Monitoring CUCM cluster with Zabbix
Sinisa Hreljac
Hi to all!
Is there any Zabbix template for CUCM version 7.1 for monitoring CUCM cluster? By that I mean, server performances, active calls, IPT registrations, usage of MGCP gateways...anything that could be found by SNMP...
If not, how can I manually create such template in Zabbix (I'm not zabbix guru)? Is it worth doing that or there is some other monitoring tool that has template for CUCM 7.1 (cacti, nagios??).
What are you people using for monitoring/alerting with some history logging?
Thanks!
6 Replies 6
davethehedgehog
Level 5
Level 5
You can walk it and get the values from here...
ftp://ftp.cisco.com/pub/mibs/oid/CISCO-CCM-MIB.oid
I made a nagios template a long time ago to allow this to be monitored, but it's been lost to the ether a long time ago.
Not that familiar with zabbix though. I can't see any templates for this. Zabbix looks good though, maybe I'll take a look and make one. It's open source.
Hi!
Yes I found that, but there is some missmatch in data from that document and what server returns to me.
Let's see this one in CISCO-CCM-MIB.oid:
"ccmActivePhones" "1.3.6.1.4.1.9.9.156.1.5.1"
When I try to snmpwalk on server, I received:
snmpwalk -v 2c -c xyxyxy 10.25.31.20 1.3.6.1.4.1.9.9.156.1.5
iso.3.6.1.4.1.9.9.156.1.5.5.0 = Counter32: 740
iso.3.6.1.4.1.9.9.156.1.5.6.0 = Counter32: 14
iso.3.6.1.4.1.9.9.156.1.5.7.0 = Counter32: 2
iso.3.6.1.4.1.9.9.156.1.5.8.0 = Counter32: 11
iso.3.6.1.4.1.9.9.156.1.5.9.0 = Counter32: 0
so there is no 1.3.6.1.4.1.9.9.156.1.5.1 oid-
If I try snmpget:
snmpget -v 2c -c xyxyxy 10.25.31.20 1.3.6.1.4.1.9.9.156.1.5.1
reasponse is:
iso.3.6.1.4.1.9.9.156.1.5.1 = No Such Object available on this agent at this OID
CUCM version is 7.1.5
As I see, that CISCO-CCM-MIB.oid is not accurate to my CCM version
was this resolved?
I have the same task to monitor CUCM 11.5 could not find any OIDs to monitor
need at least CPU, Active phones, active calls etc.
I need some template to manage Cisco IP Phone without CUCM on ZAbbix
sathishkumark
Is it possible to monitor cucm services status in zabbix?
sathish
Hi! Does anybody get Zabbix-CUCM integration to work? Thank you
