Outgoing calls fail
Eugene Meyer
Hi guys.
I ran into some issues with one of our brach sites where all outgoing calls fail.
We use a standard config across all brach sites wiht MGCP gateways, and works perfectly except this one site.
It used to work and recently had some power failures. After the power failures all out going calls started to fail.
Incoming calls work fine.
I've had the telco take a look at their equipment and they came back saying everything is fine on their side.
I ran a debug isdn q931 on the gateway while making outgoing calls, please see the attached file.
I can see that the telco is sending me the disconect message, but it is interesting to see the messages before the diconnect.
It seems that the gateway is complaining about missing information
A status message of "message not complatible with call state or not implemented" and another message "Mandatory information element missing"
It looks to me that there is a signaling issue between the Telco and the brach site when making outgoing calls, but I have no idea where to start troubleshooting this.
Any assitance will be much appreciated.
10 Replies 10
sh isdn status?
have you rebooted your gw?
Best Regards
Thanks for all the prompt responses
I can confirm the gateway was rebooted, and that sh isdn stat shows all BRIs up and multiple frame established, and that the switch type is matching with the provider's switch type.
I will ask the provider to look into the RELEASE_COMP message.
you are receiving "Cause i = 0x82D100000000 - Invalid call reference value" from provider.
please crosscheck your isdn switch type. If the configuration looks good, have a word with your provider.
//Suresh Please rate all the useful posts.
Would that invalid call reference value message not be because of the "0x80E2 - Message not compatible with call state or not implemented" and "0x80E0 - Mandatory information element missing" message transmitted from the gateway?
It looks to me that the gateway is complaining that it is not receiving all information if I look at the order of the call ref#
Nadeem Ahmed
This is more likely an issue on provider side since immediately after SETUP message, we are recieving RELEASE_COMP from provider end.
001791: Dec 12 10:52:09.791 GMT: ISDN BR0/2/1 Q931: TX -> SETUP pd = 8  callref = 0x11
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0x8A
                Exclusive, B2
        Calling Party Number i = 0x0081, '0112516401'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '0716009662'
001792: Dec 12 10:52:09.843 GMT: ISDN BR0/2/0 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x91
Ask the provider why they are sending this RELEASE_COMP ??
Br,
Nadeem
Please rate all useful post.
Br, Nadeem Please rate all useful post.
Hi Nadeem.
The debug output I've attached is only the last bit, but below is the full debug.
When calling a number the GW tries to push the call out, but fails on the first attempt and then immediatly tries to push out a call again.
The RELEASE_COMPLETE message you see straight after the SETUP message looks like it is from the previous call that failed. This would explain why you see the message.
In the debug output above you dont see the RELEASE COMPLETE straig after the SETUP message.
Thanks for your help.
001783: Dec 12 10:52:09.187 GMT: ISDN BR0/2/0 Q931: TX -> SETUP pd = 8  callref = 0x11
        Sending Complete
                Standard = CCITT
        Channel ID i = 0x8A
                Exclusive, B2
001784: Dec 12 10:52:09.439 GMT: ISDN BR0/2/0 Q931: RX <- SETUP_ACK pd = 8  callref = 0x91
        Channel ID i = 0x8A
                Exclusive, B2
001785: Dec 12 10:52:09.443 GMT: ISDN BR0/2/0 Q931: TX -> STATUS pd = 8  callref = 0x11
        Cause i = 0x80E2 - Message not compatible with call state or not implemented
        Call State i = 0x01
001786: Dec 12 10:52:09.539 GMT: ISDN BR0/2/0 Q931: RX <- CALL_PROC pd = 8  callref = 0x91
001787: Dec 12 10:52:09.543 GMT: ISDN BR0/2/0 Q931: TX -> STATUS pd = 8  callref = 0x11
        Cause i = 0x80E0 - Mandatory information element missing
        Call State i = 0x01
001788: Dec 12 10:52:09.643 GMT: ISDN BR0/2/0 Q931: RX <- DISCONNECT pd = 8  callref = 0x91
        Cause i = 0x82E500000000 - Message not compatible with call state
