Not able to communicate with remote IP phones
SwathyEdayath
Dear Team,
We have one remote site with three phones connected via VPN from main site. the phones are having same configuration as in main site .
we are able to make outgoing calls from these phones both internal and PSTN . but we are unable to reach these phones dialing extension and direct line as well . even the phones are not mutually reachable . please suggest .
swathy
25 Replies 25
Dennis Mink
what do you mean by "not reaching"  you mean when you call them from within your organisation they ring, but no voice?
remember RTP is point to point, so make sure you can route to your VPN subnet from any voice subnet in your organisation that needs to call these phones
Please remember to rate useful posts, by clicking on the stars below.
No. The phones don't even ring . Its like they are not even configured .
HARIS_HUSSAIN
Please Clarify below say Ph-Br== Branch PHones, Ph-HQ- Head Office Phoens
1) Ph-Br-A can call Ph-Br-B :- Call Works ?
2) Ph-HQ-C can Call Ph-Br-A or B :- Call Works ?
3) Ph-Br-A calls Ph-HQ-C :- Call WOrks ?
Are the Phone shown as registered in CUCM ?
Haris
1) No
2) No
3) yes , only when I force to call . automatic dialing doesn't work .
phones are registered in cucm.
Do a DNA form CUCM for remote phone scenario 1,2 and 3 Above and attache output here.
For DNA go to CUCM Serviceability Page (<CCMIP/ccmservice> ) and Tools Dialled Number Analyser.
Search for respective phone and do analysis for above scenario, paste output here.
You might have some partition,CSS issue.
Haris
but its not a css/partition issue . since we have the same configuration as in main branch . pfa. both are in same partition.
Please collect the CDR Log for the respective call and CUCM SDL Logs for the duration.
What do you mean by
Hi Haris,
Kindly find attachments . when I simply dial extensions, call not going .
but after complete dialing when I press " call ", its going .
below are the phones details .
94D469AEA49C_610 : remote location : called phone
00B0E115F29C_611 : remote location : called phone
00562B62D63F_143 : calling phone ( main location )
CUCM Is sending 503 Response
3081560.003 |12:05:07.713 |AppInfo |//SIP/SIPHandler/ccbId=0/scbId=0/sip_stop_timer: timerContext=0xe7d9256c type=SIP_TIMER_EXPIRES value=180000 retries=0
93081560.004 |12:05:07.713 |AppInfo |//SIP/Stack/Info/0x0xe7d91568/sipSPIUaddCcbToTable: Added to table. ccb=0xe7d91568 key=00562b62-d63f0058-192e738c-2efad675@192.168.7.589835954~33DE5FCD-860F-73CA-F6F9-12E60625B9AA-50213073
93081560.005 |12:05:07.713 |AppInfo |//SIP/Stack/Info/0x0xe7d91568/sipSPISendInviteResponse: Associated container=0xe3786f58 to Invite Response 503
