09-30-2013 06:32 AM - edited 03-16-2019 07:36 PM
09-30-2013 06:43 AM
Hi.
In the old license model, 4
Carlo
Please rate all helpful posts
"The more you help the more you learn"
09-30-2013 08:12 AM
Positive is 5 stars, anything else means it was not complete.
Thanks for rating anyhow, good luck.
Chris
09-30-2013 06:43 AM
Hi.
Carlo
09-30-2013 06:45 AM
thanks for the quick reply. what do mean by the old licenes model.
09-30-2013 06:52 AM
What version of CUCM are you on?
Chris
09-30-2013 06:53 AM
Call manager version 8.6
09-30-2013 06:56 AM
Then as already answered, you will be using 4 DLUs for the phone itself. CUCM version 9 no longer uses DLUs as it tracks actual user licenses via ELM.
HTH, please rate all useful posts!
Chris
09-30-2013 07:00 AM
thanks
09-30-2013 07:02 AM
Hi Curtis,
you can also refer the link which has DLU calculator.
https://supportforums.cisco.com/thread/309942
regds,
aman
09-30-2013 07:22 AM
Curtis,
It appears you were not completely satisfied with the answers, can you let us know what else you are missing?
Chris
09-30-2013 08:10 AM
no it was good I gave possitive feed back.
09-30-2013 08:12 AM
Chris
