need an SRST advice
first of all my greetings to everyone who'll see this thread)
I have a common SRST solution: A CUCM 4.2 in central office and remote 3845 with SRST feature with ip-phones on this device registered on the mentioned above CUCM 4.2. In the case of WAN link failure phones are operating in SRST mode.How can I force those phones to register on CME that is collocated with 3845 if WAN link failes?Which commands are used for this purpose(both on CME and SRST routers)?
PS: and one extra question: where is (while operating in SRST mode) the phones' config stored(dn, etc...)? - I ve restored phones config to deafaults - they got their configured on CUCM dns.I've powered off the router - they still got their dns. changed ports of the phones...) <- common curiosity.
MARTIN STREULE
The following doc explains how to use CME as SRST:
Configuring SRST Fallback Support
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmesrst.html
Cheers,
Martin
Rajesh Revuru
Level 4
Level 4
Hello:
You would need the following basic commands to enable SRST. However please following the recommended guide to design according to your environment
http://www.cisco.com/en/US/docs/voice_ip_comm/cusrst/admin/srst/configuration/guide/srst41/srst41sa.html
call-manager-fallback
ip source-address x.x.x.x port 2000
max-ephones x
max-dn x
That was just exactly what i did - but it didn't work. The reason was in SRST reference on CUCM - there should be IP addess of CME router. now it's working.In the list of Call Managers in the phone config SRST CCM is my CME router.