93081560.006 |12:05:07.713 |AppInfo |//SIP/Stack/Transport/0x0xe7d91568/sipSPITransportSendMessage: msg=0xe586e0d0, addr=192.168.7.58, port=51272, sentBy_port=51272, is_req=0, tran
93081560.007 |12:05:07.713 |AppInfo |//SIP/Stack/Transport/0x0/sipInstanceGetConnectionId: gcb=0xe7d91568 is already on connection=0xe594dd10 context_list
93081560.008 |12:05:07.713 |AppInfo |//SIP/Stack/Transport/0x0xe7d91568/sipTransportLogicSendMsg: Connection obtained...sending msg=0xe586e0d0
93081560.009 |12:05:07.713 |AppInfo |//SIP/Stack/Transport/0x0xe7d91568/sipTransportPostSendMessage: Posting send for msg=0xe586e0d0, addr=192.168.7.58, port=51272, connId=66708 for
93081560.010 |12:05:07.713 |AppInfo |//SIP/Stack/Info/0x0xe7d91568/sentErrResDisconnecting: Sent an 3456XX Error Response
93081560.011 |12:05:07.713 |AppInfo |//SIP/Stack/States/0x0xe7d91568/sipSPIChangeState: 0xe7d91568 : State change from (STATE_RECD_INVITE, SUBSTATE_NONE) to (STATE_DISCONNECTING, SUBSTATE_NONE)
93081560.012 |12:05:07.713 |AppInfo |//SIP/SIPHandler/ccbId=0/scbId=0/sip_stop_timer: timerContext=0xe7d92548 type=SIP_TIMER_CONNECT value=500 retries=6
93081560.013 |12:05:07.713 |AppInfo |//SIP/SIPHandler/ccbId=0/scbId=0/sip_start_timer: timerContext=0xe7d92548 type=SIP_TIMER_CONNECT value=500 retries=6
93081561.000 |12:05:07.713 |SdlSig |SIPSPISignal |wait |SIPTcp(2,100,72,1) |SIPHandler(2,100,80,1) |2,100,13,76604.1^*^* |*TraceFlagOverrode
93081561.001 |12:05:07.713 |AppInfo |SIPTcp - wait_SdlSPISignal: Outgoing SIP TCP message to 192.168.7.58 on port 51272 index 66708
[28869712,NET]
SIP/2.0 503 Service Unavailable
Via: SIP/2.0/TCP 192.168.7.58:51272;branch=z9hG4bK04964c25
From: "Swathy" <sip:143@192.168.1.51>;tag=00562b62d63f0c5c63893367-07f5d65c
To: <sip:611@192.168.1.51>;tag=9835954~33de5fcd-860f-73ca-f6f9-12e60625b9aa-50213073
Date: Thu, 20 Apr 2017 08:05:07 GMT
Call-ID: 00562b62-d63f0058-192e738c-2efad675@192.168.7.58
CSeq: 101 INVITE
Allow-Events: presence
Server: Cisco-CUCM11.0
Session-ID: 00000000000000000000000000000000;remote=4141c04fe3ecd425827932caa9835954
Reason: Q.850; cause=41
Remote-Party-ID: <sip:611@192.168.1.51;user=phone>;party=x-cisco-original-called;privacy=off
Content-Length: 0
will that because of any firewall problem .
To verify if this is a firewall problem you should take a packet capture from IP phone and traces from CUCM for a test call to see if all the packets sourced from IP phone and CUCM make it to the other end successfully. If you can open all SIP and UDP traffic between this site and headquarter as a quick test then it can help as well to identify it quickly.
Manish
I checked the traces and reason of failure that your CUCM isn't able to establish TCP connection to your remote phone (610) at IP 172.21.20.3 port 5060.
