02-19-2013 01:43 AM - edited 03-16-2019 03:48 PM
Outbound calls are disconnecting when called party answers the phone. I have pasted the debug below. Would appreciate any help in understanding the issue. Thank you for your time
*Feb 19 09:07:44.910: //-1/A84612B7BD8D/CCAPI/cc_api_call_setup_ind_common:
Interface=0x7082DEB4, Call Info(
Calling Number=2169301,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=90097339982779(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
Incoming Dial-peer=7300, Progress Indication=NULL(0), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=30842
*Feb 19 09:07:44.910: //-1/A84612B7BD8D/CCAPI/ccCheckClipClir:
In: Calling Number=2169301(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Out: Calling Number=2169301(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
*Feb 19 09:07:44.910: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Feb 19 09:07:44.910: :cc_get_feature_vsa malloc success
*Feb 19 09:07:44.910: cc_get_feature_vsa count is 1
*Feb 19 09:07:44.910: :FEATURE_VSA attributes are: feature_name:0,feature_time:1885860640,feature_id:649
*Feb 19 09:07:44.910: //30842/A84612B7BD8D/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=2169301(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=90097339982779(TON=Unknown, NPI=Unknown))
*Feb 19 09:07:44.910: //30842/A84612B7BD8D/CCAPI/cc_process_call_setup_ind:
Event=0x68032D20
*Feb 19 09:07:44.910: //30842/A84612B7BD8D/CCAPI/ccCallSetContext:
Context=0x7128125C
>>>>CCAPI handed cid 30842 with tag 7300 to app "_ManagedAppProcess_Default"
*Feb 19 09:07:44.910: //30842/A84612B7BD8D/CCAPI/ccCallProceeding:
*Feb 19 09:07:44.914: //30842/A84612B7BD8D/CCAPI/ccCallSetupRequest:
Destination=, Calling IE Present=TRUE, Mode=0,
Outgoing Dial-peer=9, Params=0x7127D8EC, Progress Indication=NULL(0)
*Feb 19 09:07:44.914: //30842/A84612B7BD8D/CCAPI/ccCheckClipClir:
Destination Pattern=9T, Called Number=0097339982779, Digit Strip=FALSE
Called Number=0097339982779(TON=Unknown, NPI=Unknown),
Redirect Number=, Display Info=Aslam Shaik
Account Number=2169301, Final Destination Flag=TRUE,
Guid=A84612B7-79AA-11E2-BD8D-F6CECD79320E, Outgoing Dial-peer=9
*Feb 19 09:07:44.914: //30842/A84612B7BD8D/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-username=2169301
----- ccCallInfo IE subfields -----
cisco-ani=2169301
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=0097339982779
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
cisco-redirectreason=-1 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
*Feb 19 09:07:44.914: //30842/A84612B7BD8D/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x7082DEB4, Interface Type=3, Destination=, Mode=0x0,
Call Params(Calling Number=2169301,(Calling Name=Aslam Shaik)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=0097339982779(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=9, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
*Feb 19 09:07:44.914: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Feb 19 09:07:44.914: :cc_get_feature_vsa malloc success
*Feb 19 09:07:44.914: cc_get_feature_vsa count is 2
*Feb 19 09:07:44.914: :FEATURE_VSA attributes are: feature_name:0,feature_time:1885860424,feature_id:650
*Feb 19 09:07:44.914: //30843/A84612B7BD8D/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
*Feb 19 09:07:44.914: //30843/A84612B7BD8D/CCAPI/ccCallSetContext:
Context=0x7127D89C
*Feb 19 09:07:44.914: //30842/A84612B7BD8D/CCAPI/ccSaveDialpeerTag:
*Feb 19 09:07:44.914: //30843/A84612B7BD8D/CCAPI/cc_api_call_proceeding:
Interface=0x7082DEB4, Progress Indication=NULL(0)
*Feb 19 09:07:49.390: //30843/A84612B7BD8D/CCAPI/cc_api_call_alert:
Interface=0x7082DEB4, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
Call Entry(Retry Count=0, Responsed=TRUE)
*Feb 19 09:07:49.390: //30842/A84612B7BD8D/CCAPI/ccCallAlert:
Call Entry(Responsed=TRUE, AlertSent=TRUE)
*Feb 19 09:07:49.390: //30842/A84612B7BD8D/CCAPI/ccCallNotify:
Data Bitmask=0x7, Call Id=30842
*Feb 19 09:07:56.990: //30843/A84612B7BD8D/CCAPI/cc_api_caps_ind:
Destination Interface=0x0, Destination Call Id=-1, Source Call Id=30843,
Caps(Codec=0x2, Fax Rate=0x2, Vad=0x2,
Modem=0x0, Codec Bytes=160, Signal Type=2)
Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Playout Max=250(ms), Fax Nom=300(ms))
*Feb 19 09:07:56.990: //30842/A84612B7BD8D/CCAPI/cc_api_caps_ack:
Destination Interface=0x0, Destination Call Id=30843, Source Call Id=30842,
Caps(Codec=g711alaw(0x2), Fax Rate=FAX_RATE_VOICE(0x2), Vad=OFF(0x1),
Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=1812)
*Feb 19 09:07:56.990: //30843/A84612B7BD8D/CCAPI/cc_api_event_indication:
Event=141, Call Id=30843
Event Is Sent To Conferenced SPI(s) Directly
*Feb 19 09:07:56.990: //30843/A84612B7BD8D/CCAPI/cc_api_call_connected:
Interface=0x7082DEB4, Data Bitmask=0x1, Progress Indication=NULL(0),
Connection Handle=0
Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
*Feb 19 09:07:56.990: //30842/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
(confID=0x66CE2948, callID1=0x787A, callID2=0x787B, tag=0x0)
*Feb 19 09:07:56.990: //30842/A84612B7BD8D/CCAPI/ccConferenceCreate:
Conference Id=0x66CE2948, Call Id1=30842, Call Id2=30843, Tag=0x0
*Feb 19 09:07:56.990: ccConferenceCreate: ret1=0, codecMask1=2, bytes1=160, negot1=0, dtmf1=6
ret2=0, codecMask2=2, bytes2=160, negot2=1, dtmf2=3
delay media to slow start case, codec negotation is not done
*Feb 19 09:07:56.990: //30842/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Feb 19 09:07:56.990: cc_api_get_xcode_stream : 4369
*Feb 19 09:07:56.990: //30842/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Conference Id=0xB3, Source Interface=0x7082DEB4, Source Call Id=30842,
Destination Call Id=30843, Disposition=0x0, Tag=0x0
*Feb 19 09:07:56.990: //30843/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Feb 19 09:07:56.990: //30843/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Conference Id=0xB3, Source Interface=0x7082DEB4, Source Call Id=30843,
Destination Call Id=30842, Disposition=0x0, Tag=0x0
*Feb 19 09:07:56.990: //30842/A84612B7BD8D/CCAPI/cc_generic_bridge_done:
Call Entry(Conference Id=0xB3, Destination Call Id=30843)
*Feb 19 09:07:56.990: //30843/A84612B7BD8D/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0xB3, Destination Call Id=30842)
*Feb 19 09:07:56.990: //30842/A84612B7BD8D/CCAPI/cc_process_notify_bridge_done:
Conference Id=0xB3, Call Id1=30842, Call Id2=30843
*Feb 19 09:07:56.994: //30842/A84612B7BD8D/CCAPI/ccCallConnect:
Progress Indication=NULL(0), Data Bitmask=0x1
Call Entry(Connected=TRUE, Responsed=TRUE)
*Feb 19 09:07:56.994: //30842/A84612B7BD8D/CCAPI/ccCallNotify:
*Feb 19 09:07:57.170: //30842/A84612B7BD8D/CCAPI/cc_api_call_disconnected:
Cause Value=65, Interface=0x7082DEB4, Call Id=30842
Call Entry(Responsed=TRUE, Cause Value=65, Retry Count=0)
*Feb 19 09:07:57.170: //30843/A84612B7BD8D/CCAPI/ccGenerateToneInfo:
Stop Tone On Digit=FALSE, Tone=Null,
Tone Direction=Sum Network, Params=0x0, Call Id=30843
*Feb 19 09:07:57.170: //30842/A84612B7BD8D/CCAPI/ccConferenceDestroy:
Conference Id=0xB3, Tag=0x0
*Feb 19 09:07:57.170: //30842/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
*Feb 19 09:07:57.170: //30843/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
*Feb 19 09:07:57.174: //30842/A84612B7BD8D/CCAPI/cc_generic_bridge_done:
*Feb 19 09:07:57.174: //30842/A84612B7BD8D/CCAPI/ccCallDisconnect:
Cause Value=65, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=65)
Cause Value=65, Call Entry(Responsed=TRUE, Cause Value=65)
*Feb 19 09:07:57.174: //30843/A84612B7BD8D/CCAPI/ccCallDisconnect:
Cause Value=65, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
*Feb 19 09:07:57.226: //30843/A84612B7BD8D/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x7082DEB4, Tag=0x0, Call Id=30843,
Call Entry(Disconnect Cause=65, Voice Class Cause Code=0, Retry Count=0)
Call Disconnect Event Sent
*Feb 19 09:07:57.226: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Feb 19 09:07:57.226: :cc_free_feature_vsa freeing 7067F240
*Feb 19 09:07:57.226: vsacount in free is 1
*Feb 19 09:07:57.234: //30842/A84612B7BD8D/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x7082DEB4, Tag=0x0, Call Id=30842,
*Feb 19 09:07:57.234: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Feb 19 09:07:57.234: :cc_free_feature_vsa freeing 7067F318
*Feb 19 09:07:57.234: vsacount in free is 0
*Feb 19 09:08:15.770: //30845/xxxxxxxxxxxx/CCAPI/cc_api_caps_ind:
Call Entry Is Not Found
*Feb 19 09:08:15.770: //-1/BAAA539DBD94/CCAPI/cc_api_display_ie_subfields:
cisco-username=97339982779
cisco-ani=97339982779
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=2169301
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
Solved! Go to Solution.
02-19-2013 05:37 AM
G711ulaw is certainly in the attributes..Looking at the M-line
m=audio 0 RTP/AVP 18 0 8 4 2 15 3
CUBE is offering
18=G729
0=PCMU---------G711u
8=PCMA-----G711a
And your provider certainly supports G711ulaw and alaw
This is the SDP in the response received from your ITSP
m=audio 37372 RTP/AVP 8 0 18 4 2 98 99 97
a=rtpmap:8 PCMA/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:18 G729/8000
a=rtpmap:4 G723/8000
a=rtpmap:2 G726-32/8000
a=rtpmap:98 G726-40/8000
a=rtpmap:99 G726-32/8000
a=rtpmap:97 telephone-event/8000
a=fmtp:97 0-15
a=fmtp:18 annexb=yes
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
02-19-2013 03:12 AM
You need to mention products and version used, complete call flow, configuration, etc.
02-19-2013 03:29 AM
As paolo suggested, please describe your call flow and the components involved..
Also i see call is disconnected by the originating gateway with a cause code of 65..Which is most times codec related...
So we need to see what capabilities are exchanged...
