Phones not generating SEP files
ElwinMkanyika
Hi Guys!
Why are the phones not generating SEP files? This is what they are generating
123          0 Aug 23 2012 21:48:18 +06:00 its/vrf1
124         61 Aug 23 2012 21:48:36 +06:00 its/SEPDEFAULT.cnf
125       3304 Aug 23 2012 21:48:36 +06:00 its/vrf1/XMLDefault.cnf.xml
126        596 Aug 23 2012 21:48:36 +06:00 its/vrf1/XMLDefault7902.cnf.xml
127       1044 Aug 23 2012 21:48:36 +06:00 its/vrf1/XMLDefault7905.cnf.xml
128       1360 Aug 23 2012 21:48:38 +06:00 its/vrf1/XMLDefault7906.cnf.xml
129        674 Aug 23 2012 21:48:38 +06:00 its/vrf1/XMLDefault7910.cnf.xml
130       1360 Aug 23 2012 21:48:38 +06:00 its/vrf1/XMLDefault7911.cnf.xml
131       1072 Aug 23 2012 21:48:38 +06:00 its/vrf1/XMLDefault7912.cnf.xml
132       1044 Aug 23 2012 21:48:40 +06:00 its/vrf1/XMLDefault7920.cnf.xml
133       1286 Aug 23 2012 21:48:40 +06:00 its/vrf1/XMLDefault7921.cnf.xml
134       1292 Aug 23 2012 21:48:40 +06:00 its/vrf1/XMLDefault7925.cnf.xml
135       1360 Aug 23 2012 21:48:40 +06:00 its/vrf1/XMLDefault7931.cnf.xml
136        621 Aug 23 2012 21:48:40 +06:00 its/vrf1/XMLDefault7935.cnf.xml
137        621 Aug 23 2012 21:48:42 +06:00 its/vrf1/XMLDefault7936.cnf.xml
138       1360 Aug 23 2012 21:48:42 +06:00 its/vrf1/XMLDefault7937.cnf.xml
139       1150 Aug 23 2012 21:48:42 +06:00 its/vrf1/XMLDefault7940.cnf.xml
140       1324 Aug 23 2012 21:48:42 +06:00 its/vrf1/XMLDefault7940-7914-1.cnf.xml
141       1312 Aug 23 2012 21:48:42 +06:00 its/vrf1/XMLDefault7940-7915-12-1.cnf.xml
142       1312 Aug 23 2012 21:48:44 +06:00 its/vrf1/XMLDefault7940-7915-24-1.cnf.xml
143       1312 Aug 23 2012 21:48:44 +06:00 its/vrf1/XMLDefault7940-7916-12-1.cnf.xml
144       1312 Aug 23 2012 21:48:44 +06:00 its/vrf1/XMLDefault7940-7916-24-1.cnf.xml
145       1467 Aug 23 2012 21:48:44 +06:00 its/vrf1/XMLDefault7940-7914-2.cnf.xml
146       1443 Aug 23 2012 21:48:46 +06:00 its/vrf1/XMLDefault7940-7915-12-2.cnf.xml
147       1443 Aug 23 2012 21:48:46 +06:00 its/vrf1/XMLDefault7940-7915-24-2.cnf.xml
148       1443 Aug 23 2012 21:48:46 +06:00 its/vrf1/XMLDefault7940-7916-12-2.cnf.xml
149       1443 Aug 23 2012 21:48:46 +06:00 its/vrf1/XMLDefault7940-7916-24-2.cnf.xml
150       1360 Aug 23 2012 21:48:48 +06:00 its/vrf1/XMLDefault7941.cnf.xml
151       1362 Aug 23 2012 21:48:48 +06:00 its/vrf1/XMLDefault7941GE.cnf.xml
152       1360 Aug 23 2012 21:48:48 +06:00 its/vrf1/XMLDefault7942.cnf.xml
153       1360 Aug 23 2012 21:48:48 +06:00 its/vrf1/XMLDefault7945.cnf.xml
154       1150 Aug 23 2012 21:48:48 +06:00 its/vrf1/XMLDefault7960.cnf.xml
155       1324 Aug 23 2012 21:48:50 +06:00 its/vrf1/XMLDefault7960-7914-1.cnf.xml
156       1312 Aug 23 2012 21:48:50 +06:00 its/vrf1/XMLDefault7960-7915-12-1.cnf.xml
157       1312 Aug 23 2012 21:48:50 +06:00 its/vrf1/XMLDefault7960-7915-24-1.cnf.xml
158       1312 Aug 23 2012 21:48:50 +06:00 its/vrf1/XMLDefault7960-7916-12-1.cnf.xml
159       1312 Aug 23 2012 21:48:52 +06:00 its/vrf1/XMLDefault7960-7916-24-1.cnf.xml
160       1467 Aug 23 2012 21:48:52 +06:00 its/vrf1/XMLDefault7960-7914-2.cnf.xml
161       1443 Aug 23 2012 21:48:52 +06:00 its/vrf1/XMLDefault7960-7915-12-2.cnf.xml
162       1443 Aug 23 2012 21:48:52 +06:00 its/vrf1/XMLDefault7960-7915-24-2.cnf.xml
163       1443 Aug 23 2012 21:48:52 +06:00 its/vrf1/XMLDefault7960-7916-12-2.cnf.xml
164       1443 Aug 23 2012 21:48:54 +06:00 its/vrf1/XMLDefault7960-7916-24-2.cnf.xml
No,
I am saying that when you use the command "create cnf " it should automatically generate this config
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
Ayodeji Okanlawon
Faith,
This suggests that you have not created the configuration files for your phones with the "create-cnf-file" command.
ideally you should have something like this:
1150 Aug 23 2012 21:48:48 +06:00 its/vrf1/XMLDefault7960.cnf.xml alias SEPxxxxxxxxxxxxxx
If you have configured a 7960 phone.
You can use the command below to see the files generated from the create cnf command.
CME#sh telephony-service tftp-bindings
You can also use the command below to see the content of each file
cme#more its/vrf1/XMLDefault7960.cnf.xml
aokanlawon hi!
Sorry for the delayed reply.
So you mena to tell me that i need to making tftp bindings for each phone ?
Eg.
tftp-server system:/its/XMLDefault7920.cnf.xml alias SEP001121CEC80A.cnf.xml
No,
Thank you. I forgot to do that.
