Need help with sip-header Diversion between CME and SIP trunk
Chrysostomos_CY
Level 5
Level 5
We have  CME connected with ISP via sip trunk
We are experiencing two issues
1) with call forwarding
2) with the snr
It seems that the from in the sip header is the originating A number which is not be recognized by the ISP  which is expecting any did from the sip trunk and not any other number in the FROM header
So we need to modify the sip-header Diversion and here i need you help
DID Range: 25558050- 25558059
Pilot: 25558050 (is the number which registered with the sip trunk)
A number: 22551256
B number: 25558051
25558051 is forwarded to  99445555
I see that we sent invite to ISP but in the FROM we have 22551256 which the ISP not recognized this number/
We have to change it to sip trunk DIDs .ALSO i dont see to send 180 ringing butr we are send directly 183..Pls advice
INVITE sip:99445555@bbtb.cyta.com.cy:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.10.4:5060;branch=z9hG4bK8D2054
From: <sip:22551256@bbtb.cyta.com.cy>;tag=6BBEB8-B17
To: <sip:99445555@bbtb.cyta.com.cy>
Trace:
000383: May 15 11:45:43.723: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:25558051@192.168.10.4:5060 SIP/2.0
Max-Forwards: 8
Via: SIP/2.0/UDP 10.224.42.132:5060;branch=z9hG4bK7mjzv5772gs6mkzvq2tcfm9v5
To: "25558051 25558051" <sip:25558051@bbtb.cyta.com.cy>;cscf
From: <sip:22551256@fmc.cyta.com.cy;user=phone>;tag=h7g4Esbg_1681470739-1368618399853-
Call-ID: BW1446398531505131781641981@10.224.50.81
CSeq: 335658039 INVITE
Contact: <sip:sgc_c@10.224.42.132;transport=udp>
Record-Route: <sip:10.224.42.132;transport=udp;lr>
Min-Se: 600
P-Asserted-Identity: <sip:22551256@fmc.cyta.com.cy;user=phone>
P-Called-Party-ID: <sip:25558050@bbtb.cyta.com.cy>
Privacy: none
Session-Expires: 1800
Content-Type: application/sdp
Content-Length: 491
Allow: ACK, BYE, CANCEL, INVITE, OPTIONS, PRACK, REFER, NOTIFY, INFO, UPDATE
Accept: application/media_control+xml
Accept: application/sdp
Accept: application/x-broadworks-call-center+xml
Accept: multipart/mixed
v=0
o=BroadWorks 140580428 1 IN IP4 10.224.42.132
s=-
c=IN IP4 10.224.42.6
t=0 0
m=audio 29920 RTP/AVP 18 8 100
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=yes
a=rtpmap:8 PCMA/8000
a=rtpmap:100 telephone-event/8000
a=fmtp:100 0-15
a=sqn: 0
a=cdsc: 1 audio RTP/AVP 18 8 100
a=cpar: a=rtpmap:18 G729/8000
a=cpar: a=fmtp:18 annexb=yes
a=cpar: a=rtpmap:8 PCMA/8000
a=cpar: a=rtpmap:100 telephone-event/8000
a=cpar: a=fmtp:100 0-15
a=cdsc: 4 image udptl t38
a=sendrecv
a=ptime:20
000384: May 15 11:45:43.735: //224/CF32F22D8173/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Wed, 15 May 2013 11:45:43 GMT
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
000385: May 15 11:45:43.735: //224/CF32F22D8173/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
To: "25558051 25558051" <sip:25558051@bbtb.cyta.com.cy>;cscf;tag=6BAB34-2590
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Contact: <sip:25558051@192.168.10.4:5060>
Content-Length: 0
000386: May 15 11:45:48.731: //226/CF32F22D8173/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Wed, 15 May 2013 11:45:48 GMT
Call-ID: D22E7ED5-BC8B11E2-817AF6C2-2862DEAD@192.168.88.14
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE: 1800
Cisco-Guid: 3476222509-3163230690-2171860674-0677568173
User-Agent: Cisco-SIPGateway/IOS-12.x
CSeq: 101 INVITE
Timestamp: 1368618348
Contact: <sip:22551256@192.168.10.4:5060>
Expires: 60
Max-Forwards: 7
Content-Disposition: session;handling=required
