02-02-2016 06:08 AM - edited 03-17-2019 05:42 AM
Guys,
I have cube which is connected to itsp and cucm 9.1. Both are on sip trunk and everything is working however i cannot hear audio for some international calls. Stream is dead and counter on ip phone increases which means that the call is connected. As per the debugs i checked that Cube is negotiating for g711alaw and it's sending 101 for RTP payload but i cannot see anything from ITSP regarding the rtp payload. Any idea regarding the said problem ?
Support will be highly appreciated.
02-03-2016 09:08 AM
did you use ALG SIP Inspection Firewall? Please take a look into if you're using.
thanks,
Stefan
02-05-2016 01:40 AM
No. I didn't use ALG Sip Inspection Firewall
02-05-2016 01:48 AM
hi,
debug ccsip messages, make a test call and attach the same.
-Kevin
