09-18-2014 01:52 PM - edited 03-17-2019 12:13 AM
I've run into an issue where callers coming from the PSTN do not hear ringback after being transferred using a Cisco Unity call handler.
Ringback works internally between phones, and also works internally if I dial the call handler DN and request a transfer.
Call flow is this: SIP Provider -> CUBE -> SIP Trunk -> CUCM -> Unity Connection (SCCP)
The caller just hears dead air until the phone is picked up, or it bounces to voicemail.
There is an MRGL assigned to the SIP trunk to CUBE that contains an announciator and MoH.
The weird thing is the caller does hear about a second of MoH when Unity begins the transfer, but nothing after that.
debug ccsip messages:
1111111111 is the called party/number, 2222222222 is the calling number (my cellphone)
000925: Sep 18 14:08:06.696 MST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:1111111111@184.71.242.2:5060 SIP/2.0
Via: SIP/2.0/UDP 208.43.85.75:5060;branch=z9hG4bK27e0cc04;rport
From: "2222222222" <sip:2222222222@208.43.85.75>;tag=as2bec68a8
To: <sip:1111111111@184.71.242.2:5060>
Contact: <sip:2222222222@208.43.85.75>
Call-ID: 264119bc6be819f81634da4a67543569@208.43.85.75
CSeq: 102 INVITE
User-Agent: Asterisk PBX
Max-Forwards: 70
Remote-Party-ID: "2222222222" <sip:2222222222@208.43.85.75>;privacy=off;screen=no
Date: Thu, 18 Sep 2014 20:08:06 GMT
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY
Supported: replaces
Content-Type: application/sdp
Content-Length: 361
v=0
o=root 1022 1022 IN IP4 208.43.85.75
s=session
c=IN IP4 208.43.85.75
b=CT:384
t=0 0
m=audio 11300 RTP/AVP 0 8 101
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=silenceSupp:off - - - -
a=ptime:20
a=sendrecv
m=video 14308 RTP/AVP 34 99
a=rtpmap:34 H263/90000
a=rtpmap:99 H264/90000
a=sendrecv
000926: Sep 18 14:08:06.708 MST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:700@10.135.191.12:5061 SIP/2.0
Via: SIP/2.0/TLS 172.18.0.1:5061;branch=z9hG4bK40E577
Remote-Party-ID: "2222222222" <sip:2222222222@172.18.0.1>;party=calling;screen=no;privacy=off
From: "2222222222" <sip:2222222222@sip1.ixica.com>;tag=1D82524-20B8
To: <sip:700@10.135.191.12>
Call-ID: 56A4B001-3EA611E4-8227D749-31CC0927@172.18.0.1
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE: 1800
Cisco-Guid: 1453513609-1051070948-2183255881-0835455271
User-Agent: Cisco-SIPGateway/IOS-15.2.4.M6a
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1411070886
Contact: <sip:2222222222@172.18.0.1:5061;transport=tls>
Expires: 180
Allow-Events: telephone-event
Max-Forwards: 69
Content-Disposition: session;handling=required
Content-Length: 394
v=0
o=CiscoSystemsSIP-GW-UserAgent 6324 6685 IN IP4 172.18.0.1
s=SIP Call
c=IN IP4 172.18.0.1
t=0 0
m=audio 16420 RTP/AVP 0 101
c=IN IP4 172.18.0.1
a=fmtp:101 0-16
a=ptime:20
m=video 16422 RTP/AVP 34 119
c=IN IP4 172.18.0.1
a=fmtp:34 CIF=1
a=rtpmap:119 H264/90000
a=fmtp:119 profile-level-id=000000
000927: Sep 18 14:08:06.712 MST: //1040/56A2DB898221/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 102 INVITE
Server: Cisco-SIPGateway/IOS-15.2.4.M6a
Content-Length: 0
000928: Sep 18 14:08:06.716 MST: //1042/56A2DB898221/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Allow-Events: presence
Content-Length: 0
000929: Sep 18 14:08:06.728 MST: //1042/56A2DB898221/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <sip:700@10.135.191.12>;tag=6169~dc062259-9b0a-4df2-b05d-e4de329c1980-23733830
CSeq: 101 INVITE
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
Server: Cisco-CUCM10.5
Supported: X-cisco-srtp-fallback
Supported: Geolocation
