04-16-2020 10:43 AM
We need to replace some of our UCS servers which has a CUCM Pub and Unity Pub on them, if they were Subscribers then no issues.
The original have been installed with Hostnames
Issue
At the moment the new UCS are in different DC`s from the original clusters
our thinking is as follows
Move the UCS to the same DC as the original, same Subnet as the original Pub
Build the new UCS servers with the same IP and Hostnames but hide them behind NAT rules
Build the servers with the same SW as the original
Restore the DRS to the new servers from the original Cluster
Turn off the old Pub , un-hide the new servers
Cluster live
Aim - Try to reduce any certificate issues by keeping the IP and Hostname the same
The other option is to keep the new UCS in different DC
Change the IP address and Host name on the new "PUB"
Cluster live
issue -Would we need to do the Certificates due to the change of IP and Hostname
Next Question
After the work above we need to upgrade from 10 to 11 - is there any issues, Certificates on phones etc. we aim to keep the old phone firmware in place by turning off the TFTP , replace the new firmware with the old ones , turn on TFTP
We have Unity and IM&P as well where we need to do the same
thanks
04-16-2020 11:00 AM
Feels like your overthinking this. As the CUCM is a VM you should be able to just move it as is to a new ESXi host that is running on the new UCS. No need to rebuild the node and restore from DRS.
04-17-2020 05:27 AM
Why not look at PCD network migration as an option? It would require you perform an upgrade at the same time, but eliminates re-hosting and re-IPing, I have done it in similar circumstances. You would have to migrate your Subs to new VMs with this approach as well, so if you have large cluster this may not be worth it, just throwing out options.
04-17-2020 09:17 AM
Hi roger
I was originally told we couldn't do this by our server team but now it seems we can
04-17-2020 10:55 AM
You definitely can do this, we have used it multiple times for UCS hardware renewals or move VMs to other ESXi hosts that run on non UCS hardware.
