05-27-2013 06:15 AM - edited 03-16-2019 05:32 PM
HI support
form the branch office to head office call is disconnecting with (Disconnect Cause=38)
but from the head office to branch it is working fine .
i here attached the config and error log
from 4xxx to 7xxx while callingit gets Disconnect
please help us to resolve the issue
regards
Raja
Solved! Go to Solution.
05-27-2013 06:30 AM
Hi Raja,
Look like a routing/firewall problem. Cause 38 mean that the network is not functioning correctly.
Please remember to rate useful posts clicking on the stars below.
Favor calificar todos las respuestas útiles dando click en las estrellas de mas abajo.
___________________________________________
LinkedIn Profile: do.linkedin.com/in/leosalcie
05-27-2013 06:30 AM
Hi Raja,
05-27-2013 06:37 AM
Hi leosalcie
Thank you for your update is there is any command that i cam confirm is the problem with routing and firewall
becauz from the branch it is connecting to another branch that work fine . and other branch that is connected to hed office also works fine
please help me is there is any command that i can confirm
regards
raja
05-27-2013 06:55 AM
That depend on your scenario. Do you have a VPN tunnel between HQ and BR?
