Outside IVR making inbound call via SIP doesn't recognize our response via DTMF from our phones
garyasher99
We have a CME that is configured with a SIP provider and all works well including DTMF to outside organization's IVR.  We can navigate IVR systems when we make the outbound call.  Our issue is that we have a couple IVRs that call us and require us to navigate by pressing digits.  I have the dial-peers using voice-class sip dtmf-relay force rtp-nte.  The inbound calls do not recognize our choices.  I also don't know how to reproduce these calls, we are a provider and get these from our customers as they come in, only a couple a week.
My inbound dial-peer
dial-peer voice 700 voip
description SIP Trunk (incoming)
session protocol sipv2
session target dns:sip3.voipvoip.com
incoming called-number 555.......
codec g711ulaw
Any ideas, please let me know.
Gary
Hello Gary,
This would need below to logs to verify and isolate the issue.
debug voip ccapi inout
debug ccsip message
debug voip rtp session named-event
Meanwhile you can try removing the "voice-class sip dtmf-relay force rtp-nte" command and test below command.
dtmf-relay rtp-nte sip-kpml sip-notify
Balram
Please rate if you find this helpful
Thank You
Balram
Balram,
I changed the command from voice class dtmf to dtmf-relay rtp-nte sip-kpml sip-notify.  I tested through an IVR and DTMF works.  So I have to wait for feedback from the client.
Thank you for your suggestion. I will comment when I hear from them.
Gary