You can send a debug h225 asn1 and debug h245 asn1 along with your sh run and call flow description
02-19-2013 04:41 AM
Thank you for taking time to review this. This VG is connected to ISP via SIP trunk. I have also pasted below debug ccsip all. I will post the other information requested by aokanlawon also shortly.
*Feb 19 11:10:34.521: //31226/BDD4BC8FBF32/SIP/Info/sipSPIUdeleteccCallIdFromTable: Removing call id 79FA
*Feb 19 11:10:34.521: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIDeleteContextFromTable: Context for key=[31239] removed.
*Feb 19 11:10:34.521: //31226/BDD4BC8FBF32/SIP/Info/sipSPIUdeleteCcbFromUASReqTable: ****Deleting from UAS Request table.
*Feb 19 11:10:34.521: //31226/BDD4BC8FBF32/SIP/Info/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x7078E564 key=isbcthet427pekuth2ahe2utpc7utsu2tpuh@SoftX3000
*Feb 19 11:10:34.521: //31226/BDD4BC8FBF32/SIP/Info/sipSPIUdeleteCcbFromUASRespTable: ****Deleting from UAS Response table.
*Feb 19 11:10:34.521: //31226/BDD4BC8FBF32/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
*Feb 19 11:10:34.521: //31226/BDD4BC8FBF32/SIP/Info/sipSPIUfreeOneCCB: Freeing ccb 7078E564
*Feb 19 11:10:42.365: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
*Feb 19 11:10:42.365: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x00000000
*Feb 19 11:10:42.365: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x7095EC90, addr=10.104.160.30, port=41357, connid=1, transport=TCP
*Feb 19 11:10:42.365: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:90097339982779@10.106.78.7:5060 SIP/2.0
Date: Tue, 19 Feb 2013 11:03:45 GMT
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
From: "Aslam Shaik" <2169301>;tag=895022dc-e465-496e-9fcb-fa8b46f34648-477193402169301>
Allow-Events: presence
P-Asserted-Identity: "Aslam Shaik" <2169301>2169301>
Supported: timer,resource-priority,replaces
Min-SE: 1800
Remote-Party-ID: "Aslam Shaik" <2169301>;party=calling;screen=yes;privacy=off2169301>
Content-Length: 0
User-Agent: Cisco-CUCM7.0
To: <90097339982779>90097339982779>
Contact: <2169301>2169301>
Expires: 180
Call-ID: 6014400-12315c11-adf1-1ea0680a@10.104.160.30
Via: SIP/2.0/TCP 10.104.160.30:5060;branch=z9hG4bKeaa03332dc41
CSeq: 101 INVITE
Session-Expires: 1800
Max-Forwards: 70
*Feb 19 11:10:42.365: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
*Feb 19 11:10:42.369: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAddContextToTable: Added context(0x70782DB8) with key=[31241] to table
*Feb 19 11:10:42.369: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 10.104.160.30,Port 41357, Transport 2, SentBy Port 5060
*Feb 19 11:10:42.369: //-1/D5950F0DBF34/SIP/State/sipSPIChangeState: 0x70782DB8 : State change from (STATE_NONE, SUBSTATE_NONE) to (STATE_IDLE, SUBSTATE_NONE)
*Feb 19 11:10:42.369: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
*Feb 19 11:10:42.369: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckIpip: VOIP dialpeer (peer=0x6652B9AC) found for sip_user: 90097339982779
*Feb 19 11:10:42.369: //-1/D5950F0DBF34/SIP/Info/sipSPISetInfoFromRpid: Received current remote name: Aslam Shaik, current remote number: 2169301
*Feb 19 11:10:42.369: //-1/D5950F0DBF34/SIP/Info/sipSPISetInfoFromRpid: Received ;screen=yes ;privacy=off -> Setting Octet3A 0x81, extended_privacy 0x00
*Feb 19 11:10:42.369: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentGTD: No GTD found in inbound container
*Feb 19 11:10:42.369: //-1/D5950F0DBF34/SIP/Info/sipSPIUaddCcbToUASReqTable: ****Adding to UAS Request table.
*Feb 19 11:10:42.369: //-1/D5950F0DBF34/SIP/Info/sipSPIUaddCcbToTable: Added to table. ccb=0x70782DB8 key=6014400-12315c11-adf1-1ea0680a@10.104.160.3090097339982779
*Feb 19 11:10:42.369: //-1/D5950F0DBF34/SIP/Info/sipSPIMatchSrcIpGroup: Match not found on carrier id
*Feb 19 11:10:42.369: //-1/D5950F0DBF34/SIP/Info/sipSPIMatchSrcIpGroup: Match not found on Incoming called number: 90097339982779
*Feb 19 11:10:42.369: //-1/D5950F0DBF34/SIP/Info/sipSPIMatchSrcIpGroup: Match not found on destination pattern: 2169301
*Feb 19 11:10:42.369: //-1/D5950F0DBF34/SIP/Info/ccsipUpdateIncomingCallParams: ccCallInfo: Calling name Aslam Shaik, number 2169301, Calling oct3 0x00, oct_3a 0x81, Called number 90097339982779
*Feb 19 11:10:42.369: //-1/D5950F0DBF34/SIP/Info/sipSPIGetCallConfig: Precondition tag absent in Require/Supported header
*Feb 19 11:10:42.369: //-1/D5950F0DBF34/SIP/Info/sipSPIGetCallConfig: Peer tag 7300 matched for incoming call
*Feb 19 11:10:42.369: //-1/D5950F0DBF34/SIP/Info/sipSPIGetCallConfig: Using Voice Class Codec, tag = 1
*Feb 19 11:10:42.369: //-1/D5950F0DBF34/SIP/Info/sipSPIContinueNewMsgInvite: Calling name Aslam Shaik, number 2169301, Calling oct3 0x00, oct_3a 0x81, ext_priv 0x00, Called number 90097339982779, oct3 0x00
*Feb 19 11:10:42.369: //-1/D5950F0DBF34/SIP/Info/sipSPIContinueNewMsgInvite: Carrier id code , prev_cid NONE, next_cid NONE, prev_tgrp NONE, next_tgrp NONE
*Feb 19 11:10:42.369: //-1/D5950F0DBF34/SIP/Info/sipSPIRscmsmAvail: Value returned by check is = 0
*Feb 19 11:10:42.369: //31228/D5950F0DBF34/SIP/Info/sipSPINegotiateSessionExpires:
Session-Expires value: 1800 refresher: 3
*Feb 19 11:10:42.369: //31228/D5950F0DBF34/SIP/Info/sipSPINegotiateSessionExpires: Min-SE Header: 1800
*Feb 19 11:10:42.369: //31228/D5950F0DBF34/SIP/Error/sipSPIProcessCallInfoHeader: Call-Info header with for Unsolicited Notify Absent,Disabling Unsolicited Notifies
*Feb 19 11:10:42.369: //31228/D5950F0DBF34/SIP/Info/sipSPIGetContentSDP: No SDP found in inbound container
*Feb 19 11:10:42.369: //31228/D5950F0DBF34/SIP/Info/sipSPIDoQoSNegotiation: No SDP body
*Feb 19 11:10:42.369: //31228/D5950F0DBF34/SIP/Info/sipSPICanSetFallbackFlag: Local Fallback is not active
*Feb 19 11:10:42.369: //31228/D5950F0DBF34/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
CallID 31228, sdp 0x66CF34D4 channels 0x70783E88
*Feb 19 11:10:42.369: //31228/D5950F0DBF34/SIP/Info/copy_channels:
callId 31228 size 0 ptr 0x706BD774)
*Feb 19 11:10:42.369: //31228/D5950F0DBF34/SIP/Info/sipSPIUpdateSrcSdpFixedPart: Delayed media case...creating new stream
*Feb 19 11:10:42.369: //31228/D5950F0DBF34/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.106.78.7
*Feb 19 11:10:42.369: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIReserveRtpPort: reserved port 17372 for stream 1
*Feb 19 11:10:42.369: //31228/D5950F0DBF34/SIP/Info/sipSPIUpdateSrcSdpFixedPart: Reserving rtp port for stream 1, src_port=17372
*Feb 19 11:10:42.369: //31228/D5950F0DBF34/SIP/Media/sipSPIAddSDPMediaPayload: Preferred method of dtmf relay is: 6, with payload: 101
*Feb 19 11:10:42.369: //31228/D5950F0DBF34/SIP/Info/sipSPIAddBillingInfoToCcb: sipCallId for billing records = 6014400-12315c11-adf1-1ea0680a@10.104.160.30
*Feb 19 11:10:42.369: //31228/D5950F0DBF34/SIP/Info/sipSPI_ipip_store_channel_info: Store channelInfo in CallInfo
*Feb 19 11:10:42.369: //31228/D5950F0DBF34/SIP/Info/sipSPI_ipip_store_channel_info: negotiated dtmf not available, using dialpeer config dtmf = 6
*Feb 19 11:10:42.369: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateRawMsg: No GTD passed.
