After integrating Presence server with CUCM, rhosts file dont match across the cluster. Some servers have the presence servers on the rhosts file but others don't.Any Ideas?
Hi NetProI have a CUCME v9.1 and I have a few phones 8941. I want change the background image, the files is in the router flash, but the phones don't show the option for change the background image. The phones firmware is SCCP 9-2-2-0, es_CO locale.A...
Hi,I have a cucm 9.1.1.20000-5 version in my office and I have a corporate address book which works fine on all the users phone.I got a request from my seniors to create a personal address book for few users.I created a new personal address book and ...
Hi All,I have a Cisco 3825 for a VG and this is supposed to send calls out via a SIP Trunk.When dialling out from the site calls are being put out over the 2 BRI lines which are for backup only and not going out over the SIP.Incoming calls to the sit...
Hello everyone! I'm in great need of solving the problem, and i can't, with the help of all docs and threads in Internet. I need to make work IP phones 7962G on 2921's CME. So, i have new 2921, 3750G and 7962G phones, which are not registering on 292...
good day everybody, I'm having a problem with calls fom PSTN to VoIP phones. There is a cheme PSTN (Nortell) ----> Cisco 2911 (gateway) ----> Cisco C2600-IX-M (Gatekeeper) ----> CUCM 8.6 Calls from VoIP phones to PSTN works just fine. When PSTN user ...
Hi,We have a site where by the phones are occasionally and randomly rebooting mid call.We checked cabling, switch configuration etc.The phones are set tp pickup their ip address from the DHCP on the VGW.I have set the Option 150.However - I was readi...
Hi all, can anyone tell me how time of day routing works on the call manager, say we have a number, we want it to call normally at say 08:00 to 12:00, then after this should go to voicemail or another numberwhat do I need to do to create this ?cheers...
HelloWhether every 8831 need cube 3 when the 8831 in daisy-chain configuration?I found the following information in datasheet, but I have no idea what means..The Cisco Unified IP Conference Phone 8831 is an interoperable IEEE 802.3af PoE (Class 3 dev...
Hellowe have a 8.6.1 CUCM Cluster with EM enabled. It works as expected but, sometime some users on some (random) phones are still able to login but they are not able to place the call and they hear the message "the precedence used is not authorized ...
Hi,I have a problem with Cisco Communications Manager and KIRK Dect for call interoperability integration.I have installed Communications Manager 9.1.1.20000-5 version and DECT Kirk solution with KWS6000 dect server (PCS13_ firmware version).This is ...
Hello,Please be indulgent if I forgot something, it’s my first post here I need you help with a VoIP problem. I’m installing a new site with IP telephony. We work with a CUCM 7.1(5).On site we have a PRI and my MGCP gateway is correctly registered to...
Hi,I have a question related to CallFwdAll With Activating Device/Line CSS. Will it get activated only when the users press the CallFwdAll softkey on the phone? The administrators cannot update the line settings to reflect the setting as below and ma...
Hey Guys,I have a customer who uses 9 to call out and they will be using jabber mainly to dial out of outlook. But all the numbers inthe contact is save without 9, how can i go about with this.IM & Presence 9.1.1.20000-5 and Jabber 9.2.4 CUCM...
We have the following setup:CUCM --- SIP --- CUBE --- SIP --- ITSP |---------SIP----- CUBE --- SIP --- ITSPThe CUBE has 2 physical interfaces, one for each call leg. When the interface is down on the ITSP side, outgoing calls fail.Ofcouse, this is...
Subject | Author | Posted |
01-24-2025 03:51 PM | ||
01-24-2025 03:18 PM | ||
01-22-2025 01:28 PM | ||
01-22-2025 01:04 AM | ||
01-16-2025 02:00 AM |
User | Count |
5 | |
4 | |
2 | |
1 | |
1 |
