Phone Time or timezone problem
Manuel Azevedo
Level 4
Level 4
Hi all,
I have two customers right now with problems with the time zone on their phones.
Customer 1:
  • 7921     CP7921G-1.3.3
  • 7940     P00308010100
Both this models display a wrong time (-1 of current time)
  • 7906     SCCP11.8-5-2SR1S
This model displays a correct time.
Customer's running CUCM  7.1.3.20000-2
NTP seems correct:
admin:utils ntp status
ntpd (pid 24900) is running...
     remote           refid      st t when poll reach   delay   offset  jitter
127.127.1.0     LOCAL(0)        10 l   28   64  377    0.000    0.000   0.004
*X.XXX.X.XX      XXX.XXX.X.XXX    3 u  642 1024  377    6.884   -9.076   3.476
synchronised to NTP server (X.XXX.X.XX) at stratum 4
   time correct to within 115 ms
   polling server every 1024 s
Current time in UTC is : Wed Oct 27 14:14:38 UTC 2010
Current time in Europe/Lisbon is : Wed Oct 27 15:14:38 WEST 2010
admin:
Date/Time Group is configured to (GMT) Europe/London * (Compatible with legacy phones)
Customer 2:
  • 6941     SCCP69xx.9-0-3-a
This models display a wrong time (-1 of current time)
  • 7962     SCCP42.9-0-2SR1S
Customer's running CUCM  7.1.5.30000-1
NTP also seems correct:
ntpd (pid 31403) is running...
127.127.1.0     LOCAL(0)        10 l   39   64  377    0.000    0.000   0.004
*XXX.XXX.XX.XX   XXX.XXX.XX.XX    4 u  438 1024  377    0.526    0.797  23.508
synchronised to NTP server (XXX.XXX.XX.XX) at stratum 5
   time correct to within 304 ms
Current time in UTC is : Wed Oct 27 14:13:56 UTC 2010
Current time in Europe/Lisbon is : Wed Oct 27 15:13:56 WEST 2010
admin:
It seems to me that old legacy phones (7921, 7940) and new budget phones (69XX) seem to be affected with this problem.
I've searched online and found nothing. Did any of you had this problems?
Manuel Azevedo
srsivara
Hi Manuel,
This is a known defect :
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCtj70240
7940/7960/69XX phones are showing 1 hour before the real time.
The following versions are affected:
* 7.1.3: all CM versions below 007.001(003.33031.001)
* 7.1.5: all CM versions below 007.001(005.12008.001)
* 8.0.2: all CM versions below 008.000(002.41007.001), 8.0.3 shouldn't be affected.
We already have COP files for the 3 branches mentioned above:
7.1.3: http://tools.cisco.com/squish/3D00d9
ciscocm.dst-updater.2010i-1.el4.7.1.3.cop.sgn
7.1.5: http://tools.cisco.com/squish/36da0f
ciscocm.dst-updater.2010i-1.el4.7.1.5.cop.sgn
8.0: http://tools.cisco.com/squish/62fB9b
ciscocm.dst-updater.2010i-1.el4.8.0.2.cop.sgn
Please bear in mind the following suggestions when installing the COP
files:
- Installation to all machines in the cluster is required
- As with any installation or upgrade, it is recommended that you apply this Update during off peak hours.
- When applying this Package be advised that a clusterwide reboot is required.
- It is also recommended that this update be installed on all  machines in the cluster before the cluster is rebooted.
- Sriram
5 Replies 5
d.hillman
COMMENT REMOVED, DUE TO STUPID ADVICE
srsivara
Hi Manuel,
files:
- Sriram
Thank you Sriram.
It works perfectly.I don't know I missed it. Probably didn't look deep enough.
Kind regards,
Manuel
Good to know that it helped resolving your issue, Manuel !
Sriram
Guys, the same problem it is happening to me, but my version is
Active Version
6.0.1.2000-4
I don´t know what else to do.