*Feb 19 11:10:42.369: //31228/D5950F0DBF34/SIP/Info/ccsip_set_bearer_capability:
Bearer Capability: Speech (0x00)
*Feb 19 11:10:42.369: //31228/D5950F0DBF34/SIP/Info/sipSPIContinueNewMsgInvite: ccsip_api_call_setup_ind returned: SIP_SUCCESS_DELAYED_MEDIA
*Feb 19 11:10:42.369: //31228/D5950F0DBF34/SIP/Info/sipSPIUaddccCallIdToTable: Adding call id 79FC to table
*Feb 19 11:10:42.369: //31228/D5950F0DBF34/SIP/Transport/sipSPITransportSendMessage: msg=0x6800EE4C, addr=10.104.160.30, port=41357, sentBy_port=5060, is_req=0, transport=2, switch=0, callBack=0x00000000
*Feb 19 11:10:42.369: //31228/D5950F0DBF34/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*Feb 19 11:10:42.369: //31228/D5950F0DBF34/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
*Feb 19 11:10:42.369: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x6800EE4C, addr=10.104.160.30, port=41357, connId=1 for TCP
*Feb 19 11:10:42.369: //31228/D5950F0DBF34/SIP/State/sipSPIChangeState: 0x70782DB8 : State change from (STATE_IDLE, SUBSTATE_NONE) to (STATE_RECD_INVITE, SUBSTATE_NONE)
*Feb 19 11:10:42.369: //31228/D5950F0DBF34/SIP/Info/sipSPIProcessContactInfo: Previous Hop 10.104.160.30:5060
*Feb 19 11:10:42.373: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Tue, 19 Feb 2013 11:10:42 GMT
Server: Cisco-SIPGateway/IOS-12.x
CSeq: 101 INVITE
Allow-Events: telephone-event
Content-Length: 0
*Feb 19 11:10:42.373: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_PROCEEDING
*Feb 19 11:10:42.373: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAddContextToTable: Added context(0x70795398) with key=[31242] to table
*Feb 19 11:10:42.373: //31229/000000000000/SIP/State/sipSPIChangeState: 0x70795398 : State change from (STATE_NONE, SUBSTATE_NONE) to (STATE_IDLE, SUBSTATE_NONE)
*Feb 19 11:10:42.373: //31229/000000000000/SIP/Info/ccsip_call_setup_request: Before processing SETUP REQccb->pld.flags_ipip = 200
This a IPIP call: NULL peer_channel - Delayed Media: peer_channels = 0x0, peer_param = 0x71190624, callID= 31229, peer_callID = 31228
*Feb 19 11:10:42.373: //31229/000000000000/SIP/Info/ccsip_gw_set_sipspi_mode: Setting SPI mode to SIP-SIP
*Feb 19 11:10:42.373: //31229/000000000000/SIP/Info/ccsip_call_setup_request: After processing SETUP REQccb->pld.flags_ipip = 400000
*Feb 19 11:10:42.373: //31229/D5950F0DBF34/SIP/Info/sipSPIGetOutboundHostAndDestHost: CCSIP: target_host : 10.200.7.157 target_port : 5060
*Feb 19 11:10:42.373: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_SETUP
*Feb 19 11:10:42.373: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_event_handler:
*Feb 19 11:10:42.373: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_event_handler: switch(ev.ev_id: 147)
*Feb 19 11:10:42.373: //31228/D5950F0DBF34/SIP/Info/ccsip_event_handler:
ccsip_event_handler: peer ID 31229 chans 0x712DCD68 event 147 flags 0x40201C 0x300 0x201 data 0x712DCD68
ccsip_event_handler: CC_EV_H245_SET_MODE: peer ID 31229 chans 0x712DCD68 event 147 flags 0x40201C 0x300 0x201 data 0x712DCD68, type = 1
*Feb 19 11:10:42.373: //31228/D5950F0DBF34/SIP/Info/ccsip_gw_set_sipspi_mode: Setting SPI mode to SIP-SIP
*Feb 19 11:10:42.373: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_event_handler: CC_R_SUCCESS_WITH_CONFIRMED
*Feb 19 11:10:42.373: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 3
*Feb 19 11:10:42.373: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 2
*Feb 19 11:10:42.373: //31229/D5950F0DBF34/SIP/Info/sipSPIUaddccCallIdToTable: Adding call id 79FD to table
*Feb 19 11:10:42.373: //31229/D5950F0DBF34/SIP/Info/sipSPIGetCallConfig: preferred_codec set[0] type :No Codec bytes: 0
*Feb 19 11:10:42.373: //31229/D5950F0DBF34/SIP/Info/sipSPICanSetFallbackFlag: Local Fallback is not active
*Feb 19 11:10:42.373: //31229/D5950F0DBF34/SIP/Info/sipSPIGetCallConfig: Not using Voice Class Codec
*Feb 19 11:10:42.373: //31229/D5950F0DBF34/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp:
callid 31229, channels 0x0 caps 0x685A4B00
*Feb 19 11:10:42.373: //31229/D5950F0DBF34/SIP/Info/sipSPIValidateAndCopyOutboundHost: CCSIP: copy target_host to outbound_host
*Feb 19 11:10:42.373: //31229/D5950F0DBF34/SIP/Info/sipSPIAddMLPPServicesInfo: No MLP Info available on incoming leg
*Feb 19 11:10:42.377: //31229/D5950F0DBF34/SIP/Info/act_idle_continue_call_setup:
*Feb 19 11:10:42.377: //31229/D5950F0DBF34/SIP/Info/sipSPIRscmsmAvail: Value returned by check is = 0
*Feb 19 11:10:42.377: //31229/D5950F0DBF34/SIP/Info/sipSPIUaddCcbToUACTable: ****Adding to UAC table.
*Feb 19 11:10:42.377: //31229/D5950F0DBF34/SIP/Info/sipSPIUaddCcbToTable: Added to table. ccb=0x70795398 key=D59647F6-79BB11E2-BF39F6CE-CD79320E@10.66.7.218
*Feb 19 11:10:42.377: //31229/D5950F0DBF34/SIP/Info/sipSPIUsetBillingProfile: sipCallId for billing records = D59647F6-79BB11E2-BF39F6CE-CD79320E@10.66.7.218
*Feb 19 11:10:42.377: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 10.200.7.157,Port 5060, Transport 1, SentBy Port 5060
*Feb 19 11:10:42.377: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
*Feb 19 11:10:42.377: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIgetRegistrarHost: registrar is not configured
*Feb 19 11:10:42.377: //31229/D5950F0DBF34/SIP/Event/sipSPICreateRpid: Received Octet3A=0x81 -> Setting ;screen=yes ;privacy=off
*Feb 19 11:10:42.377: //31229/D5950F0DBF34/SIP/Info/sipSPISendInvite: Associated container=0x7117C820 to Invite
*Feb 19 11:10:42.377: //31229/D5950F0DBF34/SIP/Transport/sipSPISendInvite: Sending Invite to the transport layer
*Feb 19 11:10:42.377: //31229/D5950F0DBF34/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
*Feb 19 11:10:42.377: //31229/D5950F0DBF34/SIP/Transport/sipSPITransportSendMessage: msg=0x70C7F080, addr=10.200.7.157, port=5060, sentBy_port=0, is_req=1, transport=1, switch=0, callBack=0x615E6EC8
*Feb 19 11:10:42.377: //31229/D5950F0DBF34/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*Feb 19 11:10:42.377: //31229/D5950F0DBF34/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
*Feb 19 11:10:42.377: //31229/D5950F0DBF34/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x70C7F080
*Feb 19 11:10:42.377: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x70C7F080, addr=10.200.7.157, port=5060, connId=1 for UDP
*Feb 19 11:10:42.377: //31229/D5950F0DBF34/SIP/Info/sentInviteRequest: Sent Invite in state STATE_IDLE
*Feb 19 11:10:42.377: //-1/xxxxxxxxxxxx/SIP/Info/sentInviteRequest: Transaction active. Facilities will be queued.
*Feb 19 11:10:42.377: //31229/D5950F0DBF34/SIP/State/sipSPIChangeState: 0x70795398 : State change from (STATE_IDLE, SUBSTATE_NONE) to (STATE_SENT_INVITE, SUBSTATE_NONE)
*Feb 19 11:10:42.377: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:0097339982779@10.200.7.157:5060 SIP/2.0
Via: SIP/2.0/UDP 10.66.7.218:5060;branch=z9hG4bK3F815E6
From: "Aslam Shaik" <2169301>;tag=248B1A04-13842169301>
To: <0097339982779>0097339982779>
Call-ID: D59647F6-79BB11E2-BF39F6CE-CD79320E@10.66.7.218
Supported: 100rel,timer,resource-priority,replaces
Min-SE: 1800
Cisco-Guid: 3583315725-2042302946-3207919310-3447271950
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1361272242
Call-Info: <10.66.7.218:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"10.66.7.218:5060>
Expires: 180
Max-Forwards: 69
Content-Length: 0
*Feb 19 11:10:42.389: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpSocketReads: Msg enqueued for SPI with IP addr: 10.200.7.157:5060
*Feb 19 11:10:42.389: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
*Feb 19 11:10:42.389: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x00000000
*Feb 19 11:10:42.389: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
*Feb 19 11:10:42.389: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
From: "Aslam Shaik"<2169301>;tag=248B1A04-13842169301>
CSeq: 101 INVITE
Content-Length: 0
*Feb 19 11:10:42.389: //31229/D5950F0DBF34/SIP/State/sipSPIChangeState: 0x70795398 : State change from (STATE_SENT_INVITE, SUBSTATE_NONE) to (STATE_RECD_PROCEEDING, SUBSTATE_PROCEEDING_PROCEEDING)
*Feb 19 11:10:42.645: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpSocketReads: Msg enqueued for SPI with IP addr: 10.200.7.157:5060
*Feb 19 11:10:42.645: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
*Feb 19 11:10:42.645: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x00000000
*Feb 19 11:10:42.645: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:10.66.7.218:5060 SIP/2.0
Via: SIP/2.0/UDP 10.200.7.157:5060;branch=z9hG4bKo2kofkt7hu47dupoosc7ausefT17526
Call-ID: isbcoc2au4b7s4oco2tobse77otchdeeepk7@SoftX3000
From: <10.66.7.218:5060>;tag=sbc08032sehe4do10.66.7.218:5060>
To: <10.66.7.218>10.66.7.218>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
*Feb 19 11:10:42.645: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
*Feb 19 11:10:42.645: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAddContextToTable: Added context(0x7077BF84) with key=[31243] to table
*Feb 19 11:10:42.645: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 10.200.7.157,Port 5060, Transport 1, SentBy Port 5060
*Feb 19 11:10:42.645: //-1/D5BF2BC9BF3A/SIP/State/sipSPIChangeState: 0x7077BF84 : State change from (STATE_NONE, SUBSTATE_NONE) to (STATE_IDLE, SUBSTATE_NONE)
*Feb 19 11:10:42.645: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.200.7.157,Port 5060, Transport 1, SentBy Port 5060
*Feb 19 11:10:42.645: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
*Feb 19 11:10:42.645: //31230/D5BF2BC9BF3A/SIP/Info/sipSPIGetCallConfig: Precondition tag absent in Require/Supported header
*Feb 19 11:10:42.645: //31230/D5BF2BC9BF3A/SIP/Info/sipSPIGetCallConfig: Non dial peer leg - using RTP Supported Codecs
*Feb 19 11:10:42.645: //31230/D5BF2BC9BF3A/SIP/Info/sipSPIGetCallConfig: RTP Preferred Codecs supported by GW 18
*Feb 19 11:10:42.645: //31230/D5BF2BC9BF3A/SIP/Info/sipSPIGetCallConfig: RTP Preferred Codecs supported by GW 0
*Feb 19 11:10:42.645: //31230/D5BF2BC9BF3A/SIP/Info/sipSPIGetCallConfig: RTP Preferred Codecs supported by GW 8
*Feb 19 11:10:42.645: //31230/D5BF2BC9BF3A/SIP/Info/sipSPIGetCallConfig: RTP Preferred Codecs supported by GW 4
*Feb 19 11:10:42.645: //31230/D5BF2BC9BF3A/SIP/Info/sipSPIGetCallConfig: RTP Preferred Codecs supported by GW 2
*Feb 19 11:10:42.645: //31230/D5BF2BC9BF3A/SIP/Info/sipSPIGetCallConfig: RTP Preferred Codecs supported by GW 15
*Feb 19 11:10:42.645: //31230/D5BF2BC9BF3A/SIP/Info/sipSPIGetCallConfig: RTP Preferred Codecs supported by GW 3
*Feb 19 11:10:42.645: //31230/D5BF2BC9BF3A/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.66.7.218
*Feb 19 11:10:42.645: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_OPTIONS_RESP
*Feb 19 11:10:42.645: //31230/D5BF2BC9BF3A/SIP/Info/sact_idle_new_message_options: ccsip_api_options_ind returned: SIP_SUCCESS
*Feb 19 11:10:42.645: //31230/D5BF2BC9BF3A/SIP/State/sipSPIChangeState: 0x7077BF84 : State change from (STATE_IDLE, SUBSTATE_NONE) to (SIP_STATE_OPTIONS_WAIT, SUBSTATE_NONE)
*Feb 19 11:10:42.645: //31230/D5BF2BC9BF3A/SIP/Info/sipSPIUaddCcbToUASReqTable: ****Adding to UAS Request table.
