05-24-2013 08:15 AM - edited 03-16-2019 05:29 PM
Dear Friends
I wish you are fine ....... I need your help in CUCM ...... I have a customer that have CUCM 6 with 100 IP Phones (some of them 7911 , other 7945 others 7965) ....... He need to implemet CUCM 9 at another new site and he will take some of the IP Phones (20 form 7911; 20 from 7945 & 10 from 7965 ) and need them to work with the new CUCM 9
My question is: Can i move the IP Phone licenses which are already added to CUCM 6 to the new CUCM 9 so that those 50 IP Phones can work with the new CUCM 9 ???
If you have any document from Cisco, Kindly share it
Thanks in advance
05-24-2013 08:20 AM
You will need to work with licensing@cisco.com, but my understand is that unless this is an upgrade you are not entitled to move licenses between clusters, you would need to purchase the migration license.
HTH,
Chris
05-24-2013 08:57 AM
Hi Ahmed,
In addition to what Mr. Chris (+5) has said, you can refer this POST which talks about the migration of IP phones and CUCM version as well.
https://communities.cisco.com/thread/18836
Refer the PArt code MIG-CUCM-USR-A .
Do consult Cisco SE before quoting solution.
regds,
aman
