multiple route pattern
elite2010
Level 3
Level 3
I want to create multiple route pattern for same long distance  . Now I am using 9 for the long distance
for user a i want to use one gateway , for user b i want to use another gateway .
What is the solution ?
George Sotiropoulos
May I suggest creating a second Route Pattern with using different prefix, to direct the call to another Voice-Gateway?
If the above doesn't work for you, then you will need to create another Partition with individual Calling Search Space and assign the user and the Voice-Gateway to that Partition (PartitionB).
Users in partition A would call 9.X using Gateway A and users in Partition B would call 9.X using Gateway B.
You may find the following link useful:
https://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-callmanager/22325-part-css-tn.html
George
Hope the above helps,
gsotirop
What if the long distance 9.[2-3]XXXXXX go to gw1  and 9.[4-6]XXXXXX goto gw2
Dennis Mink
this is fairly easy to do:
user A has device pool A, with in it local route group A (containg gateway A)
user B has device pool B, with in it local route group B (containg gateway B)
the long distance route patter is one pattern for both, but using local route group as its destination, simples
Please remember to rate useful posts, by clicking on the stars below.
What if bot h devices are in same pool A