*Feb 19 11:10:42.645: //31230/D5BF2BC9BF3A/SIP/Info/sipSPIUaddCcbToTable: Added to table. ccb=0x7077BF84 key=isbcoc2au4b7s4oco2tobse77otchdeeepk7@SoftX3000
*Feb 19 11:10:42.645: //31230/D5BF2BC9BF3A/SIP/Info/sipSPIUaddccCallIdToTable: Adding call id 79FE to table
*Feb 19 11:10:42.645: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 38
*Feb 19 11:10:42.645: //31230/D5BF2BC9BF3A/SIP/Info/sipSPISendOptionsResponse: Associated container=0x7117DA68 to Options Response
*Feb 19 11:10:42.645: //31230/D5BF2BC9BF3A/SIP/Transport/sipSPITransportSendMessage: msg=0x70861A28, addr=10.200.7.157, port=5060, sentBy_port=5060, is_req=0, transport=1, switch=0, callBack=0x615E9E98
*Feb 19 11:10:42.645: //31230/D5BF2BC9BF3A/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*Feb 19 11:10:42.645: //31230/D5BF2BC9BF3A/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
*Feb 19 11:10:42.649: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x70861A28, addr=10.200.7.157, port=5060, connId=0 for UDP
*Feb 19 11:10:42.649: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.66.7.218>;tag=248B1B10-173010.66.7.218>
CSeq: 1 OPTIONS
Supported: 100rel,resource-priority,replaces
Accept: application/sdp
Content-Type: application/sdp
Content-Length: 164
v=0
o=CiscoSystemsSIP-GW-UserAgent 2842 1907 IN IP4 10.106.78.7
s=SIP Call
c=IN IP4 10.66.7.218
t=0 0
*Feb 19 11:10:47.421: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpSocketReads: Msg enqueued for SPI with IP addr: 10.200.7.157:5060
*Feb 19 11:10:47.421: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
*Feb 19 11:10:47.421: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x00000000
*Feb 19 11:10:47.421: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
*Feb 19 11:10:47.425: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
Record-Route: <10.200.7.157:5060>10.200.7.157:5060>
To: <0097339982779>;tag=sbc0804h4bsb2sa-CC-300097339982779>
CSeq: 101 INVITE
Contact: <0097339982779>0097339982779>
Allow: INVITE,ACK,OPTIONS,BYE,CANCEL,REGISTER,INFO,PRACK,SUBSCRIBE,NOTIFY,UPDATE,MESSAGE,REFER
Require: 100rel
RSeq: 1
Content-Length: 371
v=0
o=- 28471578 28471578 IN IP4 10.200.7.157
s=SBC call
c=IN IP4 10.200.7.157
t=0 0
a=fmtp:97 0-15
*Feb 19 11:10:47.425: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentGTD: No GTD found in inbound container
*Feb 19 11:10:47.425: //31229/D5950F0DBF34/SIP/Info/ccsip_api_call_alert: SDP in 180 will be ignored if present: No early media cut through
*Feb 19 11:10:47.425: //31229/D5950F0DBF34/SIP/Error/sipSPIProcessCallInfoHeader: Call-Info header with for Unsolicited Notify Absent,Disabling Unsolicited Notifies
*Feb 19 11:10:47.425: //31229/D5950F0DBF34/SIP/Info/ccsip_api_call_alert: SDP Body either absent or ignored in 180 RINGING:- will wait for 200 OK to do negotiation.
*Feb 19 11:10:47.425: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateRawMsg: No GTD passed.
*Feb 19 11:10:47.425: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_MEDIA_EVENT
*Feb 19 11:10:47.425: //31229/D5950F0DBF34/SIP/Info/HandleSIP1xxRinging: ccsip_api_call_alert returned: SIP_SUCCESS
*Feb 19 11:10:47.425: //31229/D5950F0DBF34/SIP/State/sipSPIChangeState: 0x70795398 : State change from (STATE_RECD_PROCEEDING, SUBSTATE_PROCEEDING_PROCEEDING) to (STATE_RECD_PROCEEDING, SUBSTATE_NONE)
*Feb 19 11:10:47.425: //31229/D5950F0DBF34/SIP/State/sipSPIChangeState: 0x70795398 : State change from (STATE_RECD_PROCEEDING, SUBSTATE_NONE) to (SIP_STATE_SEND_PRACK, SUBSTATE_NONE)
*Feb 19 11:10:47.425: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 29
*Feb 19 11:10:47.425: //31229/D5950F0DBF34/SIP/Info/act_handle_app_media_event: method = 105 state = 23
*Feb 19 11:10:47.425: //31229/D5950F0DBF34/SIP/Info/act_handle_app_media_event: Received media sip event SIP_REQUEST_ANSWER
*Feb 19 11:10:47.425: //31229/D5950F0DBF34/SIP/State/sipSPIChangeState: 0x70795398 : State change from (SIP_STATE_SEND_PRACK, SUBSTATE_NONE) to (STATE_RECD_PROCEEDING, SUBSTATE_NONE)
*Feb 19 11:10:47.425: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAddRouteHeaders: status = TRUE Route: <10.200.7.157:5060>10.200.7.157:5060>
*Feb 19 11:10:47.425: //31229/D5950F0DBF34/SIP/Transport/sipSPISendPrack: Sending PRACK to the transport layer
*Feb 19 11:10:47.425: //31229/D5950F0DBF34/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
*Feb 19 11:10:47.425: //31229/D5950F0DBF34/SIP/Transport/sipSPITransportSendMessage: msg=0x70861A28, addr=10.200.7.157, port=5060, sentBy_port=0, is_req=1, transport=1, switch=0, callBack=0x615E7910
*Feb 19 11:10:47.425: //31229/D5950F0DBF34/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*Feb 19 11:10:47.425: //31229/D5950F0DBF34/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
*Feb 19 11:10:47.425: //31229/D5950F0DBF34/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x70861A28
*Feb 19 11:10:47.425: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x70861A28, addr=10.200.7.157, port=5060, connId=1 for UDP
*Feb 19 11:10:47.425: //31229/D5950F0DBF34/SIP/Info/sentPrack: Sent Prack Request, starting PrackTimer
*Feb 19 11:10:47.425: //31229/D5950F0DBF34/SIP/State/sipSPIChangeState: 0x70795398 : State change from (STATE_RECD_PROCEEDING, SUBSTATE_NONE) to (STATE_RECD_PROCEEDING, SUBSTATE_NONE)
*Feb 19 11:10:47.425: //31229/D5950F0DBF34/SIP/Info/sact_app_media_event_send_request: Transaction active. Facilities will be queued.
*Feb 19 11:10:47.425: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_ALERTING
Sent:
PRACK sip:0097339982779@10.200.7.157:5060;user=phone SIP/2.0
Via: SIP/2.0/UDP 10.66.7.218:5060;branch=z9hG4bK3F937F
CSeq: 102 PRACK
RAck: 1 101 INVITE
Max-Forwards: 70
Content-Length: 0
*Feb 19 11:10:47.425: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 5
*Feb 19 11:10:47.425: //31228/D5950F0DBF34/SIP/Info/sipSPIUaddCcbToUASRespTable: ****Adding to UAS Response table.
*Feb 19 11:10:47.425: //31228/D5950F0DBF34/SIP/Info/sipSPIUaddCcbToTable: Added to table. ccb=0x70782DB8 key=6014400-12315c11-adf1-1ea0680a@10.104.160.30248B2DBC-3A7
*Feb 19 11:10:47.425: //31228/D5950F0DBF34/SIP/Info/ccsip_api_update_allowed: UPDATE(1) allowed
*Feb 19 11:10:47.425: //31228/D5950F0DBF34/SIP/Event/sipSPICreateRpid: Received Octet3A=0x00 -> Setting ;screen=no ;privacy=off
*Feb 19 11:10:47.425: //31228/D5950F0DBF34/SIP/Transport/sipSPISendInviteResponse: Sending 180 Response to the Transport Layer
*Feb 19 11:10:47.425: //31228/D5950F0DBF34/SIP/Transport/sipSPITransportSendMessage: msg=0x70861A28, addr=10.104.160.30, port=41357, sentBy_port=5060, is_req=0, transport=2, switch=0, callBack=0x615E77D0
*Feb 19 11:10:47.425: //31228/D5950F0DBF34/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*Feb 19 11:10:47.425: //31228/D5950F0DBF34/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
*Feb 19 11:10:47.425: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x70861A28, addr=10.104.160.30, port=41357, connId=1 for TCP
*Feb 19 11:10:47.425: //31228/D5950F0DBF34/SIP/Info/sentInviteResponse18x: Sent a 18x Response
*Feb 19 11:10:47.425: //31228/D5950F0DBF34/SIP/State/sipSPIChangeState: 0x70782DB8 : State change from (STATE_RECD_INVITE, SUBSTATE_NONE) to (STATE_SENT_ALERTING, SUBSTATE_NONE)
Sent:
SIP/2.0 180 Ringing
To: <90097339982779>;tag=248B2DBC-3A790097339982779>
CSeq: 101 INVITE
Remote-Party-ID: <0097339982779>;party=called;screen=no;privacy=off0097339982779>
Content-Length: 0
*Feb 19 11:10:47.477: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpSocketReads: Msg enqueued for SPI with IP addr: 10.200.7.157:5060
*Feb 19 11:10:47.477: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
*Feb 19 11:10:47.477: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x00000000
*Feb 19 11:10:47.477: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
*Feb 19 11:10:47.481: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 PRACK
Content-Length: 0
*Feb 19 11:10:47.481: //31229/D5950F0DBF34/SIP/Info/act_recdproc_new_message_response: Transaction Complete. Lock on Facilities released.
*Feb 19 11:10:47.481: //31229/D5950F0DBF34/SIP/Info/ccsip_api_update_allowed: UPDATE(2) allowed
*Feb 19 11:10:54.581: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpSocketReads: Msg enqueued for SPI with IP addr: 10.200.7.157:5060
*Feb 19 11:10:54.581: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
*Feb 19 11:10:54.581: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x00000000
*Feb 19 11:10:54.581: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
*Feb 19 11:10:54.581: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Content-Length: 371
v=0
o=- 28471578 28471579 IN IP4 10.200.7.157
s=SBC call
t=0 0
a=fmtp:97 0-15
*Feb 19 11:10:54.581: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentGTD: No GTD found in inbound container
*Feb 19 11:10:54.581: //31229/D5950F0DBF34/SIP/Info/sipSPIhandle200OKInvite: Transaction active. Facilities will be queued.
