBE CFB_2CUBE
  CFB_1CUBE CFB_1CUBE
  CFB_2CUBE CFB_2CUBE
   SW_MRG
CFB_1CUBE CFB_1CUBE
  CFB_2CUBE CFB_2CUBE
  CFB_1CUBE CFB_1CUBE
  CFB_2CUBE CFB_2CUBE
I realized that I was missing the command: Maximun conference-participant so now the conference ad-hoc are working but the Meetme is still not working.
After some looking, I realized the Meetme is using the MCU Media resources so maybe there's a way to increase the number participant for the MCU.