P-Asserted-Identity: "Cisco Unity" <sip:800@10.135.191.12>
Remote-Party-ID: "Cisco Unity" <sip:800@10.135.191.12>;party=called;screen=yes;privacy=off
Contact: <sip:700@10.135.191.12:5061;transport=tls>
Content-Length: 0
000930: Sep 18 14:08:06.732 MST: //1040/56A2DB898221/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
To: <sip:1111111111@184.71.242.2:5060>;tag=1D82538-D9C
CSeq: 102 INVITE
Remote-Party-ID: "Cisco Unity" <sip:800@184.71.242.2>;party=called;screen=yes;privacy=off
Contact: <sip:700@184.71.242.2:5060>
Content-Length: 0
000931: Sep 18 14:08:06.804 MST: //1042/56A2DB898221/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Allow-Events: presence, kpml
Supported: replaces
Session-Expires: 1800;refresher=uas
Require: timer
Contact: <sip:700@10.135.191.12:5061;transport=tls>;isFocus
Content-Length: 406
v=0
o=CiscoSystemsCCM-SIP 6169 1 IN IP4 10.135.191.12
s=SIP Call
c=IN IP4 10.135.191.12
b=TIAS:64000
b=CT:64
b=AS:64
t=0 0
m=audio 25280 RTP/AVP 0 101
a=ptime:20
a=fmtp:101 0-15
m=video 0 RTP/AVP 31 34 96 97
a=rtpmap:31 H261/90000
a=rtpmap:96 H263-1998/90000
a=rtpmap:97 H264/90000
a=content:main
a=inactive
000932: Sep 18 14:08:06.808 MST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:700@10.135.191.12:5061;transport=tls SIP/2.0
Via: SIP/2.0/TLS 172.18.0.1:5061;branch=z9hG4bK40F1BB8
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
000933: Sep 18 14:08:06.812 MST: //1040/56A2DB898221/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 102 INVITE
Contact: <sip:1111111111@184.71.242.2:5060>
Supported: replaces
Supported: sdp-anat
Supported: timer
Content-Length: 292
v=0
o=CiscoSystemsSIP-GW-UserAgent 4672 7011 IN IP4 184.71.242.2
s=SIP Call
c=IN IP4 184.71.242.2
t=0 0
m=audio 16416 RTP/AVP 0 101
a=fmtp:101 0-16
a=ptime:20
m=video 0 RTP/AVP 34
000934: Sep 18 14:08:06.896 MST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:1111111111@184.71.242.2:5060 SIP/2.0
Via: SIP/2.0/UDP 208.43.85.75:5060;branch=z9hG4bK243fd8d0;rport
CSeq: 102 ACK
Max-Forwards: 70
Content-Length: 0
000935: Sep 18 14:08:17.351 MST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
UPDATE sip:2222222222@172.18.0.1:5061;transport=tls SIP/2.0
Via: SIP/2.0/TLS 10.135.191.12:5061;branch=z9hG4bK8347ed20ac
From: <sip:700@10.135.191.12>;tag=6169~dc062259-9b0a-4df2-b05d-e4de329c1980-23733830
To: "2222222222" <sip:2222222222@sip1.ixica.com>;tag=1D82524-20B8
Date: Thu, 18 Sep 2014 20:08:07 GMT
User-Agent: Cisco-CUCM10.5
Max-Forwards: 70
Supported: timer,resource-priority,replaces
CSeq: 101 UPDATE
Call-Info: <urn:x-cisco-remotecc:callinfo>;x-cisco-video-traffic-class=VIDEO_UNSPECIFIED
Session-Expires: 1800;refresher=uac
Min-SE: 1800
P-Asserted-Identity: "Anthony" <sip:270@10.135.191.12>
Remote-Party-ID: "Anthony" <sip:270@10.135.191.12>;party=calling;screen=yes;privacy=off
Content-Length: 0
000936: Sep 18 14:08:17.351 MST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Thu, 18 Sep 2014 20:08:17 GMT
CSeq: 101 UPDATE
Contact: <sip:270@172.18.0.1:5061;transport=tls>
Require: timer
Supported: timer
Content-Length: 0
000937: Sep 18 14:08:22.894 MST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:1111111111@184.71.242.2:5060 SIP/2.0
Via: SIP/2.0/UDP 208.43.85.75:5060;branch=z9hG4bK7d5b6278;rport
CSeq: 103 BYE
Max-Forwards: 70
Content-Length: 0
000938: Sep 18 14:08:22.898 MST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Thu, 18 Sep 2014 20:08:22 GMT
CSeq: 103 BYE
Reason: Q.850;cause=16
P-RTP-Stat: PS=804,OS=128640,PR=693,OR=98712,PL=0,JI=0,LA=0,DU=16
Content-Length: 0