*Feb 19 11:10:54.581: //31229/D5950F0DBF34/SIP/Info/sipSPIhandle200OKInvite: *** This ccb is the parent
*Feb 19 11:10:54.581: //31228/D5950F0DBF34/SIP/Info/sipSPIUupdateCcCallIds: Old src/dest ccCallids: -1/-1, new src/dest ccCallids: 31228/31229
*Feb 19 11:10:54.581: //31228/D5950F0DBF34/SIP/Info/sipSPIUupdateCcCallIds: Old streamcallid=-1, new streamcallid=31228
*Feb 19 11:10:54.581: //31229/D5950F0DBF34/SIP/Error/sipSPIProcessCallInfoHeader: Call-Info header with for Unsolicited Notify Absent,Disabling Unsolicited Notifies
*Feb 19 11:10:54.581: //31229/D5950F0DBF34/SIP/Info/sipSPICompareRespMediaInfo: No Comparsion needed as 18x response SDP is either absent or ignored
*Feb 19 11:10:54.585: //31229/D5950F0DBF34/SIP/Info/sipSPIDoMediaNegotiation: Number of m-lines = 1
*Feb 19 11:10:54.585: //31229/D5950F0DBF34/SIP/Info/sipSPIDoAudioNegotiation: Codec (g711alaw) Negotiation Successful on Static Payload for m-line 1
*Feb 19 11:10:54.585: //31229/D5950F0DBF34/SIP/Info/sipSPIDoPtimeNegotiation: No ptime present or multiple ptime attributes that can't be handled
*Feb 19 11:10:54.585: //31229/D5950F0DBF34/SIP/Info/sipSPIDoDTMFRelayNegotiation: m-line index 1
*Feb 19 11:10:54.585: //31229/D5950F0DBF34/SIP/Info/sipSPIDoDTMFRelayNegotiation: Requested DTMF-RELAY option(s) not found in Preferred DTMF-RELAY option list!
*Feb 19 11:10:54.585: //31229/D5950F0DBF34/SIP/Info/sipSPIStreamTypeAndDtmfRelay: DTMF Relay mode: Inband Voice
*Feb 19 11:10:54.585: //-1/xxxxxxxxxxxx/SIP/Info/sip_sdp_get_modem_relay_cap_params: NSE payload from X-cap = 0
*Feb 19 11:10:54.585: //31229/D5950F0DBF34/SIP/Info/sip_select_modem_relay_params: X-tmr not present in SDP. Disable modem relay
*Feb 19 11:10:54.585: //31229/D5950F0DBF34/SIP/Info/sipSPIGetSDPDirectionAttribute: No direction attribute present or multiple direction attributes that can't be handled for m-line:1 and num-a-lines:0
*Feb 19 11:10:54.585: //31229/D5950F0DBF34/SIP/Info/sipSPIDoAudioNegotiation: Codec negotiation successful for media line 1
payload_type=8, codec_bytes=160, codec=g711alaw, dtmf_relay=inband-voice
stream_type=voice-only (0), dest_ip_address=10.200.7.157, dest_port=37372
*Feb 19 11:10:54.585: //31229/D5950F0DBF34/SIP/State/sipSPIChangeStreamState: Stream (callid = -1) State changed from (STREAM_DEAD) to (STREAM_ADDING)
*Feb 19 11:10:54.585: //31229/D5950F0DBF34/SIP/Media/sipSPIUpdCallWithSdpInfo:
Preferred Codec : g711alaw, bytes :160
Preferred DTMF relay : h245-alphanumeric
Preferred NTE payload : 101
Early Media : No
Delayed Media : Yes
Bridge Done : No
New Media : No
DSP DNLD Reqd : No
*Feb 19 11:10:54.585: //31229/D5950F0DBF34/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.66.7.218
*Feb 19 11:10:54.585: //31229/D5950F0DBF34/SIP/Info/sipSPI_ipip_report_media_to_peer:
callId 31229 peer 31228 flags 0x400001
*Feb 19 11:10:54.585: //31229/D5950F0DBF34/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
CallID 31229, sdp 0x68583358 channels 0x70796468
*Feb 19 11:10:54.585: //31229/D5950F0DBF34/SIP/Info/copy_channels:
callId 31229 size 0 ptr 0x66CE6898)
Hndl ptype 8 mline 1
*Feb 19 11:10:54.585: //31229/D5950F0DBF34/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Selecting codec g711alaw
*Feb 19 11:10:54.585: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711alaw codecbytes :160, ptime: 20
*Feb 19 11:10:54.585: //31229/D5950F0DBF34/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Media negotiation done: stream->negotiated_ptime=0,stream->negotiated_codec_bytes=160, coverted ptime=20 stream->mline_index=1, media_ndx=1
Adding codec 6 ptype 8 time 20, bytes 160 as channel 0 mline 1 ss 0 10.200.7.157:37372
Hndl ptype 0 mline 1
*Feb 19 11:10:54.585: //31229/D5950F0DBF34/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Selecting codec g711ulaw
Hndl ptype 18 mline 1
*Feb 19 11:10:54.585: //31229/D5950F0DBF34/SIP/Media/sipSPISelectCodecVersion: Codec (g729br8) is not in preferred list
*Feb 19 11:10:54.585: //31229/D5950F0DBF34/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: An exact codec match not configured, using interoperable codec g729r8 pre-ietf
*Feb 19 11:10:54.585: //31229/D5950F0DBF34/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Selecting codec g729r8 pre-ietf
Hndl ptype 4 mline 1
*Feb 19 11:10:54.585: //31229/D5950F0DBF34/SIP/Media/sipSPISelectCodecVersion: Codec (No Codec ) is not in preferred list
Hndl ptype 2 mline 1
*Feb 19 11:10:54.585: //31229/D5950F0DBF34/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Selecting codec g726r32
Hndl ptype 98 mline 1
Hndl ptype 99 mline 1
Hndl ptype 97 mline 1
Report initial call media
*Feb 19 11:10:54.585: //31229/D5950F0DBF34/SIP/Info/ccsip_get_rtcp_session_parameters: CURRENT VALUES: stream_callid=-1, current_seq_num=0xAFF
*Feb 19 11:10:54.585: //31229/D5950F0DBF34/SIP/Info/ccsip_get_rtcp_session_parameters: NEW VALUES: stream_callid=-1, current_seq_num=0x0
*Feb 19 11:10:54.585: //31229/D5950F0DBF34/SIP/Info/ccsip_do_caps_ind: Load DSP with codec: g711alaw, Bytes=160
*Feb 19 11:10:54.585: //31229/D5950F0DBF34/SIP/Media/sipSPISetStreamInfo: 0 Active Streams
*Feb 19 11:10:54.585: //31229/D5950F0DBF34/SIP/Media/sipSPISetStreamInfo: Number of active streams is zero (0)!
caps.stream_count=0,caps.stream[0].stream_type=0xFFFF, caps.stream_list.xmitFunc=
*Feb 19 11:10:54.585: //31229/D5950F0DBF34/SIP/Media/sipSPISetStreamInfo: ??unknown??, caps.stream_list.context=
*Feb 19 11:10:54.585: //31229/D5950F0DBF34/SIP/Media/sipSPISetStreamInfo: 0x0 (gccb)
*Feb 19 11:10:54.585: //31229/D5950F0DBF34/SIP/Info/sipSPISetDTMFRelayMode: Set DSP for dtmf-relay = CC_CAP_DTMF_RELAY_INBAND_VOICE_AND_OOB
*Feb 19 11:10:54.585: //31229/D5950F0DBF34/SIP/Info/sip_set_modem_caps: Preferred (or the one that came from DSM) modem relay=0, from CLI config=0
*Feb 19 11:10:54.585: //31229/D5950F0DBF34/SIP/Info/sip_set_modem_caps: Disabling Modem Relay...
*Feb 19 11:10:54.585: //31229/D5950F0DBF34/SIP/Info/sip_set_modem_caps: Negotiation already Done. Set negotiated Modem caps and generate SDP Xcap list
*Feb 19 11:10:54.585: //31229/D5950F0DBF34/SIP/Info/sip_set_modem_caps: Modem Relay & Passthru both disabled
*Feb 19 11:10:54.585: //31229/D5950F0DBF34/SIP/Info/sip_set_modem_caps: nse payload = 0, ptru mode = 0, ptru-codec=0, redundancy=0, xid=0, relay=0, sprt-retry=12, latecncy=200, compres-dir=3, dict=1024, strnlen=32
*Feb 19 11:10:54.585: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_caps_ind:
destCallID=31228, srcCallID=31229,
peer_ccb->call_info.currentLocalName=,
peer_ccb->call_info.currentRemoteName=,
ccb->call_info.currentRemoteName=Aslam Shaik
*Feb 19 11:10:54.585: //31228/D5950F0DBF34/SIP/Info/ccsip_caps_ind: Negotiation not done yet:: Load DSP with preferred codec : g711alaw, Bytes=160, payload: 8
*Feb 19 11:10:54.585: //31228/D5950F0DBF34/SIP/Info/ccsip_caps_ind: Set forking flag to 0x0
*Feb 19 11:10:54.585: //31228/D5950F0DBF34/SIP/Info/sip_set_modem_caps: Preferred (or the one that came from DSM) modem relay=0, from CLI config=0
*Feb 19 11:10:54.585: //31228/D5950F0DBF34/SIP/Info/sip_set_modem_caps: Disabling Modem Relay...
*Feb 19 11:10:54.585: //31228/D5950F0DBF34/SIP/Info/sip_generate_sdp_xcaps_list: Modem Relay and T38 disabled. X-cap not needed
*Feb 19 11:10:54.585: //31228/D5950F0DBF34/SIP/Info/sip_set_modem_caps: Negotiation NOT yet Done. Set the configured values and generate SDP Xcap list
*Feb 19 11:10:54.585: //31228/D5950F0DBF34/SIP/Info/sip_set_modem_caps: Modem Relay & Passthru both disabled
*Feb 19 11:10:54.585: //31228/D5950F0DBF34/SIP/Info/sip_set_modem_caps: nse payload = 100, ptru mode = 0, ptru-codec=0, redundancy=0, xid=1, relay=0, sprt-retry=12, latecncy=200, compres-dir=3, dict=1024, strnlen=32
*Feb 19 11:10:54.585: //31228/D5950F0DBF34/SIP/Media/sipSPISetStreamInfo: 0 Active Streams
*Feb 19 11:10:54.585: //31228/D5950F0DBF34/SIP/Media/sipSPISetStreamInfo: Number of active streams is zero (0)!
