Is there any way in Callmanager (6.1) to provide email notification of 911 calls without having Cisco Emergency Responder. Is this possible?
I received an error stating the the WebKnight Application firewall prevented me from viewing a CDR Report. I recently upgraded the OS from 2000.2.7 to 2000.4.5sr5b. Any ideas
Hi everyone,I'm dealing with an installation of CCME 4.1 and I'd like to know what the best approach would be for a particular need:The secretary has a 7965G+7914 addon module to allow her to monitor the necessary extensions. Because the CCME system ...
Thanks to previous posts I was able to figure out how to provide Caller Info before message playback, however I would like to automate it. We're using Unity 4.2(1). My clients wanted to hear the CallerID info before the message was played. In Unity A...
I'm trying to deploy a small CME setup in the Netherlands. I built a 2851 with a pair of 2BRI-NT/TE interfaces in the lab in the UK, and everything tested out just fine using some British Telecom ISDN2 lines. I've moved the kit to the Netherlands, an...
If you all would, I would appreciate your opinions as to if I should configure a new VG224 as SCCP or MGCP (for UCM6.1). We will have analog phones, faxes and modems but do not require supplementary services. Only dialtone, fax and modem passthroug...
What ports need to be opened on a firewall to allow a SCCP phone to connect to its Call Manager? I plan to allow only know static public IPs to connect to my Call Manager. I realize that SCCP isn't encrypted but aside from that, are there any know e...
I have a 4.1(3) system on which I am attempting to backup the MLA DB. MLA is version "MultiLevelAdmin.dll 1.0.0.1". I am getting error messages when the "c:\ciscowebs\MLA\install\backup.bat" batch job executes the step for "isql"C:\CiscoWebs\MLA\in...
Hi,Has anyone used VG200 with UCM 6.1 and can confirm if its supported.I have seen the Admin Guide for UCM 6.1, which states the step to add MGCP gateways and mentions "From the Gateway Type drop-down list box, choose one of the following MGCP gatewa...
Hi All, I am using CCM version 5.x . We have got PSTN gateway 2851 router on which PRI is terminated for making outgoing & receiving incoming calls from PSTN world.The problem which I am facing is that number being displayed at receiver end is 460XX...
We have UC 2.0.1 and we want to permanently delete voice mails and not have them sent to a deleted folder since this keeps filling up users VM accounts.
I have a CM 6.1.1 and like to know how to syncronize this two so that I can get a report?Thanks,EA
hi,i dunno what did happen, but i'm not able to change my 3911 phone configuration, i got password error, even when i used the default password which is "cisco".is there anyway to do a "hard reset" to reset the password (note that it is not registeri...
I just went through the 3rd unsuccessful attempt to migrate a cluster from ccm 4.2.3. Attempts number 2 and 3 were reasonably successful, but since the customer uses 3rd party software relying on TAPI for the operator and cti, a less than 100% workin...
Hi,I want to configure COR on a ISR router. I was hoping to block some phones to only allow them to dial internal phones only and possibly local calls.I have been using http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example0918...
Subject | Author | Posted |
04-29-2025 02:30 AM | ||
04-28-2025 05:35 AM | ||
04-26-2025 05:48 AM | ||
04-24-2025 02:49 PM | ||
04-15-2025 02:12 PM |
User | Count |
3 | |
2 | |
1 | |
1 | |
1 |