        Progress Ind i = 0x8288 - In-band info or appropriate now available
001789: Dec 12 10:52:09.647 GMT: ISDN BR0/2/0 Q931: TX -> RELEASE pd = 8  callref = 0x11
001790: Dec 12 10:52:09.743 GMT: ISDN BR0/2/0 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x91
        Sending Complete
                Standard = CCITT
        Channel ID i = 0x8A
                Exclusive, B2
001793: Dec 12 10:52:10.039 GMT: ISDN BR0/2/1 Q931: RX <- SETUP_ACK pd = 8  callref = 0x91
        Channel ID i = 0x8A
                Exclusive, B2
001794: Dec 12 10:52:10.043 GMT: ISDN BR0/2/1 Q931: TX -> STATUS pd = 8  callref = 0x11
        Call State i = 0x01
001795: Dec 12 10:52:10.139 GMT: ISDN BR0/2/1 Q931: RX <- CALL_PROC pd = 8  callref = 0x91
001796: Dec 12 10:52:10.143 GMT: ISDN BR0/2/1 Q931: TX -> STATUS pd = 8  callref = 0x11
        Call State i = 0x01
001797: Dec 12 10:52:10.243 GMT: ISDN BR0/2/1 Q931: RX <- DISCONNECT pd = 8  callref = 0x91
001798: Dec 12 10:52:10.247 GMT: ISDN BR0/2/1 Q931: TX -> RELEASE pd = 8  callref = 0x11
001799: Dec 12 10:52:10.343 GMT: ISDN BR0/2/1 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x91
001800: Dec 12 10:52:10.443 GMT: ISDN BR0/2/1 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x91
absa-2902-0241strydo-ce-1#
Hi Eugene,
Simple question, is it the ISDN 2 B boxes you have from Telkom? They should have 2 ports one which you can connect an analog phone to and see if you can make an external call over the BRI. This will give you more or less an Idea what is going on.
Your BRI shows multi frame so that is fine, I can see you sent telkom only 10 digits as they expect.
So start from the beginning and lets make sure that BRI can take a voice call.
Do you have another BRI card you can test with?
Best Regards
Hi Hermanus.
I have 4 BRI ports on site, and none of them seems to be working.
This was a working solution for months, but as I mentioned after some power issues on site all outgoing calls started to fail.
They did connect a trent test (disconected the BRI's from the gateway and connected them directly to their equipment) and were able to make calls.
Its only outgoing calls that are failing, incoming calls work fine.
I think there is a signaling issue, but confirmed that the switch type Im matches with that of telkom.
Here are is the BRI configs
interface BRI0/2/0
no ip address
isdn switch-type basic-net3
isdn incoming-voice voice
isdn bind-l3 ccm-manager service mgcp
no isdn outgoing ie progress-indicator
isdn outgoing display-ie
isdn outgoing ie redirecting-number
interface BRI0/2/1
no ip address
interface BRI0/3/0
no ip address
isdn send-alerting
interface BRI0/3/1
no ip address
shutdown
isdn point-to-point-setup
isdn send-alerting
And my MGCP config
ccm-manager fallback-mgcp
ccm-manager redundant-host x.x.x.x
ccm-manager mgcp
no ccm-manager fax protocol cisco
mgcp
mgcp call-agent x.x.x.x 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode nte-ca
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp ip qos dscp af11 signaling
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
mgcp package-capability fm-package
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 ecm
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface GigabitEthernet0/1.302
mgcp bind media source-interface GigabitEthernet0/1.302
Hi Eugene,
This is what my BRI config looks like:
interface BRI0/1/0
no ip address
isdn overlap-receiving
isdn send-alerting
voice-port 0/1/0
compand-type a-law
cptone ZA
bearer-cap Speech
I do my MGCP the manual way:
ccm-manager switchback immediate
ccm-manager redundant-host xxx.xxx.xxx.xxx
ccm-manager mgcp
ccm-manager music-on-hold
mgcp
mgcp call-agent xxx.xxx.xxx.xxx service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp ip qos dscp cs3 signaling
mgcp sdp simple
mgcp bind control source-interface FastEthernet0/0.112
mgcp bind media source-interface FastEthernet0/0.112
mgcp profile default
Best Regards
Hi Eugene,
You are right. "Invalid call reference value" you are getting is of first setup message BR0/2/0 and the second setup is with BR0/2/1.
Are you meeting the requirements of Telco i.e. calling & called number type and it's plan.
Confirm the same requirement from Telco and configure accordingly and then check it again.
Nishant Savalia
Regards, Nishant Savalia
