04-05-2011 08:54 AM - edited 03-16-2019 04:20 AM
We are using QSIG on a MGCP E1 between CUCM vers 8.5(1) to an Ericsson MD30 PBX network.
We are using MGCP because of caller-name transmission, that is working well.
When calling from CUCM to Ericsson, the ringback tone is inband (pd=8). and in some cases of routing calls through the remote PBX's, we receive continious tone instead of ringback tone due to the PBX.
Does somebody knows how to play ringback tone in MGCP on "RX <- ALERTING" instead of listening inband information, like with "alert-no-PI" in H323 ?
Thanks in advance.
GW#
*Apr 5 15:39:43.206: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8 callref = 0x0046
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9839F
Exclusive, Channel 31
Facility i = 0x9FAA06800100820100A10F02010002010080074C796E63204450
Calling Party Number i = 0x0081, '59900'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '54616'
*Apr 5 15:39:43.310: ISDN Se0/1/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x8046
*Apr 5 15:39:43.594: ISDN Se0/1/0:15 Q931: RX <- ALERTING pd = 8 callref = 0x8046
Facility i = 0x9FAA068001008201008B0102A11102020B7902010180084D4F44454D203031
At this state we hear continious tone instead of ringback tone
*Apr 5 15:39:47.058: ISDN Se0/1/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x0046
Cause i = 0x8090 - Normal call clearing
*Apr 5 15:39:47.118: ISDN Se0/1/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x8046
Cause i = 0x8590 - Normal call clearing
*Apr 5 15:39:47.138: ISDN Se0/1/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x0046
GW#
04-05-2011 02:18 PM
For the MGCP ringback tone,
1. Go to the Service menu and select Service Parameters from the Cisco
CallManager Administration page.
2. Choose the Publisher CallManager Server and Cisco CallManager
service.
3. Scroll down to Disable Alerting Progress Indicator from the
Clusterwide Parameters (Device - PRI and MGCP Gateway) section. Set this
parameter to False and click Update.
Hope this helps.
04-05-2011 11:44 PM
It is set to false by default. I tried the 2 values.
04-12-2011 02:57 AM
Did you find out what was the problem?
I'm testing a CM8.5(1) with an MGCP QSIG to MD110, using the same configuration as in previous CM releases
However, I'm having issues in the CM to MD110 direction.
Calls from MD to CM work fine but from CM to MD I'm having issues with ringback and as soon as someone answers on the MD side the call is dropped only on their side...
Best regards,
Carmen
04-13-2011 04:37 AM
Just check the Progress indicator sent by the PBX in the alerting Message.. If the PBX sends PI =2 in the alerting message then, this will cause GW not to play anything and just listen to the inband channel. To solve this problem you can make sure PBX not to send PI in the alerting message.
Alternatively you can try this service parameter on the CCM and check what happens
"Disable alerting progress indicator" - set this is "True" and click "update". Try both alternate options and this should fix your issue.
Thanks.
04-13-2011 10:21 AM
Carmen,
I have not find a solution. My issue is a little bit doffrent than yours.
When I call from CUCM to the first Ericsson PBX (the one connected to the QSIG E1 trunk) , if the PBX generates its own ringback tone I hear it. If not I do not hear anything.
When I call from CUCM to a remote Ericsson (behind the first one, they are connect together with an IP proprietary link) the ringback tone is a continious tone.
In all cases the pd=8
04-13-2011 10:34 AM
I guess there is only one option :-(
Device>> Gateway >> PRI >>Setup non-ISDN Progress Indicator IE Enable
Check this box and reset the gateway.
Here is a brief explanation of the feature:
Enable this setting only if users are not receiving ringback tones on
outbound calls. When this setting is enabled, the Cisco Unified
Communications Manager sends Q.931 Setup messages out digital (that is,
non-H.323) gateways with the Progress Indicator field set to non-ISDN.
This message notifies the destination device that the Cisco Unified
Communications Manager gateway is non-ISDN and that the destination
device should play in-band ring-back.
In this case if the gateway has to paly the dial tone locally we would have to change the switch type to a different one.
As I have noticed it earlier the switch type in use qsig does not offer this option.
03-22-2012 01:32 PM
Everyone,
I know this thread is a year old but I just ran into this same issue guy.richard mentions trying to setup an MGCP controlled E1 between a Nortel and a Cisco 2911 using PRI-EURO. I ended up going the opposite direction than Yogesh and guy.richard did. Instead of trying to cut-through audio so ringback could be sent in-band via the non-ISDN endpoint, I told Call Manager to cut through on the CONNECT indicator instead. This forced ringback to be sent out-of-band regardless and it worked.
Steven
-Please rate helpful posts
05-06-2018 06:46 AM
Hi, thanks.
helped for MGCP:
Checkbox - Setup non-ISDN Progress Indicator IE Enable****
Do not forget to enter no mgcp and mgcp commands at a gateway.
10-08-2012 02:17 AM
It worked for me, after changing the value to CONNECT under "Outgoing Media Connect Time for PRI".
I have CCM v 8.5 connected to MD110 ericsson PBX using MGCP gateway.
Users when dialing from CCM towards MD110 were not able to hear ringback tone, vice versa its working fine.
Now after changing the above said value it worked, users are able to hear the ringback tone when dialled from either sides.
Earlier i had tried all the options but none worked.
Thanks....
