Need help getting drop-through B-ACD working
cmonks
I'm having trouble getting a B-ACD script setup.
Calling the pilot number (1299) generates a fast busy signal.
The application script debug shows no output, like the call isnt even starting the script.
Heres the config so far:
application
service csqueue flash:app-b-acd-2.1.2.2.tcl
param aa-hunt1 1200
param number-of-hunt-grps 1
param queue-manager-debugs 1
param queue-len 15
service csaa flash:app-b-acd-aa-2.1.2.2.tcl
param handoff-string csaa
paramspace english index 1
param max-time-vm-retry 2
paramspace english language en
param aa-pilot 1299
param drop-through-prompt _bacd_welcome.au
param second-greeting-time 60
param welcome-prompt _bacd_welcome.au
paramspace english location flash:
param call-retry-timer 15
param voice-mail 1800
param max-time-call-retry 700
param service-name csqueue
paramspace english prefix en
param drop-through-option 1
dial-peer voice 2299 voip
service csaa
destination-pattern 1299
session protocol sipv2
session target ipv4:10.1.10.1
incoming called-number 1299
dtmf-relay h245-signal h245-alphanumeric
codec g711ulaw
Only other thing I can think of is the session target IP address.
Is this the correct IP?
The IP to send this to is the interface service-enginge
service-module ip default-gateway
8 Replies 8
Rick Morris
Level 6
Level 6
Here is our config that is working...maybe it will help you, but keep in mind our set up has 3 different queues
application
service cme-queue flash:app-b-acd-2.1.2.2.tcl
param aa-hunt1 890147
param number-of-hunt-grps 4
param aa-hunt2 890148
param aa-hunt3 890149
param queue-len 12
param aa-hunt4 890101
service cme-aa flash:app-b-acd-aa-2.1.2.2.tcl
param second-greeting-time 15
param voice-mail 7600
param handoff-string cme-aa
param max-time-call-retry 180
param aa-pilot 890141
param service-name cme-queue
dial-peer voice 3 voip
service cme-aa
destination-pattern 890141
session target ipv4:10.251.178.1
incoming called-number 890141
dtmf-relay h245-alphanumeric
codec g711ulaw
ephone-hunt 1 longest-idle
pilot 890147
list 890151, 890163, 890189, 890195
timeout 15, 15, 15, 15
statistics collect
display-logout All Agents Logged Out
ephone-hunt 2 longest-idle
pilot 890148
list 890125, 890157, 890171, 890175
statistics collect
ephone-hunt 3 longest-idle
pilot 890149
list 890161, 890165, 890167, 890169
statistics collect
Maybe something in here will help.
I can't find anything wrong, unless there is something else in the system stopping it.
application
param aa-hunt1 1200
param queue-len 15
service load csaa
param aa-pilot 1299
description **Cust Svc Call Queue**
service csaa
codec g711ulaw
ephone-hunt 10 peer
pilot 1200
list 1201, 1202
final 1801
timeout 12, 12
statistics collect
auto logout 1
description ** Cust Svc Hunt Group**
I would assume the IP is fine, my other voip dialpeers work fine.
service module config:
interface Integrated-Service-Engine0/0
description cue is initialized with default IMAP group
ip unnumbered Loopback0
ip nat inside
ip virtual-reassembly
service-module ip address 10.1.10.1 255.255.255.252
service-module ip default-gateway 10.1.10.2
I've also taken out the 'session protocol sipv2' and cleaned up the DTMF settings to match other's configs
I have had the same issue. Try this
sho call app voi sum
Check to see if the script has loaded or is still in the state of "loading...". My shows that it is in the loading state. As shown below:
SERVICES (standalone applications):
name type description
queuename (BLANK SPACE) builtin:app_b_acd_script.tcl Loading...
aaname (BLANK SPACE) builtin:app_b_acd_script.tcl Loading...
Also try this
debug voice app script
Don't for get to turn on "term mon" if you are on vty. Look for the following message:
000214: Jul 3 19:10:55.942: %CALL_CONTROL-6-APP_NOT_FOUND: Application aa in dial-peer XXXX not found. Handing callid 74 to the alternate app .
where XXXX is your dial-peer number.
As I can see this is because the script has not loaded. So TCL sends it to alternate app which you can see by typing
sho call app ses
The call must still be connected and you will see:
Session ID XX
App: Default
Type: Service
Url: builtin:Session_Service.C
Where XX is a number.
Does anyone know why a script would not load?
Is it the IOS version? Current IOS is:
c2800nm-advipservicesk9-mz.124-15.T1.bin
With this many bytes of memory 509952K/14336K
Can't believe it would be memory.
I have tried this with both flash b-acd and builtin as well with the same results.
Based on this it seems that you are sending it to CUE (10.1.10.1) it should be point to your loopback interface (10.1.10.2?)
service csaa
codec g711ulaw
ip nat inside
Thanks engage and rimon, your suggestions have solved my issue. I was using the IP of the CUE system instead of the CME system. I set the IP to 10.1.1.1, which is the IP of CME on the UC520, and it worked like a charm. I assume the 10.1.10.2 address would work too, but Cisco TAC had me use 10.1.1.1