Content-Length: 247
v=0
o=CiscoSystemsSIP-GW-UserAgent 3903 9766 IN IP4 192.168.10.4
s=SIP Call
c=IN IP4 192.168.10.4
t=0 0
m=audio 18256 RTP/AVP 8 101
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=ptime:20
000387: May 15 11:45:48.835: //226/CF32F22D8173/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 183 Session Progress
Via: SIP/2.0/UDP 192.168.10.4:5060;received=10.228.67.248;branch=z9hG4bK8D2054
To: <sip:99445555@bbtb.cyta.com.cy>;tag=h7g4Esbg_2119287777-1368618404992
CSeq: 101 INVITE
P-Asserted-Identity: <sip:99445555@bbtb.cyta.com.cy;user=phone>
Privacy: none
Content-Length: 223
Session: Media
P-Early-Media: sendonly
Allow: ACK, BYE, CANCEL, INVITE, OPTIONS, PRACK, REFER, NOTIFY, UPDATE, INFO
v=0
o=BroadWorks 140580512 1 IN IP4 10.224.42.132
s=-
c=IN IP4 10.224.42.7
t=0 0
m=audio 58606 RTP/AVP 8 101
a=fmtp:101 0-15
a=ptime:20
Please rate all useful posts
Chrysostomos
Please rate all useful posts Regards Chrysostomos ""The Most Successful People Are Those Who Are Good At Plan B""
13 Replies 13
Ayodeji Okanlawon
Chrys,
This is a bit difficult..The second invite does not use a diversion header..rather it uses a From header. We can only change the From header if your normal calls use a different header for CLI
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Chrysostomos_CY
Level 5
Level 5
Hi mate
what is your suggestion here. What is the solution? We have to find something :)
Can you do a test call outbound call for normal calls..I want to see if you PAI (P-asserted-identity) or remote party id--If you do then we can configure sip profiles to change the FROM to use a valid DDI
Jorge Armijo
Level 4
Level 4
Hi All,
What I can see is a second INVITE from CME to ITSP, with the Originator CLID, so the ITSP will reject the call if they don't know the number.
Please try:
telephony-service
calling-number local
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/command/reference/cme_c1ht.html#wp1012060
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
i have add the above command and the call now its coming to the mobile.But we dont have audio.The CME connected directly to the  ISP modem .Maybe they have enable NAT and this create the no two way audio/??
From the previous trace I can see that you are telling your ITSP to send media on ip:192.168.10.4..Can they connect to you on this IP address?
aok
they give us a modem for the sip trunk.We have enabled dhcp @ the interface connected to modem ISP.The GW of their modem is 192.168.10.254 and our ip is 192.168.10.4/
So they use NAT right?
I am not sure but most likely. You might want to speak to them and clarify things
I have asked them to disable the nat.Now we have a different ip without nating
Now when i have a normal call everything looks fine
When i use SNR or call forward then  call reach the destination number with SNR or with CF BUT we dont have audio
Pls check attached trace for normal call and call forward call
Aok
Did you have a time to check the traces?
As i wrote the call to th callforward reach the destination number but we dont have audio
Chrysostomos
HRS
Do you have a solution for this issue. We are facing the same issue, Able to make inbound and outbound call but Call Forward / SNR has NO WAY AUDIO issue.
~ HRS
This post is three years old, it may be best starting a new discussion with debugs and configs from your own CUBE.
The resolution may be completely different.
Rob
Call Forward started working after I enabled Media Flow-Around under Voice Service Voip.
Hari