*Feb 19 11:10:54.585: //31228/D5950F0DBF34/SIP/Media/sipSPISetStreamInfo: ??unknown??, caps.stream_list.context=
*Feb 19 11:10:54.585: //31228/D5950F0DBF34/SIP/Media/sipSPISetStreamInfo: 0x0 (gccb)
*Feb 19 11:10:54.585: //31228/D5950F0DBF34/SIP/Info/ccsip_caps_ind: Load DSP with codec : g711alaw, Bytes=160, payload = 8
*Feb 19 11:10:54.585: //31228/D5950F0DBF34/SIP/Info/ccsip_caps_ind: ccsip_caps_ind: ccb->pld.flags_ipip = 0x400003
*Feb 19 11:10:54.585: //31229/D5950F0DBF34/SIP/Info/ccsip_caps_ack: Set forking flag to 0x0
callId 31229 size 108 ptr 0x66CE4EA0)
*Feb 19 11:10:54.585: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_event_handler:
*Feb 19 11:10:54.585: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_event_handler: switch(ev.ev_id: 141)
*Feb 19 11:10:54.585: //31228/D5950F0DBF34/SIP/Info/ccsip_event_handler:
ccsip_event_handler: peer ID 31229 chans 0x66CE4EA0 event 141 flags 0xC0201C 0x300 0x400003 data 0x66CE4EA0
ccsip_event_handler: CC_EV_H245_OPEN_CHANNEL_IND: peer ID 31229 chans 0x66CE4EA0 event 141 flags 0xC0201C 0x300 0x400003 data 0x66CE4EA0
*Feb 19 11:10:54.585: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_NEW_MEDIA
ccsip_event_handler: set event->type = SIPSPI_EV_CC_NEW_MEDIA!: peer ID 31229 chans 0x66CE4EA0 event 141 flags 0xC0201C 0x300 0x400003 data 0x66CE4EA0
*Feb 19 11:10:54.585: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_event_handler: CC_R_SUCCESS_WITH_CONFIRMED
Stream type : voice-only
Media line : 1
State : STREAM_ADDING (2)
Callid : -1
Negotiated Codec : g711alaw, bytes :160
Nego. Codec payload : 8 (tx), 8 (rx)
Negotiated DTMF relay : inband-voice
Negotiated NTE payload : 0 (tx), 0 (rx)
Negotiated CN payload : 0
Media Srce Addr/Port : 10.66.7.218:0
Media Dest Addr/Port : 10.200.7.157:37372
*Feb 19 11:10:54.585: //31229/D5950F0DBF34/SIP/Info/sipSPIProcessMediaChanges: sipSPIProcessMediaChanges
*Feb 19 11:10:54.585: //31229/D5950F0DBF34/SIP/Info/sipSPIhandle200OKInvite: ccsip_api_call_connect_media returned: SIP_SUCCESS
*Feb 19 11:10:54.585: //31229/D5950F0DBF34/SIP/State/sipSPIChangeState: 0x70795398 : State change from (STATE_RECD_PROCEEDING, SUBSTATE_NONE) to (STATE_RECD_PROCEEDING, SUBSTATE_NONE)
*Feb 19 11:10:54.585: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateRawMsg: No GTD passed.
*Feb 19 11:10:54.585: //31229/D5950F0DBF34/SIP/Info/sipSPIhandle200OKInvite: ccsip_api_call_connected returned: SIP_SUCCESS_DELAYED_MEDIA
*Feb 19 11:10:54.585: //31229/D5950F0DBF34/SIP/State/sipSPIChangeState: 0x70795398 : State change from (STATE_RECD_PROCEEDING, SUBSTATE_NONE) to (SIP_STATE_RECD_SUCCESS, SUBSTATE_NONE)
*Feb 19 11:10:54.585: //31229/D5950F0DBF34/SIP/Info/sipSPIhandle200OKInvite: starting MediaAck timer(2)
*Feb 19 11:10:54.585: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 26
*Feb 19 11:10:54.585: //31228/D5950F0DBF34/SIP/Info/sipSPI_ipip_handle_channel_info:
CCSIP:callID 31228 ft: 1, inc 4, 10.200.7.157:37372, codec 6
*Feb 19 11:10:54.585: //31228/D5950F0DBF34/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp:
callid 31228, channels 0x66CE4EA0 caps 0x66CE89A8
*Feb 19 11:10:54.585: //31228/D5950F0DBF34/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp: Peer cap provided: callid = 31228, peer dtmf = 3
*Feb 19 11:10:54.585: //31228/D5950F0DBF34/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp: callid = 31228, peer not doing RFC2833, peer dtmf = 3, enable NTE_ASSUMED
pref dtmf 101
*Feb 19 11:10:54.585: //31228/D5950F0DBF34/SIP/Info/sipSPIProcessMediaChanges: sipSPIProcessMediaChanges
*Feb 19 11:10:54.585: //31228/D5950F0DBF34/SIP/Info/ccsip_bridge: confID = 183, srcCallID = 31228, dstCallID = 31229
*Feb 19 11:10:54.585: //31228/D5950F0DBF34/SIP/Info/sipSPIUupdateCcCallIds: Old src/dest ccCallids: 31228/31229, new src/dest ccCallids: 31228/31229
*Feb 19 11:10:54.585: //31228/D5950F0DBF34/SIP/Info/sipSPIUupdateCcCallIds: Old streamcallid=31228, new streamcallid=31228
*Feb 19 11:10:54.585: //31228/D5950F0DBF34/SIP/Info/ccsip_bridge: xcoder_attached = 0, xmitFunc = 1660080152, ccb xmitFunc = 1660080152
*Feb 19 11:10:54.585: //31228/D5950F0DBF34/SIP/Info/ccsip_bridge: ccsip_bridge: Delayed Media case
*Feb 19 11:10:54.585: //31229/D5950F0DBF34/SIP/Info/ccsip_bridge: confID = 183, srcCallID = 31229, dstCallID = 31228
*Feb 19 11:10:54.585: //31229/D5950F0DBF34/SIP/Info/sipSPIUupdateCcCallIds: Old src/dest ccCallids: -1/-1, new src/dest ccCallids: 31229/31228
*Feb 19 11:10:54.585: //31229/D5950F0DBF34/SIP/Info/sipSPIUupdateCcCallIds: Old streamcallid=-1, new streamcallid=31229
*Feb 19 11:10:54.585: //31229/D5950F0DBF34/SIP/Info/ccsip_bridge: xcoder_attached = 0, xmitFunc = 1660080152, ccb xmitFunc = 1660080152
*Feb 19 11:10:54.585: //31229/D5950F0DBF34/SIP/Info/ccsip_bridge: ccsip_bridge: Delayed Media case
*Feb 19 11:10:54.585: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_CONNECT
*Feb 19 11:10:54.585: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_MEDIA_EVENT
*Feb 19 11:10:54.589: //31227/C9CA4240BF33/SIP/Info/sipSPIUdeleteccCallIdFromTable: Removing call id 79FB
*Feb 19 11:10:54.589: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIDeleteContextFromTable: Context for key=[31240] removed.
*Feb 19 11:10:54.589: //31227/C9CA4240BF33/SIP/Info/sipSPIUdeleteCcbFromUASReqTable: ****Deleting from UAS Request table.
*Feb 19 11:10:54.589: //31227/C9CA4240BF33/SIP/Info/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x680BCF18 key=isbchuhdpahep477bpoedh4epk7sb7esasc4@SoftX3000
*Feb 19 11:10:54.589: //31227/C9CA4240BF33/SIP/Info/sipSPIUdeleteCcbFromUASRespTable: ****Deleting from UAS Response table.
*Feb 19 11:10:54.589: //31227/C9CA4240BF33/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
*Feb 19 11:10:54.589: //31227/C9CA4240BF33/SIP/Info/sipSPIUfreeOneCCB: Freeing ccb 680BCF18
*Feb 19 11:10:54.589: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 6
*Feb 19 11:10:54.589: //31228/D5950F0DBF34/SIP/Event/sipSPICreateRpid: Received Octet3A=0x00 -> Setting ;screen=no ;privacy=off
*Feb 19 11:10:54.589: //31228/D5950F0DBF34/SIP/Info/sipSPISendInviteResponse: Associated container=0x7117BEFC to Invite Response 200
*Feb 19 11:10:54.589: //31228/D5950F0DBF34/SIP/Transport/sipSPISendInviteResponse: Sending 200OK Response to the Transport Layer
*Feb 19 11:10:54.589: //31228/D5950F0DBF34/SIP/Transport/sipSPITransportSendMessage: msg=0x70BB4CD0, addr=10.104.160.30, port=41357, sentBy_port=5060, is_req=0, transport=2, switch=0, callBack=0x615E7A58
*Feb 19 11:10:54.589: //31228/D5950F0DBF34/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*Feb 19 11:10:54.589: //31228/D5950F0DBF34/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
*Feb 19 11:10:54.589: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x70BB4CD0, addr=10.104.160.30, port=41357, connId=1 for TCP
*Feb 19 11:10:54.589: //31228/D5950F0DBF34/SIP/Info/sentInviteResponse200: Sent 200Ok for Invite in state STATE_SENT_ALERTING
*Feb 19 11:10:54.589: //-1/xxxxxxxxxxxx/SIP/Info/sentInviteResponse200: Transaction active. Facilities will be queued.
*Feb 19 11:10:54.589: //31228/D5950F0DBF34/SIP/State/sipSPIChangeState: 0x70782DB8 : State change from (STATE_SENT_ALERTING, SUBSTATE_NONE) to (STATE_SENT_SUCCESS, SUBSTATE_NONE)
*Feb 19 11:10:54.589: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 29
*Feb 19 11:10:54.589: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 101 INVITE
Supported: replaces
Session-Expires: 1800;refresher=uac
Require: timer
Content-Disposition: session;handling=required
Content-Length: 256
v=0
o=CiscoSystemsSIP-GW-UserAgent 9262 4326 IN IP4 10.106.78.7
s=SIP Call
c=IN IP4 10.106.78.7
t=0 0
m=audio 17372 RTP/AVP 8 0 101
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
*Feb 19 11:10:54.857: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
*Feb 19 11:10:54.857: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x00000000
*Feb 19 11:10:54.857: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x7095EC90, addr=10.104.160.30, port=41357, connid=1, transport=TCP
*Feb 19 11:10:54.857: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:0097339982779@10.106.78.7:5060;transport=tcp SIP/2.0
Content-Length: 212
Via: SIP/2.0/TCP 10.104.160.30:5060;branch=z9hG4bKeaa17878c67
CSeq: 101 ACK
Max-Forwards: 70
v=0
o=CiscoSystemsCCM-SIP 2000 1 IN IP4 10.104.160.30
s=SIP Call
c=IN IP4 10.106.71.2
t=0 0
m=audio 31760 RTP/AVP 0 101
a=ptime:20
a=fmtp:101 0-15
*Feb 19 11:10:54.857: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
*Feb 19 11:10:54.857: //31228/D5950F0DBF34/SIP/Info/sipSPIFindCcbUASRespTable: *****CCB found in UAS Response table. ccb=0x70782DB8
*Feb 19 11:10:54.857: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.104.160.30,Port 41357, Transport 2, SentBy Port 5060
*Feb 19 11:10:54.857: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
*Feb 19 11:10:54.857: //31228/D5950F0DBF34/SIP/Info/act_sentsucc_new_message_request: Transaction Complete. Lock on Facilities released.
*Feb 19 11:10:54.857: //31228/D5950F0DBF34/SIP/Error/sipSPIProcessCallInfoHeader: Call-Info header with for Unsolicited Notify Absent,Disabling Unsolicited Notifies
*Feb 19 11:10:54.857: //31228/D5950F0DBF34/SIP/Info/sipSPIDoMediaNegotiation: Number of m-lines = 1
*Feb 19 11:10:54.857: //-1/xxxxxxxxxxxx/SIP/Info/rtpAvpCodec_to_voipCodec: Dynamic Payload :101 in SDP Body
*Feb 19 11:10:54.857: //31228/D5950F0DBF34/SIP/Info/sipSPIDoAudioNegotiation: No matching voice codec found for m-line 1
*Feb 19 11:10:54.857: //31228/D5950F0DBF34/SIP/Info/sipSPIDoDTMFRelayNegotiation: m-line index 1
*Feb 19 11:10:54.857: //31228/D5950F0DBF34/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) could not be reserved.
