02-02-2019 05:04 PM - edited 03-17-2019 02:03 PM
I configured Cisco phone “No Answer Ring Duration (seconds)” - 50 sec and then call should go to voice mail.
It works for internal or incoming external(analog) calls.
Inbound external calls through sip trunk drops after about 30 sec. if no answer
Sip Provider------ > Sip Trunk -------> CUBE ------->SIP trunk -------> Call manager (8.6) --------> Cisco phone
Possible, some SIP timers is not setup correctly. Does provider setup the timers?
Thank you
Solved! Go to Solution.
02-02-2019 08:21 PM
check the sip trace if you are receiving a "bye" after 30 seconds from your provider end, tehy are cutting the call.
add sip traces if you can
02-02-2019 08:21 PM
02-04-2019 09:24 AM
I captured the trace and I got the "buy" in 30 sec. I contacted the sip provider and he confirmed that it is the default sip configuration for their trunks. After increasing that timer no more drop calls.
Thank you,
Andrei
02-02-2019 09:58 PM
