Most stable UCCM 8.6
eljose_lol
Hello
I would like to know what´s the most stable CCM 8.6 version
Please, post full version number...
thx
2 Accepted Solutions
Chris Deren
8.6.2.21900-5 has been very stable, but I see 8.6.2.22900-9 was released couple of weeks ago. I have not installed this one yet, so to stay on the safe side I would go with the earlier, unless you see specific fixed bugs in the later version that might affect you.
HTH,
Chris
Ayodeji Okanlawon
We have three clusters running 8.6.2.21900-5. Its been very stable.
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
11 Replies 11
Chris Deren
HTH,
Chris
Hi every1
Thanks vey much for your reply, even 8.6.2.21900-5 has more bugs than 8.5 ? i did a search on bug tool and the result was 8.6 has more.
You need to do some due diligence and review the bugs to see which are applicable to you in your deployment. Its not enough to say that there are more bugs  in it than in CUCM 8.5. A while ago while working on a design, I sat with my colleagues and we reviewed the bugs on 8.6 and we were satisfied with what we saw based on our deployment.
If there are bugs which affecta certain features you intend to use, then that calls for some deeper thinking..etc
Gordon Ross
Level 9
Level 9
8.6 in general has been a solid release for me.
I've been using 8.6.2.20000-2 since it came out.
GTG
Please rate all helpful posts.
Ayodeji Okanlawon
Watch out for a nasty tomcat issue which is finally fixed in the latest version 8.6.2.22900-9, it hit several of our customers pretty hard taking down call centers, etc.
HTH,
Chris
Do you have a bug ID, Chris ?
GTG
Here is one:
CSCtx83737
I think there are others
may want to look at readme:
http://www.cisco.com/web/software/282074295/93949/cucm-readme-862asu2.pdf
I am recommending all customers affected by it immediate upgrade.
HTH,
Chris
Ah, CSCtx83737 is just a Unity bug.
GTG
Not only, notice the readme lists it under CUCM, however bug ID references UCON, it affects both I think.
Chris
Rob Huffman
Hey folks,
Excellent thread here ! +5 to Chris, Deji & Gordon for their awesome input
This one's "special" as well (nice to see a fix);
Warning for CSCtj50884
•This SU contains an update to the RTMT client that addresses a significant memory leak. You must upgrade the client version on any device that uses the RTMT client to completely resolve this issue. Please see the Bug Details of fix CSCtj50884 for complete instructions on resolving this issue.
Cheers!
Rob
"Every fool's got a reason to feelin' sorry for himself" - Springsteen