*Feb 19 11:10:54.857: //31228/D5950F0DBF34/SIP/Info/sipSPIDoDTMFRelayNegotiation: RTP-NTE DTMF relay option
*Feb 19 11:10:54.857: //31228/D5950F0DBF34/SIP/Info/sipSPIDoDTMFRelayNegotiation: Case of partial named event(NE) match in fmtp list of events.
*Feb 19 11:10:54.857: //31228/D5950F0DBF34/SIP/Info/sipSPIGetSDPDirectionAttribute: No direction attribute present or multiple direction attributes that can't be handled for m-line:1 and num-a-lines:0
*Feb 19 11:10:54.857: //31228/D5950F0DBF34/SIP/Error/sipSPIDoAudioNegotiation: Media negotiation failed for m-line 1
*Feb 19 11:10:54.857: //31228/D5950F0DBF34/SIP/Error/sipSPIDoMediaNegotiation:
no valid fax or audio streams
*Feb 19 11:10:54.857: //31228/D5950F0DBF34/SIP/Error/sipSPIProcessAckMedia: Disconnecting due to MediaNego failure
*Feb 19 11:10:54.857: //31228/D5950F0DBF34/SIP/Info/ccsip_set_cc_cause_for_spi_err: Categorized cause:65, category:278
*Feb 19 11:10:54.857: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_set_release_source_for_peer: ownCallId[31228], src[6]
*Feb 19 11:10:54.857: //31228/D5950F0DBF34/SIP/Info/ccsip_api_request_answer: ACK handling retval: SIP_UNACCEPTABLE_MEDIA_ERR
*Feb 19 11:10:54.857: //31228/D5950F0DBF34/SIP/Info/act_sentsucc_new_message_request: ccsip_api_request_answer return val:SIP_UNACCEPTABLE_MEDIA_ERR
*Feb 19 11:10:54.857: //31228/D5950F0DBF34/SIP/Info/sipSPIInitiateDisconnect: Initiate call disconnect(65) for incoming call
*Feb 19 11:10:54.857: //31228/D5950F0DBF34/SIP/State/sipSPIChangeState: 0x70782DB8 : State change from (STATE_SENT_SUCCESS, SUBSTATE_NONE) to (STATE_DISCONNECTING, SUBSTATE_NONE)
*Feb 19 11:10:54.857: //31228/D5950F0DBF34/SIP/Info/sipSPIStopHoldTimer: Stopping hold timer
*Feb 19 11:10:54.861: //31228/D5950F0DBF34/SIP/Transport/sipSPISendBye: Sending BYE to the transport layer
*Feb 19 11:10:54.861: //31228/D5950F0DBF34/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Dial peer configuration, Switch Transport is FALSE
*Feb 19 11:10:54.861: //31228/D5950F0DBF34/SIP/Transport/sipSPITransportSendMessage: msg=0x704D4150, addr=10.104.160.30, port=5060, sentBy_port=0, is_req=1, transport=2, switch=0, callBack=0x615E7CB8
*Feb 19 11:10:54.861: //31228/D5950F0DBF34/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*Feb 19 11:10:54.861: //31228/D5950F0DBF34/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
*Feb 19 11:10:54.861: //31228/D5950F0DBF34/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x704D4150
*Feb 19 11:10:54.861: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x704D4150, addr=10.104.160.30, port=5060, connId=2 for TCP
*Feb 19 11:10:54.861: //31228/D5950F0DBF34/SIP/Info/sentByeDisconnecting: Sent Bye Request, starting DisconnectTimer
*Feb 19 11:10:54.861: //31228/D5950F0DBF34/SIP/State/sipSPIChangeState: 0x70782DB8 : State change from (STATE_DISCONNECTING, SUBSTATE_NONE) to (STATE_DISCONNECTING, SUBSTATE_NONE)
*Feb 19 11:10:54.861: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:2169301@10.104.160.30:5060;transport=tcp SIP/2.0
Via: SIP/2.0/TCP 10.106.78.7:5060;branch=z9hG4bK3FA10B7
From: <90097339982779>;tag=248B2DBC-3A790097339982779>
To: "Aslam Shaik" <2169301>;tag=895022dc-e465-496e-9fcb-fa8b46f34648-477193402169301>
Date: Tue, 19 Feb 2013 11:10:54 GMT
Max-Forwards: 70
Timestamp: 1361272254
CSeq: 101 BYE
Reason: Q.850;cause=86
Content-Length: 0
*Feb 19 11:10:54.861: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
*Feb 19 11:10:54.861: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 7
*Feb 19 11:10:54.861: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAddRouteHeaders: status = TRUE Route: <10.200.7.157:5060>10.200.7.157:5060>
*Feb 19 11:10:54.861: //31229/D5950F0DBF34/SIP/Info/sipSPISendAck: Associated container=0x7117C244 to Ack
*Feb 19 11:10:54.861: //31229/D5950F0DBF34/SIP/Transport/sipSPISendAck: Sending ACK to the transport layer
*Feb 19 11:10:54.861: //31229/D5950F0DBF34/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
*Feb 19 11:10:54.861: //31229/D5950F0DBF34/SIP/Transport/sipSPITransportSendMessage: msg=0x66CE4F9C, addr=10.200.7.157, port=5060, sentBy_port=0, is_req=1, transport=1, switch=0, callBack=0x00000000
*Feb 19 11:10:54.861: //31229/D5950F0DBF34/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*Feb 19 11:10:54.861: //31229/D5950F0DBF34/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
*Feb 19 11:10:54.861: //31229/D5950F0DBF34/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x66CE4F9C
*Feb 19 11:10:54.861: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x66CE4F9C, addr=10.200.7.157, port=5060, connId=1 for UDP
*Feb 19 11:10:54.861: //31229/D5950F0DBF34/SIP/State/sipSPIChangeState: 0x70795398 : State change from (SIP_STATE_RECD_SUCCESS, SUBSTATE_NONE) to (STATE_DISCONNECTING, SUBSTATE_NONE)
*Feb 19 11:10:54.861: //31229/D5950F0DBF34/SIP/Info/sipSPIPushOrigRequestContainerIntoHolder: Request Container Holder is above threshold...trimming
*Feb 19 11:10:54.861: //31229/D5950F0DBF34/SIP/Info/sipSPIStopHoldTimer: Stopping hold timer
*Feb 19 11:10:54.861: //31229/D5950F0DBF34/SIP/Transport/sipSPISendBye: Sending BYE to the transport layer
Sent:
BYE sip:0097339982779@10.200.7.157:5060;user=phone SIP/2.0
Via: SIP/2.0/UDP 10.66.7.218:5060;branch=z9hG4bK3FCBDC
Max-Forwards: 70
CSeq: 103 BYE
Reason: Q.850;cause=65
Content-Length: 0
*Feb 19 11:10:55.525: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpSocketReads: Msg enqueued for SPI with IP addr: 10.200.7.157:5060
*Feb 19 11:10:55.525: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
*Feb 19 11:10:55.525: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x00000000
*Feb 19 11:10:55.525: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:2169301@10.66.7.218:5060 SIP/2.0
Via: SIP/2.0/UDP 10.200.7.157:5060;branch=z9hG4bKfhfcsk7e7upe2pakpfphfddaoT08070
From: <0097339982779>;tag=sbc0804h4bsb2sa-CC-300097339982779>
To: "Aslam Shaik"<2169301>;tag=248B1A04-13842169301>
CSeq: 1 BYE
Max-Forwards: 70
Content-Length: 0
*Feb 19 11:10:55.525: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
*Feb 19 11:10:55.525: //31229/D5950F0DBF34/SIP/Info/sipSPILocateInviteDialogCCB: ****Found CCB in UAC table
*Feb 19 11:10:55.525: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.200.7.157,Port 5060, Transport 1, SentBy Port 5060
*Feb 19 11:10:55.525: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
*Feb 19 11:10:55.525: //31229/D5950F0DBF34/SIP/Transport/sipSPISendByeResponse: Sending BYE Response to the transport layer
*Feb 19 11:10:55.525: //31229/D5950F0DBF34/SIP/Transport/sipSPITransportSendMessage: msg=0x66CE4F9C, addr=10.200.7.157, port=5060, sentBy_port=5060, is_req=0, transport=1, switch=0, callBack=0x00000000
*Feb 19 11:10:55.525: //31229/D5950F0DBF34/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*Feb 19 11:10:55.525: //31229/D5950F0DBF34/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
*Feb 19 11:10:55.525: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x66CE4F9C, addr=10.200.7.157, port=5060, connId=0 for UDP
*Feb 19 11:10:55.549: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: "Aslam Shaik" <2169301>;tag=248B1A04-13842169301>
Date: Tue, 19 Feb 2013 11:10:55 GMT
CSeq: 1 BYE
Content-Length: 0
*Feb 19 11:10:55.549: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpSocketReads: Msg enqueued for SPI with IP addr: 10.200.7.157:5060
*Feb 19 11:10:55.549: //31229/D5950F0DBF34/SIP/Info/sipSPIStopHoldTimer: Stopping hold timer
*Feb 19 11:10:55.549: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAddRouteHeaders: status = TRUE Route: <10.200.7.157:5060>10.200.7.157:5060>
*Feb 19 11:10:55.549: //31229/D5950F0DBF34/SIP/Transport/sipSPISendBye: Sending BYE to the transport layer
*Feb 19 11:10:55.549: //31229/D5950F0DBF34/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
*Feb 19 11:10:55.549: //31229/D5950F0DBF34/SIP/Transport/sipSPITransportSendMessage: msg=0x66CE4F9C, addr=10.200.7.157, port=5060, sentBy_port=0, is_req=1, transport=1, switch=0, callBack=0x00000000
*Feb 19 11:10:55.549: //31229/D5950F0DBF34/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*Feb 19 11:10:55.549: //31229/D5950F0DBF34/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
*Feb 19 11:10:55.549: //31229/D5950F0DBF34/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x66CE4F9C
*Feb 19 11:10:55.549: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x66CE4F9C, addr=10.200.7.157, port=5060, connId=1 for UDP
*Feb 19 11:10:55.549: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
*Feb 19 11:10:55.549: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x7095EC90
*Feb 19 11:10:55.549: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x7095EC90, addr=10.104.160.30, port=5060, connid=2, transport=TCP
*Feb 19 11:10:55.549: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
*Feb 19 11:10:55.549: //31228/D5950F0DBF34/SIP/Info/sipSPIFindCcbUASRespTable: *****CCB found in UAS Response table. ccb=0x70782DB8
Received:
SIP/2.0 200 OK
Date: Tue, 19 Feb 2013 11:03:57 GMT
Content-Length: 0
CSeq: 101 BYE
*Feb 19 11:10:55.549: //31228/D5950F0DBF34/SIP/Info/sipSPIIcpifUpdate: CallState: 4 Playout: 0 DiscTime:61310911 ConnTime 61310815
*Feb 19 11:10:55.549: //31228/D5950F0DBF34/SIP/State/sipSPIChangeState: 0x70782DB8 : State change from (STATE_DISCONNECTING, SUBSTATE_NONE) to (STATE_DEAD, SUBSTATE_NONE)
*Feb 19 11:10:55.553: //31228/D5950F0DBF34/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x70782DB8
State of The Call : STATE_DEAD
TCP Sockets Used : YES
Calling Number : 2169301
Called Number : 90097339982779
Source IP Address (Sig ): 10.106.78.7
Destn SIP Req Addr:Port : 10.104.160.30:5060
Destn SIP Resp Addr:Port : 10.104.160.30:41357
Destination Name : 10.104.160.30
*Feb 19 11:10:55.553: //31228/D5950F0DBF34/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream : 1
Negotiated Codec : No Codec
Negotiated Codec Bytes : 0
Nego. Codec payload : 255 (tx), 255 (rx)
Negotiated Dtmf-relay : 0
Dtmf-relay Payload : 0 (tx), 0 (rx)
Source IP Address (Media): 10.106.78.7
Source IP Port (Media): 17372
Destn IP Address (Media): 0.0.0.0
Destn IP Port (Media): 0
Orig Destn IP Address:Port (Media): 0.0.0.0:0
Disconnect Cause (CC) : 86
Disconnect Cause (SIP) : 200
*Feb 19 11:10:55.553: //31228/D5950F0DBF34/SIP/Info/sipSPIUdeleteccCallIdFromTable: Removing call id 79FC
*Feb 19 11:10:55.553: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIDeleteContextFromTable: Context for key=[31241] removed.