See below traces (I  highlighted the important parts in red). You need to check your routing and access control rules
93080984.048 |12:04:53.867 |AppInfo  |//SIP/Stack/Transport/0x0/sipTransportSetConnWaitTimer:
Wait Conn Timer started for 5000 msec
93080984.049 |12:04:53.867 |AppInfo  |//SIP/SIPHandler/ccbId=0/scbId=0/sip_stop_timer: timerContext=0xe5ed4114 type=SIP_TIMER_WAIT_CONNECT value=5000 retries=0
93080984.050 |12:04:53.867 |AppInfo  |//SIP/SIPHandler/ccbId=0/scbId=0/sip_start_timer: timerContext=0xe5ed4114 type=SIP_TIMER_WAIT_CONNECT value=5000 retries=0
93080984.051 |12:04:53.867 |AppInfo  |//SIP/Stack/Transport/0x0/sipCreateConnInstance: Created new initiated conn=0xe5ed40c8, connid=-1, addr=172.21.20.3, port=53168, transport=
93080984.052 |12:04:53.867 |AppInfo  |//SIP/Stack/Transport/0x0/sipInstanceGetConnectionId: Registering gcb=0xe373e370 with connection=0xe5ed40c8
93080984.053 |12:04:53.867 |AppInfo  |//SIP/Stack/Transport/0x0xe373e370/sipSPITransportSendMessage: Deferred sending msg=0xe3e6ef88
93080985.000 |12:04:53.867 |SdlSig   |SIPProceedInd                          |wait                           |SIPStationD(2,100,74,12921)      |SIPHandler(2,100,80,1)           |2,100,14,1.179340^*^*                    |[R:N-H:0,N:1,L:0,V:0,Z:0,D:0]  CcbId= 9835937 --TransType=1 --TransSecurity=0 PeerAddr = 172.21.20.3:53168
93080986.000 |12:04:53.867 |SdlSig   |SIPSPISignal                           |wait                           |SIPTcp(2,100,72,1)               |SIPHandler(2,100,80,1)           |2,100,14,1.179340^*^*                    |*TraceFlagOverrode
93080986.001 |12:04:53.867 |AppInfo  |SIPTcp - SIPSPI_EV_CREATE_CONNECTION: Addr=172.21.20.3, Port=53168, globalTCPInst=0xeaac52f8
93080987.000 |12:04:53.867 |SdlSig   |SIPProceedInd                          |translate                      |SIPStationCdfc(2,100,75,139517)  |SIPStationD(2,100,74,12921)      |2,100,14,1.179340^*^*                    |[R:N-H:0,N:1,L:0,V:0,Z:0,D:0]  CcbId= 9835937 --TransType=1 --TransSecurity=0 PeerAddr = 172.21.20.3:53168
93080988.000 |12:04:53.867 |SdlSig   |SIPProceedInd                          |outCall_inviteSent             |SIPCdpc(2,100,83,98302)          |SIPStationCdfc(2,100,75,139517)  |2,100,14,1.179340^*^*                    |[R:N-H:0,N:0,L:0,V:0,Z:0,D:0]  CcbId= 9835937 --TransType=1 --TransSecurity=0 PeerAddr = 172.21.20.3:53168
93080988.001 |12:04:53.867 |AppInfo  |SIPCdpc(98302) - combineConfigTclWithTclSupport: orig config tcl is 1; combined tcl is 1
93080988.002 |12:04:53.867 |AppInfo  |SIPCdpc(98302) - getVideoTrafficClass: CCMTCL non-trunk using tcl=1
93080989.000 |12:04:53.867 |SdlSig   |CcProceedInd                           |restart0                       |LineControl(2,100,176,3601)      |SIPCdpc(2,100,83,98302)          |2,100,14,1.179340^*^*                    |[R:N-H:0,N:0,L:0,V:0,Z:0,D:0] CI=50213070 CI.branch=0  pi.piid=30 pi.l=0IpAddrMode=0 ipAddrType=0 ipv4=0.0.0.0:0 mediaQryF locPkid= locName= deductBW=F fateShareId= videoTrafficClass=DesktopTransparentData=null CanSupportSIPTandN=false TransId=0 AllowBitMask=0x0 UserAgentOrServer= OrigDDName=locale: 1 Name:  UnicodeName:  pi: 0 mCallerId= mCallerName=
93080990.000 |12:04:53.867 |SdlSig   |CcProceedInd                           |call_received7                 |LineCdpc(2,100,177,87654)        |LineControl(2,100,176,3601)      |2,100,14,1.179340^*^*                    |[R:N-H:0,N:0,L:0,V:0,Z:0,D:0] CI=50213070 CI.branch=0  pi.piid=30 pi.l=0IpAddrMode=0 ipAddrType=0 ipv4=0.0.0.0:0 mediaQryF locPkid= locName= deductBW=F fateShareId= videoTrafficClass=DesktopTransparentData=null CanSupportSIPTandN=false TransId=0 AllowBitMask=0x0 UserAgentOrServer= OrigDDName=locale: 1 Name:  UnicodeName:  pi: 0 mCallerId= mCallerName=
