05-02-2016 01:04 AM - edited 03-17-2019 06:47 AM
Hi there,
We have recently purchassed some new MX800, MX300 G2 video endpoints which have replaced our legacy Tanberg 880 units. The Tandberg devices were registered to the VCS-C appliance, where as the newer endpoints have been migrated onto the CUCM server. We can make and recieve calls to these units, but when we try and call an encrypted devices outside of our organisation, the call is only set-up as non-encrypted.
We have witnessed this when we have tried to join a 3rd party VC call hosted by Blue Jeans. We join the BJ meeting ID, but once we add the PIN number, the call comes back notifying us that the call is not encypted and disconnects the call. When l look at the call going out from the endpoint, l see the calls goes out with encryption on, but when it joins BJ the call is uncrypted, although this does work from our one remaing legacy Tandberg unit, so this does work from a VCS-C registered device.
I have been looking at the following options for CUCM registered devices:
Can someone please let me know if they have their VC endpoints registered to CUCM, and if they can make encrypted calls to hosted VC services? If they can, could they share how their deployment is configured?
Thanks and best regards,
James
Solved! Go to Solution.
05-04-2016 04:53 AM
Hi James,
I can actually see CTL files installed on the phones with non secure profile configured. So what it means is that the following options decide whether the phone would like to have the authentication / encryption of its signaling and media in addition to whether the CTL file exists on the phone
Non Secure - unencrypted signaling and unencrypted media (voice / RTP / Real Time Protocol)
Authenticated - encrypted signaling and unencrypted media
Encrypted - encrypted signaling and encrypted media
Manish
05-02-2016 03:25 AM
Hi James,
To your two questions above:
1. Yes, CUCM needs to be in mixed mode for the TLS/Encryption to work
2. Phone can still be in non-secure mode when you enable Mixed mode if the following Phone security profile is applied
You may refer the following for details
https://supportforums.cisco.com/document/73611/ip-phone-security-and-ctl-certificate-trust-list#Create_and_Apply_Phone_Security_Profiles
Manish
05-02-2016 06:57 AM
Hi Manish,
Thanks for getting back to me.
In regards to the information you provide +5.
If you changed an endpoint to use the Secure / TLS under - System > Security Profile > Phone Security Profile, would this enable the use of the TLS functionality if the cluster was not configured for Mixed Mode? I think you may say no, but l just want to confirm :-)
Also if the phones were configured for the default Non Secure Profile and the cluster was configured for Mixed Mode, would the phones download a CTL file after the CUCM service is restarted?
James
05-02-2016 07:08 AM
Hi James ,
Yes, mixed mode is a pre requisite to make this work. As per my understanding the phone will not download ctl with non secure profile. I will check in the lab tomorrow for confirmation though.
Manish
05-04-2016 03:57 AM
Hi Manish,
I hope you are doing well.
Can you let me know if you managed to test this in your lab?
James
05-04-2016 04:53 AM
Hi James,
Manish
08-01-2017 07:38 PM
Hi James
Did you
- Basant
08-01-2017 11:15 PM
Hi Basant,
You can open a new thread if there is no reply on this post so that others may respond to your query.
Manish
08-01-2017 11:56 PM
Hi Basant,
In the end we decided not to configure mixed mode on our CUCM. To resolve the issue we decided to buy multisite option keys for the TP VC units, so if the call needs to be encrypted it can be.
If your customer has their endpoints registered to the CUCM, they need to decide if they want to make the change on the CUCM, or buy TP Option keys.
James
08-02-2017 12:35 AM
Thanks for your reply
I assume customer would prefer to have
Could you guide me on how the design would look like in this case with Multisite licenses on TP endpoint? What configuration changed you did on CUCM? I thought it would not be possible to encrypt calls without having the CUCM in mixed mode?
Thanks again for your
- Basant
08-09-2017 11:29 PM
Hi James
Just wondering if you had a chance to go through my last message. The response I am getting from TAC is to run encrypted calls, there is no option but to run CUCM in mixed mode which my customer is reluctant to however how you were able to
Looking
- Basant
08-10-2017 01:01 AM
Hi Basant,
I had responded to your post, but for some reason it looks like it never saved, ort something happened.
Anyway, we decided as your customer has, that installing mixed mode was a big thing to do, and we decided not to do this either.
In the end we installed the following option keys to all TelePresence endpoints that required to make encrypted calls.
Encryption - Enables encryption of media streams.
Hope this helps.
James
08-10-2017 01:06 AM
So is only installing "Encryption Keys" enough on TP endpoints or "Multisite" keys are also required as you mentioned in earlier post?
- Basant
08-10-2017 01:14 AM
Hi Basant,
If you are looking for just Encryption, the Encryption option key should be enough. The Multisite would be if you want the VC endpoint to conference more than one VC call.
James
