MVA cannot hear prompt after enter your remote destination number
CSCO11555492
Greeting
I  am trying to configure Mobile voice access my call manager in 7.0.2 the  call is connected and i get a prompt " welcome to cisco unified  communication enter your remote destination number follow by the bound  key " after that i am unable to hear any thing and call will be  disconnected
here is my configuration in H323 gateway
voice service voip
fax protocol cisco
application
service mva http://142.100.64.11:8080/ccmivr/pages/IVRMainpage.vxml
dial-peer voice 3000 pots
service mva
incoming called-number 3000
direct-inward-dial
forward-digits all
dial-peer voice 2 voip
destination-pattern 3...$
voice-class codec 1
voice-class h323 1
session target ipv4:142.100.64.11
dtmf-relay h245-alphanumeric
no vad
here is my configuration in my call manager
1 - enable enterprise feature in service parameter
2- enable mobile voice access in service parameter
3- Mobile voice access number is 3000
4-Matching Caller ID with Remote Destination = partial match
5-Number of Digits for Caller ID Partial Match = 7
6 - under media resource mobile voice access directory number is 3000
7 -enable mobile voice access for certain user
8- create remote destination profile for this user
9- create remote destination number for remote destination profile
6 Replies 6
ashok_boin
Level 5
Level 5
Have you enabled mobility for the user?
With best regards...
Ashok
ya its step number 7 in call manager configuration
Try doing a full match on the Remote Destination number.  CUCM 7.0 had a lot of partial match issues.  The prompt should be asking for your PIN, not the number.  It should tell you to press 1 to dial a number.
hi all,
just new to MVA and i have reached the IVR where it is saying " enter your remote destination number" do i really need to create a destination profile if we are not enabling mobile connect just MVA?
if destination profile is required what destination number will i need if we are not to use mobile connect?
You need a Remote Destination Profile for MVA so you can add the shared line as well as set the appropriate CSS on the line/device.  On the Remote Destination number, just don't check "Mobile Connect".  The destination number will vary depending on if you're using full-match or partial-match.
Nishant Savalia
Level 4
Level 4
Do you have subscriber in your network?
If yes, then to which server your phones are registered? I mean with Publisher or subsciber?
Because as per your configuration you have one dial-peer pointing towards IP (142.100.64.11).
Also, please check if your deskphone number is marked or checked in Remote Destination Number.
Regards, Nishant Savalia
