09-25-2011 01:33 PM - edited 03-16-2019 07:10 AM
Please find below the error i'm facing :
the output of "utils ntp status" is
admin:utils ntp status
ntpd (pid 4814) is running...
remote refid st t when poll reach delay offset jitter
10.0.1.21 10.0.1.22 3 u 21 64 377 0.346 126.507 51.418
10.0.1.22 10.0.1.22 2 u 14 64 377 0.239 129.458 45.550
unsynchronised
time server re-starting
polling server every 64 s
Current time in UTC is : Sun Sep 25 14:48:24 UTC 2011
Current time in Africa/Harare is : Sun Sep 25 16:48:24 CAT 2011
The two server are used to install publisher and both are accessible when navigating from OS any one has an explanation ,and why it's
unsynchronized .
09-25-2011 03:21 PM
Hi Osama.
Did you add this node to server list on the first node?
Check also the hostname/ip address you configured on this node during setup.
Hope this help.
Carlo
09-25-2011 03:28 PM
Many thanks Carlo .
Yes i checked the publisher configuration for that sub ,also the hostname/ip address of publisher is correct .
09-25-2011 03:42 PM
Hi Osama.
Can you post the output of a "show network cluster" ?
Carlo
09-25-2011 04:25 PM
Are the two IPv4 addresses shown there full NTPv4-compliant servers? Most noteably Windows servers are not since they use SNTP. A good test of this is whether Catalyst/ISR hardware is capable of syncronziing with those IP addresses. SNTP is a stripped down version of NTP that misses
My guess is they are Windows hosts since: a) they are in the middle of a subnet; b) they are providing enough data for ntpd to see their stratum and such; and, c) ntpd is still choosing not to syncronize with them. That is exactly how an NTPv4 compliant server will behave when trying to pull time from an SNTP server.
09-25-2011 04:52 PM
Amazing
thanks so much jonathan I'll check and give feed back,any doc. should I read to get more info. also your recommendation to my case is highly appreciated .
09-26-2011 10:09 AM
It has been my experience that using a Windows based NTP (or SNTP to be more accurate) server for your CUCM envronment is bad mojo. Get a Linux server (or the like) on the network and use it for NTP, it can also provide a good SFTP location for backups and a spare TFTP server for phones if you need it to. I know Linux can be a pain, expecially if you are unfamiliar with it but i does really provide the best platform for these functions.
12-24-2014 10:26 AM
I ran into this same issue trying to build a cluster offline with no access to the internet. I was using Windows Server as NTP. Showed up as accessible in the web GUI but unsynchronized from CLI. I ended up installing NetTime (http://www.timesynctool.com/) on my Windows servers and used it as the NTP server instead and CUCM was able to synchronize and I was able to complete the installation of the subscriber node.
12-25-2014 01:56 AM
Hi David,
Thanks for sharing the info on NetTime[+5].
Is it just a matter of installing this tool when on Windows Machine when we do not have internet access or do we need to more configs related to NTP?
regds,
aman
12-29-2014 06:33 AM
Yes, I installed this on a Windows server that did not have Internet access. I'm rebuilding my cluster offline to avoid hours of downtime. I have to reinstall my 9.1.1 cluster with a clean OVA template because it detects unaligned partitions after I upgraded to 9.2
09-29-2011 08:22 AM
Have you found a solution to this? I'm installing CUCM (8.5), Unity, UCCX (8.5) on a UCS-C200-M2 and keep having this issue, I've installed the OS on al vmware machines, but can't get throught the setup process, because I keep getting the NTP inaccessible message (on al servers). I have tested connectivity to the LAN, I can even ping my servers (vmware servers) from other computers but can't get it to recognize any ntp server (local or public). I can't login to the CLI because it won't take my user/password; i guess they are still in default. Help!
09-29-2011 09:09 AM
Answering my own question, NTP server has to have a low stratum (say 1-8) otherwise, CUCM, UNITY, UCCX will just ignore it, i found a stratum 1 public server and got it working =D
09-29-2011 09:28 AM
Great news you've solved your issue ,could you help me where to read about this NTP
stratum thing .
09-29-2011 10:03 AM
Info about cucm ntp stratum:
http://www.networkworld.com/community/node/59350
NTP stratum 1 public servers:
http://support.ntp.org/bin/view/Servers/StratumOneTimeServers
12-09-2016 07:57 AM
Many thanks, A00460610!
I know for sure that my publisher 8.6 in a lab - virtual machine on vmware - has connectivity but the NTP client couldn't connect to any NTP server.
I tried NIST ntp addresses, Windows NTP as a services on UDP 123 on a pc/desktop but no success.
Your solution worked very well. Thank you so much, again!
