Phones continue ringing After IP Phone hung up
eug-c
I'm facing a problem, hope someone have encountered this before.
When I use a IP phone to dial a local PSTN call to a mobile phone, the mobile phone starts to ring.
However, before the mobile phone is answered, I hang up the IP phone.
Weird thing is, the mobile phone still continues ringing.
If I answer, I would get a busy tone.
Please help...
Eugene
9 Replies 9
alessandro.dona
Level 3
Level 3
Are you experiencing this issue only with mobile or also with land phone?
perform, if you can, a "debug isdn q931"
and then make a call to a mobile phone!
Hi, I'm facing this on both land phone and mobile, local and International.
I did a debug:
Dialed from 1000 to a mobile 90624248.
mobile started to ring.
Router#
Dec 15 16:08:07.943 UTC: ISDN Se0/2/0:23 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 225470586
Dec 15 16:08:07.943 UTC: ISDN Se0/2/0:23 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Called num 0196592252411
Dec 15 16:08:07.943 UTC: ISDN Se0/2/0:23 Q931: TX -> SETUP pd = 8 callref = 0x0091
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Calling Party Number i = 0x0081, '2225471000'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '990624248'
Dec 15 16:08:08.163 UTC: ISDN Se0/2/0:23 Q931: RX <- SETUP_ACK pd = 8 callref = 0x8091
Progress Ind i = 0x8288 - In-band info or appropriate now available
Dec 15 16:08:18.235 UTC: ISDN Se0/2/0:23 Q931: RX <- CALL_PROC pd = 8 callref = 0x8091
Dec 15 16:08:23.923 UTC: ISDN Se0/2/0:23 Q931: RX <- ALERTING pd = 8 callref = 0x8091
Router#
Mobile was ringing.
On hook IP phone.
Dec 15 16:08:27.523 UTC: ISDN Se0/2/0:23 Q931: TX -> DISCONNECT pd = 8 callref = 0x0091
Cause i = 0x8090 - Normal call clearing
Dec 15 16:08:27.615 UTC: ISDN Se0/2/0:23 Q931: RX <- RELEASE pd = 8 callref = 0x8091
Dec 15 16:08:27.615 UTC: ISDN Se0/2/0:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x0091
Router#
Mobile phone is still ringing even after Ip phone is on hook.
Weird... :{
Not sure if we are hitting this bug: CSCsd58220. But we are using 12.4(9T) and it is not shown as fixed in the bug info. :{
Symptoms: The callee's phone rings continuously even after the caller goes on-
hook.
Conditions: When the caller goes on-hook, the gateway receives idle and does
not recognize the idle. The call does not get disconnected and the callee
keeps hearing the ringing tone continuously.
Workaround: The callee has to pick up the phone for the call to be dropped.
Your debug looks like to be OK!
try the same but call from your mobile phone to ip phone and the on hook your mobile phone!
in my opinion it is or a bug of your IOS or you have a problem with your phone provider.
It's not a very good workaround!
I would change IOS into a bug fixed one!
Thanks for your prompt replies. :)
I tried calling in from my mobile and hanging up from my mobile.
The call on both sides will terminate immediately.
Yea, I agree I have to upgrade to a later version IOS.
Thanks. :)
Anyone else has encountered this before?
It appears from the capture that the router correctly disconnects the call and the switch acknowledges. The bug mentioned is about phones and not seem to apply to ISDN interfaces.
Yea, I agree.
But somehow I think the telco does not understand the disconnect message and continues to ring the mobile phone.
Weird huh.
Eugene
