Showing results forĀ
Search instead forĀ
Did you mean:Ā
No dial tone for PSTN calls
V.Naveen Kumar
Need some help. I am not able hear dial tone when phone is in off hook but calls are  able to connect.
Call Manager version : 8.6
Cisco IP Phone : 6945
I have checked cluster wide parameter : disable altering process indicator is false only.
I have checked in route pattern also provide outside dialtone is enabled.
I have checked in gateway also there is no issue in conf.
help me out..!!!
- is it happening for only one phone?
- is it happening only for PSTN calls or internal too?
- when the receiver is offhook and if it still receives the calls from other phones, it could be issue with hook-switch not releasing properly.
- when the phone goes off hook, it will notify the cucm and the cucm will provide the dial-tone to the phone.
- so pls check the ccm traces as well on what exactly happening between cucm and phone.
~ SS
//Suresh Please rate all the useful posts.
its happening for all IP phone in cluster
both internal n PSTN
i tried with speaker as well as i checked with handset also.
in traces its shows it giving dial tone to the call but still i m not able to get dial tone.
hi Naveen,
So there is no dial tone for internal calls also.. correct?
what firmware is the 6945 phone running ?? Can you upgrade the firmware?
Karthik
hi
its already upgraded firmware..
SCCP 6945 9.3.1.3 version