*Feb 19 11:10:55.553: //31228/D5950F0DBF34/SIP/Info/sipSPIUdeleteCcbFromUASReqTable: ****Deleting from UAS Request table.
*Feb 19 11:10:55.553: //31228/D5950F0DBF34/SIP/Info/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x70782DB8 key=6014400-12315c11-adf1-1ea0680a@10.104.160.3090097339982779
*Feb 19 11:10:55.553: //31228/D5950F0DBF34/SIP/Info/sipSPIUdeleteCcbFromUASRespTable: ****Deleting from UAS Response table.
*Feb 19 11:10:55.553: //31228/D5950F0DBF34/SIP/Info/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x70782DB8 key=6014400-12315c11-adf1-1ea0680a@10.104.160.30248B2DBC-3A7
*Feb 19 11:10:55.553: //31228/D5950F0DBF34/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
*Feb 19 11:10:55.553: //31228/D5950F0DBF34/SIP/Info/sipSPIUfreeOneCCB: Freeing ccb 70782DB8
*Feb 19 11:10:55.553: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContextFromTable: NO context for key[31241]
*Feb 19 11:10:55.553: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
*Feb 19 11:10:55.553: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x00000000
*Feb 19 11:10:55.553: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
*Feb 19 11:10:55.553: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 487 Request Terminated
CSeq: 103 BYE
Warning: 399 SoftX3000 "SS030001F00154L00763[00000] Glare Bye condition encountered"
Content-Length: 0
*Feb 19 11:10:55.553: //31229/D5950F0DBF34/SIP/Info/sipSPIIcpifUpdate: CallState: 4 Playout: 0 DiscTime:61310911 ConnTime 61310814
*Feb 19 11:10:55.553: //31229/D5950F0DBF34/SIP/State/sipSPIChangeState: 0x70795398 : State change from (STATE_DISCONNECTING, SUBSTATE_NONE) to (STATE_DEAD, SUBSTATE_NONE)
*Feb 19 11:10:55.553: //31229/D5950F0DBF34/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x70795398
TCP Sockets Used : NO
Called Number : 0097339982779
Source IP Address (Sig ): 10.66.7.218
Destn SIP Req Addr:Port : 10.200.7.157:5060
Destn SIP Resp Addr:Port : 10.200.7.157:5060
Destination Name : 10.200.7.157
*Feb 19 11:10:55.713: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 103 BYE
Content-Length: 0
*Feb 19 11:10:55.713: //-1/xxxxxxxxxxxx/SIP/Error/sipSPILocateInviteDialogCCB: Could not find ccb for response
*Feb 19 11:11:02.713: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpSocketReads: Msg enqueued for SPI with IP addr: 10.200.7.157:5060
*Feb 19 11:11:02.713: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
*Feb 19 11:11:02.713: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x00000000
*Feb 19 11:11:02.713: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.200.7.157:5060;branch=z9hG4bKkdpfo7s4tuaphto7teau4fckuT22652
Call-ID: isbc4bsb4kbb2c7u2dee2bkc4sbauscted4h@SoftX3000
From: <10.66.7.218:5060>;tag=sbc0802hdbpeop710.66.7.218:5060>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
*Feb 19 11:11:02.713: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
*Feb 19 11:11:02.713: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAddContextToTable: Added context(0x70BA16B4) with key=[31244] to table
*Feb 19 11:11:02.713: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 10.200.7.157,Port 5060, Transport 1, SentBy Port 5060
*Feb 19 11:11:02.713: //-1/E1B54E3ABF3B/SIP/State/sipSPIChangeState: 0x70BA16B4 : State change from (STATE_NONE, SUBSTATE_NONE) to (STATE_IDLE, SUBSTATE_NONE)
*Feb 19 11:11:02.713: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.200.7.157,Port 5060, Transport 1, SentBy Port 5060
*Feb 19 11:11:02.713: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
*Feb 19 11:11:02.713: //31231/E1B54E3ABF3B/SIP/Info/sipSPIGetCallConfig: Precondition tag absent in Require/Supported header
*Feb 19 11:11:02.713: //31231/E1B54E3ABF3B/SIP/Info/sipSPIGetCallConfig: Non dial peer leg - using RTP Supported Codecs
*Feb 19 11:11:02.713: //31231/E1B54E3ABF3B/SIP/Info/sipSPIGetCallConfig: RTP Preferred Codecs supported by GW 18
*Feb 19 11:11:02.713: //31231/E1B54E3ABF3B/SIP/Info/sipSPIGetCallConfig: RTP Preferred Codecs supported by GW 0
*Feb 19 11:11:02.713: //31231/E1B54E3ABF3B/SIP/Info/sipSPIGetCallConfig: RTP Preferred Codecs supported by GW 8
*Feb 19 11:11:02.713: //31231/E1B54E3ABF3B/SIP/Info/sipSPIGetCallConfig: RTP Preferred Codecs supported by GW 4
*Feb 19 11:11:02.713: //31231/E1B54E3ABF3B/SIP/Info/sipSPIGetCallConfig: RTP Preferred Codecs supported by GW 2
*Feb 19 11:11:02.713: //31231/E1B54E3ABF3B/SIP/Info/sipSPIGetCallConfig: RTP Preferred Codecs supported by GW 15
*Feb 19 11:11:02.713: //31231/E1B54E3ABF3B/SIP/Info/sipSPIGetCallConfig: RTP Preferred Codecs supported by GW 3
*Feb 19 11:11:02.717: //31231/E1B54E3ABF3B/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.66.7.218
*Feb 19 11:11:02.717: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_OPTIONS_RESP
*Feb 19 11:11:02.717: //31231/E1B54E3ABF3B/SIP/Info/sact_idle_new_message_options: ccsip_api_options_ind returned: SIP_SUCCESS
*Feb 19 11:11:02.717: //31231/E1B54E3ABF3B/SIP/State/sipSPIChangeState: 0x70BA16B4 : State change from (STATE_IDLE, SUBSTATE_NONE) to (SIP_STATE_OPTIONS_WAIT, SUBSTATE_NONE)
*Feb 19 11:11:02.717: //31231/E1B54E3ABF3B/SIP/Info/sipSPIUaddCcbToUASReqTable: ****Adding to UAS Request table.
*Feb 19 11:11:02.717: //31231/E1B54E3ABF3B/SIP/Info/sipSPIUaddCcbToTable: Added to table. ccb=0x70BA16B4 key=isbc4bsb4kbb2c7u2dee2bkc4sbauscted4h@SoftX3000
*Feb 19 11:11:02.717: //31231/E1B54E3ABF3B/SIP/Info/sipSPIUaddccCallIdToTable: Adding call id 79FF to table
*Feb 19 11:11:02.717: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 38
*Feb 19 11:11:02.717: //31231/E1B54E3ABF3B/SIP/Info/sipSPISendOptionsResponse: Associated container=0x7117C8D4 to Options Response
*Feb 19 11:11:02.717: //31231/E1B54E3ABF3B/SIP/Transport/sipSPITransportSendMessage: msg=0x70861A28, addr=10.200.7.157, port=5060, sentBy_port=5060, is_req=0, transport=1, switch=0, callBack=0x615E9E98
*Feb 19 11:11:02.717: //31231/E1B54E3ABF3B/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*Feb 19 11:11:02.717: //31231/E1B54E3ABF3B/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
*Feb 19 11:11:02.717: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x70861A28, addr=10.200.7.157, port=5060, connId=0 for UDP
*Feb 19 11:11:02.717: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.66.7.218>;tag=248B6974-8DD10.66.7.218>
Date: Tue, 19 Feb 2013 11:11:02 GMT
CSeq: 1 OPTIONS
Content-Length: 164
v=0
o=CiscoSystemsSIP-GW-UserAgent 8661 7456 IN IP4 10.106.78.7
s=SIP Call
t=0 0
m=audio 0 RTP/AVP 18 0 8 4 2 15 3
02-19-2013 05:05 AM
Ashley,
You are using sip to sip so dont bother about the other debugs..Please add this to your config
voice service voip
sip
early-offer forced
Do a test again and send only "debug ccsip messsages"
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
02-19-2013 05:18 AM
Hi..thank you for taking time to assist. Before I proceed with the change that you have proposed, I wanted to mention that I removed codec preference 2 g711ulaw from my config (as below) and it is now working fine. Ony codec preference 1 g711alaw is now in the config which is what the provider is expecting.
However I would like to reinstate codec preference 2 g711ulaw in my config but see that there is no attribute field in the below. Am i missing something?
v=0
s=SIP Call
t=0 0
02-19-2013 05:37 AM
G711ulaw is certainly in the attributes..Looking at the M-line
CUBE is offering
18=G729
0=PCMU---------G711u
8=PCMA-----G711a
And your provider certainly supports G711ulaw and alaw
This is the SDP in the response received from your ITSP
m=audio 37372 RTP/AVP 8 0 18 4 2 98 99 97
a=rtpmap:8 PCMA/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:18 G729/8000
a=rtpmap:4 G723/8000
a=rtpmap:2 G726-32/8000
a=rtpmap:98 G726-40/8000
a=rtpmap:99 G726-32/8000
a=rtpmap:97 telephone-event/8000
a=fmtp:97 0-15
a=fmtp:18 annexb=yes
02-23-2013 09:52 PM
Hi aokanlawon
Thank you for the insights you have provided which has helped in resolving the issue and furthered my understanding.
