06-08-2009 12:30 AM - edited 03-15-2019 06:23 PM
can we register nortel 1120 e phone in callmanager using sip
Voice experts plz reply
06-08-2009 02:34 AM
You can add any third party SIP phones if you can put some settings there.
Check this document: http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/6_0_1/ccmcfg/b09sip3p.html
06-08-2009 03:06 AM
this doc i have seen
My question is specific
can nortel 1120 e model-ntys03 come with factory settings can register in callmanager....
means do we need to upload sipload or something
Those who installion exp of nortl phones,plz reply
06-08-2009 11:57 AM
There is SIP firmware available for 1120E and 1140E phones. You need to get it from a Nortel reseller though. How many phones do you need to configure?
06-08-2009 12:01 PM
i have that firmware and uploaded
But there is no option to add username and password in the nortel phone...
I am now inst in a lab after that to do 100 phones
NY ONE PLEASE HELP....
06-08-2009 12:15 PM
You can set user and password through the phone (services > system), but I would really suggest reading about the config files and using tftp. that will be much easier for 100 phones.
06-08-2009 12:17 PM
but there is no menu called system
06-08-2009 12:26 PM
06-08-2009 12:30 PM
can you send me the config file u r using and how u uploaded...??
Thanks for helping..
06-08-2009 12:53 PM
06-08-2009 01:04 PM
i already having this file and using this only I updated the sipload of the nortel phone
But still I cant able to register this phone on cisco callmanager
U already done it right?
Please help me...
06-08-2009 01:08 PM
Not with CM. I did with a Zultys. I don't know CM at all.. There is an example of the file on p.37. One thing to note about these phones is I never could get voice mail light to work..
06-08-2009 01:17 PM
I WOUL LIKE TO KNOW IS THIS PHONE WORKS WITH CISCO CM
THANKS 4 UR HELP
CISCO EXPERTS WITH NORTEL EXP..PLZ REPLY
05-12-2011 09:02 AM
Hi I just recently did get a 1120e phone to register on my
Call Manager
After you have put the SIP firmware on the 1120e set, be careful becasue some Nortel sets are not compatible with the latest SIP firmware you might download. I tested with SIP versions 2 and 3 both work.
For simplicity in Call Manager I made the user name numeric and the same as the extension number
Now the stumbling block for me is when you power up the Nortel set with the SIP firmware it comes by default of a domain of Nortel.com. You need to edit that and make it the same as any value you might have in the Enterprise Paramters in the Organization Top Level Domain box.
The set will then register,
10-13-2011 01:34 PM
Do you have your config file users.dat that you used for the Nortel phone handy? I am running into the same weird issue here...
