05-13-2021 07:37 AM
Dear Team,
When I make external calls the number appears with extension number/DN
e.i.:
Calling the number +258 842912221 from the DN: 6100. It is supposed to use: +258 840957700 for external calls(outbound) but it shows +258 8409577006100
05-13-2021 07:44 AM - edited 05-13-2021 07:44 AM
Whats your external phone number mask, have you checked use external phone mask on RP. is there any translation you applied on voice gateway ?
05-13-2021 08:02 AM
05-13-2021 08:35 AM - edited 05-13-2021 08:39 AM
Can you share the VG configuration, I assume there is some translation on gateway. With above configuration, you should send calling information 840957700. But your debug says 6100.
05-13-2021 08:53 AM
05-13-2021 09:49 AM - edited 05-13-2021 09:49 AM
05-13-2021 07:54 AM
Use external phone number mask +258 840957700 on your phone.
05-13-2021 08:12 AM
Didn´t solve the issue.
Is that all that I must change?
05-13-2021 08:16 AM
05-13-2021 08:30 AM
With the above debug, are you getting caller-ID +258 8409577006100?
If yes you need to talk to Telco. Looks like they are translating it.
05-13-2021 08:54 AM
I will try to engage them.... Bu I doubt it.
05-13-2021 10:28 AM
Take note of what you send to the Telco. If what you send is as per their requirements and something else is shown to the called party it is like others have answered the Telco that modify the calling number. If so they aught not be that hard to deal with. It is a matter of presenting facts and making your case clearly.
05-13-2021 10:43 AM - edited 05-13-2021 10:06 PM
Based on your other post about issues with outbound calls I think that you should be sending 0957700 as the called number to your Telco, not 840957700. Use the information given by other peers in the community and make the needed changes. One observation made is that you have both “Use Calling Party’s External Phone Number Mask” and “Calling Party Transform Mask” set on the RP. You should only need to have one of them set.
Also please note that if you have transforms in any other place that comes later in the call flow in CM, for example on the gateway configuration object in CM, those will override the configuration on the RP. In essence if you have any transforms in a later stage what you have set at an easier stages is ignored.
05-13-2021 07:15 PM
Can you remove the Calling party CSS from Gateway. After removing the CSS make sure you rest the gateway.
Take a debug after the change and see what calling information is sent to ISP.
