on the call manager forward all outside number couldn't work
ozden ozdugun
our system
cucm 8.6 -- sıp trunk -----cisco voice gateway ----- sip trunk ------telco
we can call outside but,when we want to forward all to mobile phone.call forwarding couldn't work
21 Replies 21
What I understood is after changing Calling Party Selection,  For a forwarding call you are sending 4 digit  extension number instead of mobile number.BUT  your ISP is expecting Full DID  for processing the call? Am I correct.
Are you using external phone number mask ? For an outgoing how do you translate 4 digit to Full digit ?
Response Signature
yes I use prefix.and calling party selection is orginatior.this configuration my calling is working but forwarding not working.when change the calling party selection redirect number.calling and faorwarding not working and  ı saw debug voip ccapi inout calling number only  4 digit not with prefix
Where you added the Prefix? So your ISP expecting Full digits ?
Response Signature
yes our isp want full digit.and ı added prefix route pattern
So just to make sure we're completely clear, are you saying (1) your phones have four digit directory numbers (for example 4444), (2) you haven't configured an External Phone Number Mask in the DN configuration. (3) For normal outgoing calls you fix up the calling number on the Route Pattern using Calling Party Transformations / Prefix Digits (Outgoing Calls).
Is that all correct?
If so then the problem is that the redirected call is just going to show the four digit DN.
One option, if you're happy to present a standard calling number for redirected calls, would be a translation rule on the gateway to match and replace any four digit number.   For example this rule matches only four digit numbers and replaces with 08501230000.  All other numbers are not matched and therefore left unchanged.
voice translation-rule 5
 rule 5 /^....$/ /08501230000/
Wouldn't this also be a possibility?
 rule 5 /^\(....\)$/ /0850123\1/
This should keep the number from the forwarding DN and prefix the needed part to it.
Response Signature
As @TONY SMITH  mentioned, you can use a translation on gateway.
Response Signature
