PAB subscribe through BAT
Aman Soi
One of our customer is using Call manager version 7 [which is end of support].We have created Personal Address Book [PAB] and want to subscribe for all the IP phone users.
Is it possible to do through BAT?
regds,
aman
Hi Aman.
You can  create a generic phone template through bat.
On top right corner select Subscribe/unscribe services.
Select the service you want to deploy and save,
Go through BAT menu --> Update phones (query)
Select all phones
Search for "Add all services from this template" and select the previously created template.
Select "run immediately"
Please let me know if it helps-
Carlo
Please rate all helpful posts "The more you help the more you learn"
Manish Gogna
Hi Aman,
I did some research on this and it looks like it is not possible to update PAB via BAT.
Manish
thanks for reply[+5 to Manish and Carlo]
Carlo, I will check tomorrow and revert.
regds,
aman
Manish Gogna
PAB as a service can however be configured as explained here
https://tools.cisco.com/bugsearch/bug/CSCsl95467/?reffering_site=dumpcr
Manish
Hi Aman.
Select all phones
Carlo
