02-20-2023 02:30 AM
iam configuring Cisco Voice gateway ISR 4321 for Webex calling. but i am not able to enter the following command in sip-ua and it is showing crypto as unrecognized command . Please help me to resolve this issue.
sip-ua
crypto signaling default trustpoint sampleTP cn-san-validate server
transport tcp tls v1.2
tcp-retry 1000
end
02-20-2023 02:35 AM
please share output of #sh ver
02-22-2023 11:08 PM
sh version
Cisco IOS XE Software, Version 17.03.05
Cisco IOS Software [Amsterdam], ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 17.3.5, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2022 by Cisco Systems, Inc.
Compiled Wed 09-Feb-22 10:37 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2022 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: 16.12(2r)
uptime is 1 day, 3 hours, 11 minutes
Uptime for this control processor is 1 day, 3 hours, 12 minutes
System returned to ROM by Reload Command at 08:09:13 UTC Tue Feb 21 2023
System image file is "flash:isr4300-universalk9.17.03.05.SPA.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
02-20-2023 03:41 AM
Very likely the router is not licensed for security features.
02-22-2023 11:10 PM
crypto pki trustpool command is taking, the issue is with Crypto command under sip-ua
02-20-2023 04:55 AM
license boot level securityk9
02-20-2023 05:03 AM
Router#copy running-config startup-config
then reboot the router and check command again
02-22-2023 11:09 PM
tried it still same behaviour
02-22-2023 11:13 PM
Is your router licensed with security features?
02-22-2023 11:16 PM
we didn't register to smart account yet
Suite Suite Current Type Suite Next reboot
FoundationSuiteK9 None Smart License None
securityk9
appxk9
AdvUCSuiteK9 None Smart License None
uck9
cme-srst
cube
Technology Package License Information:
Technology Technology-package Technology-package
Current Type Next reboot
appxk9 appxk9 Smart License appxk9
uck9 uck9 Smart License uck9
securityk9 None Smart License None
ipbase ipbasek9 Smart License ipbasek9
The current throughput level is 100000 kbps
02-23-2023 12:38 AM - edited 10-01-2023 09:39 PM
I did not ask about Smart Licensing.
10-12-2023 01:57 AM
I had the same issue, and this works with me. I have ISR4331 IOS ver 17.9.4
thanks
10-01-2023 08:27 PM
Has anyone found the solution to this problem?
10-01-2023 09:41 PM
The solution is to have the router license with security features. Without that you can not enter any commands that is related to security features in the router.
10-12-2023 01:59 AM
I had this issue, and adding the following commands work with me
license boot suite AdvUCSuiteK9
