Mobile Connect not valid user
seaman0555
CUCM 7, I am setting up Mobile Connect and it will ring the cell phone, I can hang up the cell phone and pick up on desk phone, but cannot transer from desk phone to cell phone.  When I press the mobility softkey I get "Mobile Connect Off" "You are not a valid Mobile Connect User"  I have walked through the guide and it looks like everything is set properly, any ideas?
Adam Thompson
Level 4
Level 4
Have a look at the remote destination configuration for the user. You will see a check box for 'Mobile Phone'. Checking this check box ensures that, if Send Call to Mobile Phone is specified (by using the Mobility softkey for remote destination pickup), the call gets extended to this particular remote destination.
Also, make sure that the 'Owner User ID' field on the user's desk phone is configured with the appropriate user ID.
Adam
Please rate if helpful
Adam Thompson
Level 4
Level 4
Adam
Adam, thanks, I found the problem was having extension mobility enabled, this seems to be left out of documentation.
Thanks, we also faced this issue. It got resolved after disabling  extension mobility , then associating owner user ID & later enabling ext mobility check box again.
Nikolay Kozyrev
Tnankx. The problem has been resolved when i've made assosiation the Owner User ID field of the user's desk phone with the appropriate user ID.