93080991.000 |12:04:53.867 |SdlSig   |CcProceedInd                           |wait                           |Cc(2,100,223,1)                  |LineCdpc(2,100,177,87654)        |2,100,14,1.179340^*^*                    |[R:N-H:0,N:0,L:0,V:0,Z:0,D:0] CI=50213070 CI.branch=0  pi.piid=30 pi.l=0IpAddrMode=0 ipAddrType=0 ipv4=0.0.0.0:0 mediaQryF locPkid= locName= deductBW=F fateShareId= videoTrafficClass=DesktopTransparentData=null CanSupportSIPTandN=false TransId=0 AllowBitMask=0x0 UserAgentOrServer= OrigDDName=locale: 1 Name:  UnicodeName:  pi: 0 mCallerId= mCallerName=
93080992.000 |12:04:53.867 |SdlSig   |CcProceedInd                           |tcc_incoming_call_proceeding4  |Cdcc(2,100,222,52516)            |Cc(2,100,223,1)                  |2,100,14,1.179340^*^*                    |[R:N-H:0,N:0,L:0,V:0,Z:0,D:0] CI=50213070 CI.branch=0  pi.piid=30 pi.l=0IpAddrMode=0 ipAddrType=0 ipv4=0.0.0.0:0 mediaQryF locPkid= locName= deductBW=F fateShareId= videoTrafficClass=DesktopTransparentData=null CanSupportSIPTandN=false TransId=0 AllowBitMask=0x0 UserAgentOrServer= OrigDDName=locale: 1 Name:  UnicodeName:  pi: 0 mCallerId= mCallerName=
93080993.000 |12:04:53.867 |SdlSig   |SdlConnectReq                          |started                        |SdlTCPService(2,100,11,1)        |SIPTcp(2,100,72,1)               |2,100,14,1.179340^*^*                    |*TraceFlagOverrode
93080993.001 |12:04:53.867 |Created  |                                       |                               |SdlTCPConnector(2,100,13,76603)  |SdlTCPService(2,100,11,1)        |                                         |NumOfCurrentInstances: 1
93080994.000 |12:04:53.868 |SdlSig   |SIPSPISignal                           |wait                           |SIPHandler(2,100,80,1)           |SIPTcp(2,100,72,1)               |2,100,14,1.179340^*^*                    |*TraceFlagOverrode
93080994.001 |12:04:53.868 |AppInfo  |//SIP/Stack/Info/0x0/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 (SIP_NETWORK_MSG), for event 59 (SIPSPI_EV_CONNECTION_CREATED)
93080994.002 |12:04:53.868 |AppInfo  |//SIP/Stack/Transport/0x0/sipConnectionManagerProcessConnCreated: gConnTab=0xeaac52f8, addr=172.21.20.3, port=53168, connid=74508, transport=TCP
93080994.003 |12:04:53.868 |AppInfo  |//SIP/Stack/Transport/0x0/sipInstanceHandleConnectionCreated: Moving connection=0xe5ed40c8, connid=74508state to pending
93080995.000 |12:04:53.874 |NetError |                                       |                               |SdlTCPConnector(2,100,13,76603)  |                                 |2,100,14,1.179340^*^*                    |Cannot get remote address for connector socket.
93080996.000 |12:04:53.874 |NetError |                                       |                               |SdlTCPConnector(2,100,13,76603)  |                                 |2,100,14,1.179340^*^*                    |SdlConnectorBase::connectionError
Hi Mohammed,
we have verified with firewall vendor , but they said no issue from firewall .
previously we had one way audio issue . but when I added IP route to the new network from gateway , it has been resolved . other than that what can be the issue in routing part , kindly suggest.
Look for something breaking the connectivity.  The traces are showing failure to open tcp session. There is nothing to be done from cucm at this point of time