000939: Sep 18 14:08:22.898 MST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:700@10.135.191.12:5061;transport=tls SIP/2.0
Via: SIP/2.0/TLS 172.18.0.1:5061;branch=z9hG4bK4102F8
Max-Forwards: 70
Timestamp: 1411070902
CSeq: 102 BYE
P-RTP-Stat: PS=693,OS=98712,PR=804,OR=128640,PL=0,JI=0,LA=0,DU=16
Content-Length: 0
000940: Sep 18 14:08:22.902 MST: //1042/56A2DB898221/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Date: Thu, 18 Sep 2014 20:08:23 GMT
CSeq: 102 BYE
Content-Length: 0
CUBE Dialpeers and voice config:
voice service voip
ip address trusted list
mode border-element
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
registrar server expires max 1200 min 300
rel1xx disable
midcall-signaling passthru
g729 annexb-all
dial-peer voice 1000 voip
description *** Outbound CUCM ***
destination-pattern ...
session protocol sipv2
session target ipv4:XXXXXX
session transport tcp tls
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 2000 voip
description *** Inbound CUCM ***
incoming called-number ...
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 101 voip
description *** Incoming Dial-Peer ***
translation-profile incoming INCOMING1
session target sip-server
incoming called-number 1111111111
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 1 voip
description *** Outbound Dial-Peer ***
translation-profile outgoing Strip9
destination-pattern 9.+
dtmf-relay rtp-nte
codec g711ulaw
no vad
10-25-2014 02:27 AM
In addition to my email, I can see that unity connection is sending inactive SDP during the transfer, but CUCM doesn't send inactive SDP to CUBE. Lets work this out with TAC and hopefully we can resolve this without MTP
12-19-2014 01:11 PM
Hi guys did you get any real resolution with TAC regarding the no ringback issue. I have a similar issue with CUC sending SDP with inactive back to an SME and the SME sends the SDP with inactive back to the originating cluster. Not sure what else to look for at this point but all my locales are setup to none. Just fyi.
Wilson
12-26-2014 06:20 AM
Hi Wilson,
From what I recall this was never directly addressed by TAC because it turned out there were other issues with both the ITSP and locales, I remember it being brought up on the TAC call but I don't think I ever heard an answer as to why this was happening/what this effected.
Anthony
10-24-2014 11:02 AM
Did you do enable early offer support on your sip profile?
"Need early offer to check the above parameter : You may use "Early Offer support for voice and video calls (insert MTP if needed)" in the SIP Profile. "
07-18-2017 06:16 AM
This is a late response but hopefully may help others looking for a possible solution...
In CUCM, look for service parameter "Duplex Streaming Enabled" - set to true
Jon
07-31-2017 12:52 PM
Hi Jon,
I am going to try this tonight, we are facing this issue and hope this resolves it. Do I need to restart anything ?
07-31-2017 02:57 PM
nothing to restart.
jon
07-31-2017 04:58 PM
Jon,
I just tried this, I am not getting ringback unfortunately. I Dont think I am missing anything, is there any other step in between ?
08-01-2017 12:01 AM
I suggest that you open a new thread. This an old thread and duplex streaming doesnt control ring back, please ignore that advice..
Open a new thread and explain your call flow, then describe the issues in detail. Does ring back fail on all calls? Does it fail on transfer?etc
08-29-2019 01:34 AM
Hi All,
Something that I found that works is to change the Duplex Streaming Enabled to True under the CallManager Service Parameter, after this change ringback works when transfering from Unity
